brookbphx
Everything posted by brookbphx
  1. How did you determine that it was sourcing vs. sinking vs. source/sink? You can know if it source with a simple voltmeter, but it may also be able to sink. They way I'd test that is by using if you have an external 10v voltage source and resistance and can verify that the 2475da2, can draw current through that resistor and lower the voltage (sink current) when its output voltage is set to a value less the the external voltage source. I am using a 2475da2 now with a Mean Well Ballast and some LED lights, and that has worked fine. So either the Mean Well is a Sinking Ballast or the 2475DA2 has the capability of sinking current as well as sourcing. Someone just responded to my request for this ballast from this forum, and has sold me 3 of them. I'm just waiting for delivery. After I get one, I'll validate if it is source only or if it can both source and sink current. But either way, I expect it will work well for me with the Mean Well ballast I plan on using, since the same setup has worked well in the past. PS: if you don't mind external circuity and your dimmer/controller is a sourcing dimmer that does NOT also have 'sinking' capability, you can likely adapt it so that it will sink using just a few external components (NPN transistor, resistors, etc.). It might not draw down all the way to zero volts at the minimum dim level due to the transistor's Vbe (Voltage from base to emitter - typically around 0.7v), but it should otherwise work.
  2. OK. So after seeing apostolaskisl's response, I did a little research and now I see there are two standards for 0-10v dimming: one where the dimmer controller creates a voltage/current source that drives an input to a dimmer ballast that 'receives' that voltage to adjust how it drives its LED load. The dimmer ballast will also likely have a load resistor that will sink current from that controller source to ground. That is the 'theatrical' standard. And then there's a non-theatrical standard (which I will refer to as a building standard) where the dimmer ballast's input has a 10v reference voltage source with series resistance. The control node's voltage will be at 10v when it is open circuit and no current is being pulled from it. The voltage can be externally pulled down by a dimmer controller that sinks current from it with either variable resistance to ground or by actively driving it to a lower voltage with a current sink driver. i.e., the dimmer controller (e.g. 2475da2) sinks/pulls current from that source and pulls it down towards ground to effectively 'drive' the signal to the desired voltage by sinking current. So, now I see that there are different kinds of 0-10v dimmer controllers, and that they can operate in three possible ways: as a source dimmer controller (theatrical), as a sink dimmer controller (building standard), or as 'either' if it has the ability to source or sink current, thus driving the signal higher or lower in a 'push-pull' method. So my earlier assumption was that the 'theatrical' standard was how things worked. I wasn't aware of the other standard (IEC 60929 Annex E, apparently). But apostolaskisl says (and my reading indicates he's probably right) that most non-theatrical equipment assigns the 'source' functionality to the dimmer ballast and the 'sink' functionality to the controller. I'll probably validate that at the bench next time I get the chance - just to satisfy my curiosity - but for now, I'll trust that apostoaskisl is right. Thanks for clarifying this for me. Note: I tried looking at the 2475da2 and the Mean Well ballast specifications, and to me, those specs really weren't all that clear as to whether each of these devices could act as current source, sink, or source/sink. That would be a nice thing to include in the specs, in my opinion. But since neither of these are designed for 'theatrical' use, they're probably following the controller=sink and ballast=source standard.
  3. Yeah, the Insteon 10v dimmer just has a 0-10v output that is meant to drive the 0-10v input of a dimming ballast, such as for LEDs or fluourescent lights. The Leviton device, from what I understand, is meant to receive the 120v dimmed output signals from a normal triac-based dimmer, and convert those to a 0-10v output which is then suitable for driving the 0-10v input of a dimmable ballast. For some examples of LED dimmable ballasts that work with a 0-10v input, see https://ballastshop.com/brands/mean-well/#?Category0=Brands&Category1=Mean+Well&search_return=all&Customfielddimming=0-10+Analog^Analog+(0-10V) . The Insteon, the Qubino, and the Leviton all create 0-10v outputs, which to me means they 'source' the 0-10v voltage which is then sent to a ballast which receives it (sinks it). The ballast uses the 0-10v input to create the proper dimmed voltage/current needed by the lights being driven (LED or Fluourescent). That being said, if you purchased an Insteon 2475DA2 0-10v dimmer that's still in good condition and you aren't using it, I know someone who might be willing to buy it. Me.
