hargray2
  1. This works beautifully. Great explanation! Thanks again.
  2. You guys are awesome! I'll give this a try. Thanks
  3. Thanks for the fast response. Correct me if I'm reading it wrong, but at first glance it looks like this requires the ability to know which input the switch is on. The switch doesn't have the ability to be queried and doesn't reply in any way when an input is switched. It is receive only. Will this work without knowing the actual state of the hdmi switch? Daniel
  4. I have an HDMI matrix switch that I am controlling via rs232 with a global cache itach. I have created the network resources and programs to switch between four different HDMI inputs on the matrix switch. There are four programs, one for each input. Is it possible to set up a single KPL button to cycle through the programs? Each button press would run the next program, allowing me to cycle through the inputs on the HDMI switch. I have tested all of the programs manually from the ISY admin console and they work great. I just can't figure out how to do this with a single KPL button. It would also be very nice to have this on a single remotelinc button if possible. Any help would be greatly appreciated. Thanks Daniel
