deirwin
Everything posted by deirwin
  1. I responded a few days ago, but apparently did not send... I did perform the z-wave heal, but it didn't help. I moved ISY back to original location, and all thermostats almost instantly showed status. That problem resolved. KPL issues continue. It turns out, we still have 8. 3 make a clicking sound and will do nothing. 3 seem to be working perfectly. 1 only turns on its own light, but other buttons do not perform their function. 1 performs functions for all buttons, but lights do not appear indicating they are on...
  2. I have several issues that I think are related. No longer able to communicate with thermostats (z-wave) I was able to communicate with a few this morning, but not all, and now, none. ISY is located approximately 10 feet from one thermostat. No Keypads work for any purpose other than primary switch - programming and secondary functions no longer work. I have been having keypad issues for long time, but removed all but 5. 4 of the 5 remaining in system had been working fine prior. Three incidents that could have impacted things (that I know of): I moved the ISY to a different part of house. I changed the IP address of ISY 6-8 weeks ago Power outage occurred a few times in last couple of weeks We have automated whole-house generator, but during the last outage, the generator did not start, so we went several hours without power. Typically after a power outage, I have to manually reset the keypads by pulling tab out for 10 seconds. This has not helped this time. I would be grateful for any thoughts on what to do.
  3. Thanks to everyone that created and fine-tuned this! I also added a program to verbally announce the leak through my ELK M1G system. Works perfectly as far as I can see and tested. I assume announcements could be announced through Alexa, Sonos, or Audio System also.
  4. Hi Teken, it would be great to know what you think today of the Water Hero system and if this is a route you would go, or if you would use ELK/ISY approach, or other solution for water detection / auto-shutoff?
  5. Why do i get “Sorry, I couldn’t find a device or group named xx in account” when the item is programmed exactly as understood?
  6. I love the integration, but I'm having several issues/questions. I get a response of “Sorry, I couldn’t find a device or group named xx in account”. Even if she says the device back to me exactly as programmed. "Kitchen Sink" for example. “I’ve found several devices matching that name. Which one did you mean?" I have changed names to some items to overcome, but I am also wondering if scenes impact this? Some scenes seem to work, "Backyard lights" for example, but some do not, "Main Floor" for example, even though I added it through "Add" "Scene" and she says it back to me exactly as programmed. Maybe scenes have to be programmed into a KPL button to work? Is there a syncing process I should go through after I rename Spoken or Alternate Spokens? Thanks! Dean
  7. Thanks Jon, I had two errors: 1) I was trying to do this through Admin Console, rather than the portal URL; 2) ISY needed to reboot to get back online. Now I hope to be able to figure out how to make functional ISY Recipe through IFTTT.
  8. I can't find the set-up section, specifically Select Tool or Connectivity. I imagine its something simple, but have been searching and can't find anything on this... On wiki it says, "On portal, IFTTT configuration is in Select Tool | Connectivity | IFTTT". But I don't see that. I see: Portal Integration UDI "Offline" "Registered" Action Services my username "Registered" a button for "revoke" and "more Info" Requested Services this section is blank/empty Thanks in advance! Dean
  9. For me, it's not really budget driven. Really looking for genuine functionality, ease of use, and self-manageable - I don't want to have a tech come out to tune/update/fine-tune...
  10. Like most of us on this forum, I want to integrate everything that can be automated in the house and use it easily. It's exciting now that Echo is smart enough to handle voice commands and that apps bring together all of the various systems (almost) seamlessly. I want my kids or older parents or babysitter to use system without a learning curve. So I ask, what app do you use to integrate your systems and how well do they work? I'm currently using eKeypad Pro away from home and Simple Control (formerly Roomie Remote) at home. System includes Sonos, ISY994, Insteon, Elk M1G, Trane Z-Wave and Wi-fi Thermostats (AC, baseboard heating, radiant floors), Lorex cameras/DVR, A/V equipment, Xbox, Wii, pool, temp sensors, global cache ethernet/IR adapter, (Echo not yet received.) It's not perfect for sure, but getting closer to seamless than ever. To me: EKeypad works well for straight forward remote access of ISY and ELK. But doesn't integrate everything or attempt to. And Lorex doesn't "play nice" with automation systems/apps. I am the only one in the house that has ever used this app. Simple Control has occasional hiccups, but mostly controls A/V equipment nicely. Easy for everyone to use. Also, because you can include URL's, it can open other apps within their app (at least it feels like it is within), so you can open Sonos or Lorex app... But I can't control the thermostats or see their status from within the remote, like it does with lighting. I can see/control a Nexia thermostat, but not ISY controlled thermostats. IR emitter has been more consistent than ethernet commands. I would recommend it because I'm sure they will overcome the hiccups and don't know of another strong app others are using, and everyone in house can easily control things - usually and the babysitter - kind of... Would really like to know what others are using and if they think it is best/good solution.
