EISY 6.0.5
I have the same problem with eisy-ui not loading nodes and reporting an "Error: Internal server error." Everything else seems ok.
Writing variable data to a file for long term analysis
I use the Web Server Module to save data to files. https://wiki.universal-devices.com/ISY-994i_Series_INSTEON:Networking#Web_Server_Module I create my own log files if I want to keep track of something or record errors. It's like sending an email but it goes to a file. The file can be viewed in a web browser or you can copy it from eisy to another computer to view in Excel.
Kasa Devices to support
3.2.4 works. I can control the KP125M now. The power nodes populate but the voltage and current are 0. I don't see these in the Kasa app so I assume it doesn't report them. Thank you.
Now it seams to be looking for: 2024-12-22 21:15:15.640 MainThread udi_interface ERROR udi_interface:write: No module named 'async_timeout' I will send a log package.
I installed 3.2.2 in a new slot. Seems to be stuck in a loop with this error: 2024-12-22 16:31:31.319 MainThread udi_interface ERROR udi_interface:write: No module named 'mashumaro' I created a debug log file (maybe) should I attach it here or send another way?
I was trying 3.2.2 but my view is different. I have Activate, not Install. My PG3x is 3.2.27. My installed version is 3.1.4.
@Jimbo.Automates@bmercier I have 3.1.4 installed, which I purchased a while ago. The non-production store shows 3.2.1 and 3.2.2. 3.2.2 is listed as free but when I push the activate button it takes me to the portal and PayPal to buy it for $30. Do I need to install 3.2.1 first since the button is install? From the popup window: You currently do not have a valid license for this version of Kasa. Please click on the purchase button below. NOTE: After completing your purchase return here and click on Install. Purchase takes me to the portal and PayPal.
@Jimbo.Automates I have been traveling so I haven't had a chance to try this. I went to the non-production store to install 3.2.2 and there is an activate button. When I press the button, it wants me to purchase a license. The description says free trial. Am I doing something wrong? Also do I need to do an update of PG3x 3.2.27? IoX is 5.8.4. Can the old and new versions coexist? Thanks for supporting this.
Eisy controlable light bulbs
I have some tp-link Kasa KL125 WiFi bulbs and I use the Kasa plugin to talk to them. I tried the MagicHome plugin but the bulbs I tried didn't work very well.
I'm learning about Insteon linking. Question about status tracking between controllers
I think you need to link the devices by creating a scene with the ISY994. If you link the devices using the paddles on the devices, the ISY994 doesn't know what is linked. I hope I got this correct. I don't know if it's possible to import links.
Unable to "Find/Replace" many programs after migrating from 994i to eisy with Matters+ dongle
I tried searching for programs again. When it does find a program it seems to be a program that's called by another program. It finds the text in a program, not the actual program. Maybe it's not really looking for programs but references to programs. I never used this feature before. When I see something in the forum that I haven't tried before, sometimes I will try it. Learned a lot of things from the forum.
I've never used the Find/Replace on programs before. I just tried it and there appears to be a lot of programs it can't find. This is on eisy v5.8.0.
- 0.9.6x is available
mjrush
Joined
Last visited
