timdenike
  1. Hey there, I've been able to create a self-signed cert, but I just tried creating a CSR (so I can sign my own custom self-signed SSL cert) but the SSL tool doesn't seem to work. I choose "Generate Certificate Request to CA", fill out all the fields, 2048, FQDN, etc, then nothing. Known issue? Anyone else have this problem? T
  2. Aha! That's very helpful. I added the following: CatGenie Alert: If $Int_1 is 0 # default value and From 8:00am to 11:59pm (same day) # Time when CatGenie and me sleep. Then: Wait 4 hours # will likely tune this higher Send email # alert me that something's wrong. Added set Int_1 to 1, then a subsequent set Int_1 back to 0 in my CatGenie Run program to abort the previous program. I'll see tomorrow how it goes. Many thanks - this is awesome. It's great to know everything's running smoothly when I'm away - if I get this email, I can have a friend stop by to avert a disaster. Tim
  3. timdenike posted a topic in ISY994
    Hey all, Hoping I could get some thoughts on a funny problem.. I've got a CatGenie automated catbox. It's connected to a Synchrolinc to sense when it's running. Currently the following program sends me an email whenever it runs. CatGenie Trigger: if Control 'CatGenie Sensor' is switched On Then Run Program 'CatGenie Run' CatGenie Run: Then: Disable Program 'CatGenie Trigger' Set 'CatGenie Exhaust Fan' On Send Notification to .... Wait 40 minutes Set 'CatGenie Exhaust Fan' Off Enable Program 'CatGenie Exhaust' This works swell, although the email isn't terribly helpful, aside from knowing my CatGenie is working when I'm away. What I'd LOVE is an email only if the CatGenie hasn't run in 9 hours. (Or better yet, 4 hours, with a gap overnight when the CatGenie doesn't run.) Is this getting too advanced? I figured I'd try to solve this externally, but thought I'd try here first.
  4. Hey all, Been tweaking on a program for a while and not having much luck. I've got a CatGenie litter box connected to a syncrolinc. Above it, I have a window box fan connected to an ApplicanceLinc. My goal: Turn the fan on when the CatGenie starts, and run until about 5 minutes after it finishes. It runs about 35 minutes start to finish, triggering the SyncroLinc several times. Any ideas how to go about this? If Control CatGenie Sensor switched on then Disable Program CatGenie Set CatGenie Fan On Send Notification to 'email' content 'catgenie running' Wait 40 minutes Set CatGenie Fan Off Enable Program CatGenie I've tried several variations of above, but the program seems to just finish instantly. Any sugestions?
  5. Hey there, Apologies for the noob question, but I just got down to setting up my ISY-99i/IR PRO and I'm a bit perplexed by a few issues. I've been using a SmartLinc + EZUIRT for remote and IR control for a few weeks now. a KPL in my bedroom and front-door, with SwitchLincs everywhere else, plus a few LampLincs. I switched to the ISY because I found redefining scenes manually on each KPL/controller a bit tedious. I had imagined that the ISY would start up and be able to download my existing links / scenes and display them on-screen. I assumed I'd see the old address of my (unplugged) Smartlinc and EZUIRT controllers, and I'd be able to remove them from any responders. When setting up the ISY with "Start Linking", I chose "Add Devices Found in Links and Keep Existing Links" - assuming this would leave my (mostly working) configuration intact, and allow me to tweak it. (And went around the house hitting Set on all my devices.) Instead I just got a list of all my devices with no relationships displayed. Over time, I redefined a number of scenes in the ISY, and added them to my KPL, noticing my KPL was still controlling scenes from previous configurations. I even tried deleting and re-adding the KPL with "Remove all links" option, yet the KPL still controls old scenes that aren't defined in the ISY. My fear here is that there are links defined to old IDs (like the Smartlink/EZUIRT) that aren't being exposed in the ISY. Is there a way to get the ISY to display everything the way it currently is? Must I start from scratch and air-gap every switch to wipe any old pairings? Also - how do I properly make a 2-way switch in the ISY? Is it just a scene with the two switches, with the "remote" switch as the controller? Previously, I had cross-linked both of them to the other.