  4. I was looking at that Leviton e300-Dow as another 'alternative' if I couldn't find a 2475DA2. It's certainly something to consider, but its on the lower end of my list of preferences due to cost and due to adding another layer of complexity. Std Triac Insteon Dimmer---> Leviton E300 ---> (10v) ---> 0-10v LED Dimmable Ballast ---> LED assembly However, unless someone has a horror story about it, or if I just can't get it, I'll probably go with the Qubino thing. It's smaller and cheaper. But it's got additional complexity as well, since it doesn't run on 120vac ---->120vacto24vdc PS---->Qubino--\ / \ (0-10v dim signal) 120v --/--------------------------------->LED Dimmable Ballast(0-10v)--->LED Assembly Still hoping someone comes up with an 2475DA2 they have laying around and would be willing to sell.
  5. Hi MrBill Thank you for pointing me to those. Yes, I saw them. I sent a query to the guy to ask if he wanted $250 for five of them or if it was $250 each. The answer was $250 each. Yikes! While I really want one of these, that is just too much for me. So far, I have roughly 50 Insteon devices and perhaps 12 older X10 based devices, and I've been sticking with that for years, avoiding transitioning to Z-wave or Zigbee. But now, I'm starting to think this might be the time to start the transition to Z-wave. I LOVE the built-in 'scene' capabilities of Insteon (and older SmartHome X10 products surprisingly) where switches can be programmed with scenes and you don't have to depend on a controller to implement the scenes. From what I can see, neither Z-wave nor Zigbee support that - or if they do, it is not as easily managed as it is with the ISY. Program your scenes with ISY, and then the ISY is not required in many cases. If the ISY goes down (which has not yet happened to me), the scenes would still work. (Yes I do have some specialty scenes that use ISY programs, but most of my house uses the Insteon built-in scene capability, and the ISY primarily provides 'programming' functionality.) Anyway, if nobody has a spare 2475DA2 they'd be willing to sell for an affordable price within the next week or two, my plan is to add the Z-wave Plus module and use something like a Qubino Z-Wave Plus 0-10 V Dimmer ZMNHVD3 . I'll probably spend $150 on that stuff, including a power supply for the Qubino, but then I'll be ready for additional Z-Wave devices. I'll try to keep the Insteon components where I have lots of scenes. Luckily this LED project doesn't need to be part of any multi-dimmer scenes, so Z-wave should work just fine for that. Still looking for a 2475DA2 if anyone has one at an affordable price, but I have my backup plan as well. Thanks!
  6. I'll apologize in advance if this is against the rules to ask if something is for sale on here. I can't find the posting rules for this forum. But considering how hard it is to get products from Smarthome these days, this forum seems like a potentially good place for folks who need Smarthome products to ask around and see if anyone has spares for sale. I need a 2475DA2 - a 0-10v ballast dimmer for controlling fluourescent or LED dimmable ballasts/drivers. I set up a custom dimmable LED device in the past using one of these, and it worked great. Now I'm trying to create another dimmable LED project. I had it all planned out with lots of components already purchased. Thought I'd just buy me a 2475DA2 to control it. But nope. There aren't any. And it seems doubtful that Smarthome will make them again. So, do any of you HA fans out there have any 'spares' of the 2475DA2 you'd be willing to sell? Thank you much in advance.
