boatfevor
  1. Russ, One word....HERO! Thanks for your hard work. It works great!!
  2. Thanks for your info. I went to your topic and found that the link in that topic no longer worked. Can you point me in another direction? Thanks? Corey
  3. Hello, Looking for a little help setting up a command to turn on my Denon audio receiver via the ISY. It is the CI version and can take IP codes via rule. What I would like to know is can I set a KPL to turn on the receiver and change the input to itunes to play music in the house. I tried to copy the irule codes to the network mod and tried every which way to get it to work. Now I am stuck asking anyone if they have any suggestions. Thank you for your time in advance.
  4. Hello, Can I trouble one of you for an example as I am not following the "20%" part. My switch address is "17.F7.C0" So if I understand this right it should be...rest/nodes/17F720%C/cmd/DOF for off. Am I close? Thank you for your time...
  5. I am sure this is really really simple but when I use this program, the light never turns off. If: From sunset to sunrise and control motion sensor is turned on and status front door light is off Then: sert front door light on wait 3 min set front door light off Thank you for your time!!
  6. boatfevor replied to boatfevor's topic in ISY994
    I am using the static DNS as this is the only way for me to access my ISY via the iphone. So I am not sure how to make sure the settings are correct. I am also having it sync every 24 hours. I tried the manual adjust and get "NTP server error DNS error"....
  7. boatfevor replied to boatfevor's topic in ISY994
    Okay, did that and what I get is -6100 followed by pool.ntp.org. Under the setting tab I have an "!" in red. I can log in remote to my isy so I assume the unit is able to talk to the web. What should I check next? Thanks!!!!
  8. boatfevor posted a topic in ISY994
    Quick Question, About every 3 min or so, the "MEM" and "ERR" LED light up for about 15 sec on the ISY. Any ideas on why this would be happening?
  9. Yes, Plan on using it as a 7 key when all done
  10. Happy New Year..... Don't know which way to make this work so I thought I would ask the experts.... Just made my KPL from a 6 to an 8 button. I like the large "off" button and would like to set it up for an all off. The problem I am running into is it now "G" & "H" button. I have played with the grouping, toggle, etc and having no luck. Is there a way to put the G & H button back together? I have programed using control g or h is pressed but they don't light up together when just one is press. Am I making any sense??? Thanks
  11. I "think" I am getting it now. I guess my next question would be how can I use KPL LED to let me know if any lights are on. For example, I went to bed but left the garage light on. I would like the KPL to tell me there is a light on...... am I getting in way to deep???
  12. Hello all, what I would like to do is set up a bedtime button on the KPL. I would like to press one button and turn off the kitchen however turn on the stair light and hallway light to 50%. I have played around with the programing however I get the little icon when I hit save. Can one of you give me a short example? Thanks for your time Corey
  13. boatfevor posted a topic in ISY994
    Hello, are there any how to video out there on programing the ISY? Trying to set up the outside light to come on at sunset and go off at 10pm. I get the light to come on however it remains on all night. Any help would be great. Thanks
  14. boatfevor posted a topic in ISY994
    Does anyone have an idea on what the max cable run from the router to the ISY and From the ISY to the Insteon Modem?
  15. Thank you, Got it working