  11. I have Simple Control (formerly Roomie Remote), ISY994, Insteon lighting controls, and Z-Wave thermostats. I have been unable to integrate the thermostats with SC. I see them as lighting nodes. I also had issues when first integrating, as it showed duplicates of most items in ISY, as if it was resyncing. There doesn't seem to be a simple way to add an item to a room, like a dimmer ro thermostat. Has anyone had any luck with this? Could you steer me toward direction or solution?
  12. Is there a big issue with Insteon keypads. I have 6 installed in my house right now. 1 makes a clicking noise (and doesn't appear to communicate), one seems dead, another makes a beeping noise (and doesn't appear to communicate), and i have 3 more in a box that did the same. So, 6 out of 9 - seems like a very high percentage. Is anybody else having same experience or know a way to resolve the clicking or beeping? Hopefully it's just me, but maybe there's a bigger issue? FYI, we also have 6 defective dimmers/switches, but we have 70 or so that are working, so under 10%.
  13. deirwin replied to deirwin's topic in ISY994
    Yes, the lights work perfectly with Insteon dimmers simply by using the correct transformer as mentioned above. It was very easy. I recommend to anyone that wants to add something special to a room - they provide nice mood lighting and subtle night lighting - it really takes things to a new level! And by hiding them, they are completely unoffensive light, since they provide a glow. I only went with white, but it seems color would have been just as easy to tie in, but more programming to control color (at least from what i have read). There are a variety of whites though. They are so cheap that we bought a variety of whites and brightnesses to test out. Here is a link to a couple pix of both bathrooms (LED's behind mirrors, in niches and under a vanity). https://goo.gl/photos/aAuRF3w26SCu69of7 And yes, I was able to tie-in the radiant floor with the ISY994. I used Trane Zwave Thermostats by connecting an Aube Electric heating relay (RC840T-120) to each unit, hidden in the wall. Again, very easy and works perfectly. I really only use the thermostat to turn on for an hour or two at a time for the most part because these are bathrooms. The floor warms up very quickly and is very comfortable. It makes me wish we had radiant heating throughout the house. Next one for sure! Overall, I'm very pleased with being able to include the led strips and floor heating thermostats.
  14. Thanks stusviews! I was trying it at around 5 feet, but was seeing errors in my Events viewer. So, I held the ISY right up to the thermostat and it worked! Now I will try to figure out how to include my XL824! :-}
  15. I have 7 Trane TZEMT400BB32 Z-Wave thermostats that I can’t get to communicate with my ISY994. They used to, but while having house renovated last winter, I tried to remove from network and was unable, so I deleted them from ISY. Now I cant get them back. On stats, when I go to Menu>Wave Install, it says “Remove Thermostat from ZWave Network”. But that option never changes. Does anybody have any ideas on how can I get them back? FYI, I also have a Trane XL824 (TCONT824AS52DA), but that was never part of system, because it does not appear to be compatible. But may be causing problems? We also have Elk M1G integrated. Thanks in advance!
  16. Well, I hooked a Z-wave thermostat without using the sensor on one system and non z-wave with sensor on the other. They are both warming up nicely. I will play with them for a little while, but I'm feeling like we would be better off with z-wave, even without sensor. Since they are both in bathrooms, what we really want is a cozy floor under our feet. Maybe programming within a degree or two for on/off once i figure it out.