  7. Hello Greg, I believe the next version of the ISY firmware will likely resolve this problem. I'd just hold tight a little longer. . . Regards, Brook
  8. So, there may be a fly in the ointment of my 'workaround', listed earlier in this thread. It may work well for some situations, but not for others. Here's my interpretations of what I've heard from Lee and Michel and from what I've been seeing with my 2477SA1. Perhaps Lee or Michel can chime in if they think I've got it wrong. It turns out that when you first link the ISY to the 2477SA1 in i2 mode, it writes link #0, which is very important. Later in the initial linking sequence, a NACK occurs that shouldn't occur. This causes the overall linking process to fail, but that first link is in place, which is good because it's needed later. Later, after you do the i1 restore mentioned in my workaround above, you can put the ISY back in i2 mode and successfully communicate with the 2477SA1, because that first link is in place. You can add the 2477SA1 to scenes, and update the links in i2 mode. This will often work out well. However, if you add the 2477SA1 to some other scenes, and the ISY decides to rearrange the links in the link list, you may be in trouble. Apparently Link #0 cannot be re-written without removing the 2477SA1 from the ISY and re-linking it. So as long as your ISY scenes always leave the link #0 intact in the first link position, you're OK. But if it moves that link to another position in the list, you are in trouble. When Link #0 is created when you first link a 2477SA1 to an ISY, the ISY's PLM will always be the first link. You can verify this by looking at your Device Links before adding the device to any scenes. But as you add the 2477SA1 to other scenes, the ISY apparently may choose to rearrange the order links. I'm not sure why. If order isn't important, perhaps they can change the code so that link #0 never moves. Anyway, attached is a screen shot of my ISY and Device links for my 2477SA1. This is from after adding the 2477SA1 to a couple of scenes on a Keypadlinc. My ISY's PLM is 13.21.82, while the Keypadlinc is 1C,8B.20. Notice how link #0 on the left is linking the 2477SA1 to the Keypadlinc (1C.8B.20). However, over on the right side there is a record mismatch in that first position. Link #0 on the right shows a link to the ISY's PLM (13.21.82). That is the original link that was created when the 2477SA1 was first linked to the ISY. You can see the same line at link #3. The ISY apparently rearranged the links and moved what was originally at Link #0 to Link #3. But the 2477SA1 wouldn't overwrite the old Link #0 with the new Link #0 for 1C.8B.20. So control was lost, and I now get errors when trying to communicate with the 2477SA1. . . . It seems to me that if linking Insteon controllers to the 2477SA1 were this problematic in general, Smarthome would never get away with a bug like this. It does seem to be a bug, but perhaps the Smarthome folks know a workaround in the way they do the linking to THEIR controllers that avoids this bug. And perhaps the ISY guys aren't privy to the SmartHome workaround. I'm sure what ISY is doing *SHOULD* work if the 2477SA1 bug wasn't there, but a few of us have found that it doesn't. I'm wondering if it might be worthwhile for the ISY folks to 'reverse engineer' what the SmartHome controllers (such as a SmartLinc or HouseLinc) do when they link to a 2477SA1. Perhaps doing things in a different order or responding to ACKs and NAKs in a different way might provide a software workaround to the problem. I'm hoping for the best, but at this point, I'm thinking about returning all of the 2477SA1s, or possibly using them in X10 mode. I was trying to get away from that. But I've only got a couple of weeks left to return them before I get stuck with them. Any thoughts or comments appreciated! ---- PS: after 'previewing' the above before clicking "Submit", I saw that Michel had responded to my previous post before I could get this one out. Apparently he was using his sixth sense to hear what I was asking about. Cool! So I'll wait until next Friday to try out the 'workaround' he's come up with. Thanks Lee and Michel!
  9. Remove power by pulling set button. Wait 10 seconds or so. Push button back in and hold until switch beeps. Hold another couple of seconds and release. The load turns on full bright. I haven't gone in and queried the links after doing so. Perhaps I should do that to make sure they're being wiped out. Thanks!
  10. Any chance you or Michel could get SmartHome to review these findings and fix it? Alternatively, can you recommend a Smarthome technical contact I can talk to get them to do something to fix this? And do you think there's any chance Smarthome will swap out my 'bad' 2477SA1 at no cost in a few months after they've fixed the firmware bug, while letting me keep the bad 2477SA1 now? Even though I've figured out a workaround, I'd really rather have a unit without the bug in it. Same goes for those 2486D units I've been talking about in another thread if they turn out to have a bug as well. Note: I'm going to go ahead and send back the second 2477SA1 I got, which is the one that was used for the above troubleshooting. I got it to replace the 'bad' first unit, but it was just as 'bad' as the first unit. Thanks!
