cwagner2401
  1. So I have the same issue as many others. I have two homes. Both have ISY994i ZW/IR Pro v. 5.3.4. Both stopped working with my gmail account on Feb 23. I tried 1) creating a new app password in gmail, 2) removing the account from ISY and putting it back and 3) using default. Nothing worked on either ISY. I switched to my AOL account and all is now working fine. Must be something that the folks at Google changed.
  2. I just upgraded a 994i ZW (300 series zwave) to 5.3.4 and then read that doing so will ruin the system (face slap). Is this a recoverable situation? I can still access the ISY so, I downgraded to 5.0.16C and it seems to be ok however I haven't tried to configure and test any devices yet. Thanks.
  3. Problem solved - I didn't realize there was an updated UDM app version put on the app store last week - downloaded and the status is back.
  4. I'm having the same issue. It started immediately after the oAuth issue was solved. I'm on what I believe is the latest ISY994 version 5.3.4
  5. Thanks, Javi.
  6. Question: Subsequent to a spurious restart event in my 994 (see below), the UDM remote access issue presented itself. Is there anything in the problem you found that could have restarted my 994? The log time is Eastern US time. @Javi INSTEON Device Control Value Time User Log Type 0 null Mon 2024/04/29 11:32:22 PM System Start
  7. Remote and Local now working just as before - all good here. Thank you!
  8. Same here - remotely, device icons are grey and I get the 404 error
  9. FYI - I can go to the UD ISY Portal and select "ISY Web Access" - there I can see and control devices. So it appears to me that the portal can see my ISYs but UD Mobile is having a problem with the portal.
  10. I can only work on the ISY in house #1 (the other is a 4 hour drive). So, in house #1, I followed the instructions and now local is working (can see and control devices) but, I still can't access remotely.
  11. Both ISYs produce the same result
  12. Also UD Mobile fails both local and remote.
  13. Just a note for clarity: both my systems are ISY994i/IR Pro 5.3.4 and UD Mobile app is latest from Apple app store
  14. No. I can control all devices with both the admin console and eK Pro both local and remote
