GregE
  1. GregE replied to GregE's topic in eisy-ui
    Yeah I can ping it and they did ask me to do that but I have neither at home so will have to bring one once I am back at work.
  2. GregE replied to GregE's topic in eisy-ui
    Thanks. I appreciate your help.
  3. GregE replied to GregE's topic in eisy-ui
    5.8.4 No luck. isy.io says it's offline
  4. GregE replied to GregE's topic in eisy-ui
    Yeah IoX launcher says not found so can't get to the admin console. I unplugged it and let it sit for a while but no luck. I should have not tried to upgrade since it was working.
  5. GregE posted a topic in eisy-ui
    Told my Eisy to upgrade but now I can't connect to it. UD Mobile is saying it is offline. I tried unplugging power and plugging back in to reboot but no luck. What else can I do? Thanks
  6. I got it to connect bringing it closer to the ISY with my setup cord but it was still acting weird once I put it in it's location so I took it out and moved another switch that was already on my system to that location. I'm going to return this one to Amazon as defective and get a replacement and try again.
  7. Love my Wago's!!! This switch doesn't have any pigtails so I will connect right to it.
  8. Made me a cord so I could add it to my network closer to the ISY and easily.
  9. I can give that a try but probably not until this Sunday. Need to load up a trailer and take my daughter's stuff for her apt to her.
  10. Firmware and UI are the same version. Yes other Zwave devices. I'm trying to install another switch like one that I already have. That switch is about 5 feet away. The ISY is in the basement.
  11. So did the update but still not able to add my zwave switch. 😪
  12. I have 6.82.01 so I will do the upgrade tonight and see if that helps. Figured I'm better to do it at home than remotely. Thanks
  13. Hey all, Like the title says I am trying to add a zwave switch to my ISY994. It's running v5.3.1 and I have the zwave module. I had an Insteon on off switch stop working so wanted to replace it with a zwave. I've tried the Enbrighten and the Zooz 700 switch and can't get the ISY to recognize either. I have the same Zooz switch in the same bathroom running some lights by my mirrors so I expected it to not have any issues. I've tried excluding it first and am at a loss of what else to try. So when I click add a zwave device, I get the device discovery window and also a window showing the IoX Finder which is kind of weird I thought. I press on the switch like the instructions say but nothing ever finds my switch. I even tried it using UD Mobile on my phone but also no luck. I've even thought about moving to Eisy but UD shows it out of stock. Any suggestions? Thanks Greg
  14. Z-Wave||Advanced||Z-Wave Version. I was also asking because there is no version on my screen but I think that's because I am only at ISY version 4.8 right now.
  15. Was looking to upgrade my version 4.8 ISY994i and was following the list and it said to make sure your z-wave firmware was at 4.55 but when I look at mine I see this. Did I miss a step when I installed it? Only z-wave device installed in my network is a repeater currently so no big deal whatever I need to do. I got it so I could install a z-wave switch on my water heater since Insteon got rid of theirs but haven't gotten to it yet. Edit: Did some more reading. Could this be because I have a new z-wave module so it's a 500 series but my ISY is only on version 4.8? If so, should I remove the card, do the upgrade, and then install the card?