  11. Thanks Lee, You may recall way back in this thread that I said that I originally got the KPL to work correctly for my scene (Not the test scene as requested by Michel, but the original working scene needed for this house). The buttons would all turn on the load as intended. There were two other Switchlincs on each scene, for a total of 3 responders. I had not yet added in the other KPL buttons as responders to each scene, so all the buttons would stay lit. But at least the load could be controlled. I think there were 38 total links on the KPL after setting it that way. Next, I did add each of the other KPL buttons as responders to each scene so that I could get them to turn off when I pressed a Scene button. That's when things broke for that KPL, and I've never been able to get them working again. There were 63 device links in that case. My theory is that the KPL will work OK until you've either got too many links or until you set other KPL buttons as responders to a KPL controller button. Given that SmartHome was trying to resolve an issue with turning off all buttons except the pressed button om mutually exclusive scene buttons with multiple separate controllers, I wouldn't be too surprised if they accidentally sneaked in a bug to turn off the load as well as the other buttons. In this quest to get these KPLs working, I've now got 3 KPLs that won't control the load to any ON level from buttons B-H. No amount of factory resetting, removing from ISY and readding, or even creating completely new scenes to add it to helps. I've got one more brand new KPL in a box, but I hesitate to 'load it up' and break it like I've now broken 3 others. Thanks!
  12. Continued from above post STEP 9 - Make a Scene and add a Controller - Create a scene, and add the 2477SA1 device and a controller to that scene. That will create additional links for the 2477SA1, and will overwrite the bad link. It seems that its OK to add links in i2 mode. The only thing required for i1 mode is Restoring and re-writing the program for the whole device. In my case, I had a scene with 7 controllers on a single keypadlinc, and I added the 2477SA1 to that scene. I then set the device to "OFF" for buttons B, D, F, and H, and left it at "ON" for C, E, and G. I didn't have "Automatically Write Changes" turned on when I made these edits to the scene. I turned that on after making all the edits so that it would update the device. Below is the log of me doing these things: Sun 09/23/2012 04:01:04 PM : [1A.C7.55.1] Start : Adding to scene '00 Test Scene 2' Sun 09/23/2012 04:01:04 PM : [1A.C7.55.1] Making '00 Test Scene 2' a Controller Sun 09/23/2012 04:01:04 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1A C7 55 09 0A 41 06 Sun 09/23/2012 04:01:04 PM : [1A.C7.55.1] Making '1C.8E.6E.B' a Controller Sun 09/23/2012 04:01:04 PM : [1A.C7.55.1] Making '1C.8E.6E.C' a Controller Sun 09/23/2012 04:01:05 PM : [1A.C7.55.1] Making '1C.8E.6E.D' a Controller Sun 09/23/2012 04:01:05 PM : [1A.C7.55.1] Making '1C.8E.6E.E' a Controller Sun 09/23/2012 04:01:05 PM : [1A.C7.55.1] Making '1C.8E.6E.F' a Controller Sun 09/23/2012 04:01:05 PM : [1A.C7.55.1] Making '1C.8E.6E.G' a Controller Sun 09/23/2012 04:01:05 PM : [1A.C7.55.1] Making '1C.8E.6E.H' a Controller Sun 09/23/2012 04:01:05 PM : [1A.C7.55.1] Finish : Adding to scene '00 Test Scene 2' was Successful Sun 09/23/2012 04:01:35 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 13 00 Sun 09/23/2012 04:01:35 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 13 00 06 LTOFFRR(00) Sun 09/23/2012 04:01:35 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 13 00 06 LTOFFRR(00): Duplicate or ACK for a different device Sun 09/23/2012 04:01:36 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 13 00 LTOFFRR(00) Sun 09/23/2012 04:01:36 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:01:41 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 13 00 Sun 09/23/2012 04:01:41 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 13 00 06 LTOFFRR(00) Sun 09/23/2012 04:01:41 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 13 00 06 LTOFFRR(00): Duplicate or ACK for a different device Sun 09/23/2012 04:01:41 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 13 00 LTOFFRR(00) Sun 09/23/2012 04:01:41 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:01:45 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 13 00 Sun 09/23/2012 04:01:45 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 13 00 06 LTOFFRR(00) Sun 09/23/2012 04:01:45 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 13 00 06 LTOFFRR(00): Duplicate or ACK for a different device Sun 09/23/2012 04:01:45 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 13 00 LTOFFRR(00) Sun 09/23/2012 04:01:45 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:01:49 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 13 00 Sun 09/23/2012 04:01:49 