  17. Teken, thanks again - and wow on your system. It will take a few days to look through it all. I'm just not sure if I should hook up a z-wave thermostat with an aube adaptor and no sensor. Maybe i should just use a standard radiant heat thermostat and wait for technology to advance in that community. it'd be very disappointing to have that one aspect of the house be excluded from my automation system... I'm really surprised that more people are not doing this, or demanding this. Radiant heating is coming on strong and is big in new construction and remodels.
  18. 1. I'm not sure, the power is off because thermostats have not been installed. I believe previously with original thermostat, that it remembered presets. I'm not even sure what would happen now if we used a regular thermostat without the in-floor sensor. Would it turn on forever? Do you know if it simply on/off, or do they have on levels? 2. It has 2 wires. Schluter does not seem to give info on their sensors, but apparently compatible with most, if not all, radiant heating thermostats. 3. Would this be a benefit in this application? Install a sensor (and other necessary hardware), then program the system for thermostat on/off? Thanks again!
  19. Thanks Teken. My goal is simply to access with HI system (Elk/ISY), like all of the other thermostats in the house, and to warm up the floor & shower in advance of going into those rooms. And ability to program with iPad or computer. We would have gone to greater lengths a few weeks ago (and thought we did everything we needed unfortunately), but now the floors are finished. In the floors, we installed the sensors that came with the systems. We ran those wires to the location of the thermostats will be. Now when hoping up, we realize, we don't have a place to tie-in up the sensor. Also, not sure if this helps in this situation, but each room still has telephone lines in the walls in case we ever want/need them (bathrooms used to have telephones in them . It is odd to me that these systems don't offer home automation conveniences, when it feels like they would justify it more than most thermostats, especially since it takes longer to reach temp goals and they are expensive luxury-type systems right now.
  20. If we want z-wave or Insteon, I guess we then ignore the in-floor sensor? So, it will just turn on and stay on until room gets to a certain temp? Or i program to stay on for a certain amount of time? Doesn't seem logical for radiant heat. Have you had luck with this? Any wisdom is welcome.
  21. Thanks Stu, so I just hook this up with whichever smart thermostat I want and I'll be good?
  22. Thanks Teken. I haven't yet bought thermostats. I hope this helps. I have 120v Schluter Ditra Heat System. It has an in-floor sensor. The thermostat they sell for this system: Technical Specifications Supply voltage: 120/208/240 VAC, 50/60 Hz Maximum electrical current with a resistive load: 16 A
3840 W @ 240 VAC 3330 W @ 208 VAC 1920 W @ 120 VAC Temperature Display Range: 0 °C to 35 °C (32 °F to 95 °F) Temperature display resolution: 1 °C (1 °F) Range of the temperature set points: 3 °C to 35 °C (37 °F to 95 °F) Temperature set point increments: 1 °C (1 °F) Storage: -30 °C to 50 °C (-22 °F to 122 °F)
  23. I am having a hard time figuring how to tie-in my electric radiant floor heating into my automation system. I have ISY 994 w/Z-Wave and an ELK M1 Gold system. Has anyone had any luck with this? It seems these systems are cutting edge and would then naturally have z-wave or internet or HA thermostats. Would appreciate any suggestions. Thanks!
  24. deirwin replied to deirwin's topic in ISY994
    Thanks builderb, Banichi and rahnee. We have received the items and tested perfectly and now installing. We ran the wires from Insteon Dimmer (2477D) to the transformer, then to LED strips. We are using same transformer as Banichi mentions above (Hitlights brand version from Amazon). RGB control would be cool, especially since there is such a variety in whites in LED lighting, but we didn't go that route. Will follow-up with finished image(s) when project is ever completed. Now if I could only find a clean solution for my radiant floor heating to work with my ISY/ELK - it would be so nice to have a touchpad thermostat on wall that was also tied in through system...
  25. deirwin posted a topic in ISY994
    I would like to install led strips or lighting that is compatible and dimmable with my Insteon/ISY system. Has anyone had luck with this or suggestions? Thanks! Dean
