oboyko
  1. Got it, thanks for your patience. Will try this approach tomorrow and let you know what happens. Cheers!
  2. Thanks LeeG! I assume you are referring to "Link Management->New INSTEON Device" menu option as opposed to "Start Linking"? If so, what should I enter into the "Address" field of "New INSTEON Device" dialog box? Thanks a lot for your help!
  3. Hi everybody! I just switched existing and previously linked KPL from 6 to 8 button configuration and expected to see three additional buttons in ISY Admin Console as a result - but no new buttons/devices appeared. Here are the steps I've taken so far. Pass 1: 1) Perform 6 to 8-button reconfiguration per Insteon instructions. 2) Put KPL into linking mode. 3) Initiate linking from ISY Admin interface. Result: only 5 KPL buttons in GUI. Pass 2: 1) Rest KPL to factory default. 2) Repeat steps from Pass 1. Result: same, only 5 buttons available. What I am doing wrong, or is it possible at all to force ISY to recognize new 8 button configuration for KPL? Thanks!