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 13 00 06 LTOFFRR(00) Sun 09/23/2012 04:01:49 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 13 00 06 LTOFFRR(00): Duplicate or ACK for a different device Sun 09/23/2012 04:01:49 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 13 00 LTOFFRR(00) Sun 09/23/2012 04:01:49 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:01:49 PM : [iNST-DUP ] Previous message ignored. Sun 09/23/2012 04:02:23 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 Sun 09/23/2012 04:02:23 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06 (00) Sun 09/23/2012 04:02:24 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:02:24 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:02:24 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F FF 20 E2 01 13 21 82 FF 1F 01 E9 Sun 09/23/2012 04:02:24 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:02:24 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 02 0F F7 08 A2 47 13 21 82 FF 1F 01 03 Sun 09/23/2012 04:02:24 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 02 0F F7 08 A2 47 13 21 82 FF 1F 01 03 06 (00) Sun 09/23/2012 04:02:25 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:02:25 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:02:25 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1A C7 55 09 0A 41 15 Sun 09/23/2012 04:02:25 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 02 0F EF 08 A2 02 1C 8E 6E 00 1F 01 ED Sun 09/23/2012 04:02:25 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 02 0F EF 08 A2 02 1C 8E 6E 00 1F 01 ED 06 (00) Sun 09/23/2012 04:02:26 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:02:26 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:02:26 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 02 0F E7 08 A2 03 1C 8E 6E FF 1F 01 F5 Sun 09/23/2012 04:02:26 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 02 0F E7 08 A2 03 1C 8E 6E FF 1F 01 F5 06 (00) Sun 09/23/2012 04:02:26 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 2F 00 (00) Sun 09/23/2012 04:02:26 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 04:02:26 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 02 0F DF 08 A2 04 1C 8E 6E 00 1F 01 FB Sun 09/23/2012 04:02:26 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 02 0F DF 08 A2 04 1C 8E 6E 00 1F 01 FB 06 (00) Sun 09/23/2012 04:02:26 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:02:26 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:02:26 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 02 0F D7 08 A2 05 1C 8E 6E FF 1F 01 03 Sun 09/23/2012 04:02:27 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 02 0F D7 08 A2 05 1C 8E 6E FF 1F 01 03 06 (00) Sun 09/23/2012 04:02:27 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:02:27 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:02:27 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 02 0F CF 08 A2 06 1C 8E 6E 00 1F 01 09 Sun 09/23/2012 04:02:28 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:02:28 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:02:37 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 02 0F CF 08 A2 06 1C 8E 6E 00 1F 01 09 Sun 09/23/2012 04:02:37 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 02 0F CF 08 A2 06 1C 8E 6E 00 1F 01 09 06 (00) Sun 09/23/2012 04:02:37 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:02:37 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:02:37 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 02 0F C7 08 A2 07 1C 8E 6E FF 1F 01 11 Sun 09/23/2012 04:02:37 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 02 0F C7 08 A2 07 1C 8E 6E FF 1F 01 11 06 (00) Sun 09/23/2012 04:02:38 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:02:38 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:02:38 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 02 0F BF 08 A2 08 1C 8E 6E 00 1F 01 17 Sun 09/23/2012 04:02:38 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 02 0F BF 08 A2 08 1C 8E 6E 00 1F 01 17 06 (00) Sun 09/23/2012 04:02:39 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:02:39 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:02:39 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 02 0F B7 08 00 00 00 00 00 00 00 00 01 Sun 09/23/2012 04:02:39 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 02 0F B7 08 00 00 00 00 00 00 00 00 01 06 (00) Sun 09/23/2012 04:02:39 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:02:39 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:02:39 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F AF 01 00 00 00 00 00 00 00 00 12 Sun 09/23/2012 04:02:39 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F AF 01 00 00 00 00 00 00 00 00 12 06 (00) Sun 09/23/2012 04:02:40 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:02:40 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:02:40 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 2F 00 (00) Sun 09/23/2012 04:02:40 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 04:02:40 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F AF 20 00 00 00 00 00 00 00 00 F1 Sun 09/23/2012 04:02:40 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:02:40 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F AF 01 00 00 00 00 00 00 00 00 12 Sun 09/23/2012 04:02:40 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F AF 01 00 00 00 00 00 00 00 00 12 06 (00) Sun 09/23/2012 04:02:41 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:02:41 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:02:41 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F AF 20 00 00 00 00 00 00 00 00 F1 Sun 09/23/2012 04:02:41 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:02:41 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 02 0F AF 08 00 00 00 00 00 00 00 00 09 Sun 09/23/2012 04:02:41 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 02 0F AF 08 00 00 00 00 00 00 00 00 09 06 (00) Sun 09/23/2012 04:02:42 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:02:42 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:02:42 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 77 08 E2 02 1A C7 55 FF 1F 02 07 Sun 09/23/2012 04:02:42 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 77 08 E2 02 1A C7 55 FF 1F 02 07 06 (00) Sun 09/23/2012 04:02:43 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 04:02:43 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 04:02:43 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 6F 08 E2 03 1A C7 55 FF 1F 03 0D Sun 09/23/2012 04:02:43 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 6F 08 E2 03 1A C7 55 FF 1F 03 0D 06 (00) Sun 09/23/2012 04:02:43 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 04:02:43 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 04:02:43 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 67 08 E2 04 1A C7 55 FF 1F 04 13 Sun 09/23/2012 04:02:43 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 67 08 E2 04 1A C7 55 FF 1F 04 13 06 (00) Sun 09/23/2012 04:02:44 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 04:02:44 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 04:02:44 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 5F 08 E2 05 1A C7 55 FF 1F 05 19 Sun 09/23/2012 04:02:44 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 5F 08 E2 05 1A C7 55 FF 1F 05 19 06 (00) Sun 09/23/2012 04:02:45 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 04:02:45 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 04:02:45 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 57 08 E2 06 1A C7 55 FF 1F 06 1F Sun 09/23/2012 04:02:45 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 57 08 E2 06 1A C7 55 FF 1F 06 1F 06 (00) Sun 09/23/2012 04:02:45 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 04:02:45 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 04:02:45 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 4F 08 E2 07 1A C7 55 FF 1F 07 25 Sun 09/23/2012 04:02:46 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 4F 08 E2 07 1A C7 55 FF 1F 07 25 06 (00) Sun 09/23/2012 04:02:46 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 04:02:46 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 04:02:46 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 47 08 E2 08 1A C7 55 FF 1F 08 2B Sun 09/23/2012 04:02:46 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 47 08 E2 08 1A C7 55 FF 1F 08 2B 06 (00) Sun 09/23/2012 04:02:47 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 04:02:47 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 STEP 10 - Query Links again for Inspection - To make sure the 'bad link' is gone, perform another "Query Device Links" as was done in Step 7. Right click on the device and selecting Diagnostics -> Show Device Link Table. The ISY will query the device in i2 mode, and get back the list of links that have been programmed. Then, to see how well the links match what the ISY thinks they should be, click on 'Compare' at the bottom of the links table that popped up. At this point, you should show additional links, and if it works the way it did for me, they should all be valid links (indicated as "Identical"). Below is the screen shot of my link table, followed by the Event Log for gathering those links: Sun 09/23/2012 04:03:56 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 C2 Sun 09/23/2012 04:03:56 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 C2 06 (00) Sun 09/23/2012 04:03:56 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:03:56 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:03:57 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F FF 20 E2 01 13 21 82 FF 1F 01 E9 Sun 09/23/2012 04:03:57 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:03:57 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F F7 01 00 00 00 00 00 00 00 00 CA Sun 09/23/2012 04:03:57 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F F7 01 00 00 00 00 00 00 00 00 CA 06 (00) Sun 09/23/2012 04:03:57 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:03:57 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:03:58 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 2F 00 (00) Sun 09/23/2012 04:03:58 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 04:03:58 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F F7 20 A2 47 13 21 82 FF 1F 01 EB Sun 09/23/2012 04:03:58 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:03:58 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 Sun 09/23/2012 04:03:58 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 06 (00) Sun 09/23/2012 04:03:59 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:03:59 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:03:59 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F EF 20 A2 02 1C 8E 6E 00 1F 01 D5 Sun 09/23/2012 04:03:59 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:03:59 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F E7 01 00 00 00 00 00 00 00 00 DA Sun 09/23/2012 04:03:59 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F E7 01 00 00 00 00 00 00 00 00 DA 06 (00) Sun 09/23/2012 04:04:00 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:04:00 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:04:00 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F E7 20 A2 03 1C 8E 6E FF 1F 01 DD Sun 09/23/2012 04:04:00 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:04:00 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F DF 01 00 00 00 00 00 00 00 00 E2 Sun 09/23/2012 04:04:00 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F DF 01 00 00 00 00 00 00 00 00 E2 06 (00) Sun 09/23/2012 04:04:01 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:04:01 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:04:01 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F DF 20 A2 04 1C 8E 6E 00 1F 01 E3 Sun 09/23/2012 04:04:01 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:04:01 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F D7 01 00 00 00 00 00 00 00 00 EA Sun 09/23/2012 04:04:01 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F D7 01 00 00 00 00 00 00 00 00 EA 06 (00) Sun 09/23/2012 04:04:02 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:04:02 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:04:02 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F D7 20 A2 05 1C 8E 6E FF 1F 01 EB Sun 09/23/2012 04:04:02 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:04:02 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F CF 01 00 00 00 00 00 00 00 00 F2 Sun 09/23/2012 04:04:02 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F CF 01 00 00 00 00 00 00 00 00 F2 06 (00) Sun 09/23/2012 04:04:03 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:04:03 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:04:03 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F CF 20 A2 06 1C 8E 6E 00 1F 01 F1 Sun 09/23/2012 04:04:03 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:04:03 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F C7 01 00 00 00 00 00 00 00 00 FA Sun 09/23/2012 04:04:03 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F C7 01 00 00 00 00 00 00 00 00 FA 06 (00) Sun 09/23/2012 04:04:04 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:04:04 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:04:04 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F C7 20 A2 07 1C 8E 6E FF 1F 01 F9 Sun 09/23/2012 04:04:04 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:04:04 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F BF 01 00 00 00 00 00 00 00 00 02 Sun 09/23/2012 04:04:04 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F BF 01 00 00 00 00 00 00 00 00 02 06 (00) Sun 09/23/2012 04:04:05 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:04:05 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:04:05 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F BF 20 A2 08 1C 8E 6E 00 1F 01 FF Sun 09/23/2012 04:04:05 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:04:05 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F B7 01 00 00 00 00 00 00 00 00 0A Sun 09/23/2012 04:04:05 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F B7 01 00 00 00 00 00 00 00 00 0A 06 (00) Sun 09/23/2012 04:04:06 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 04:04:06 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:04:06 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F B7 20 00 00 00 00 00 00 00 00 E9 Sun 09/23/2012 04:04:06 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 If you don't see any link errors, your device should now be in 100% working order. STEP 11 - Test it - At this point, I tried controlling the device from the ISY and from the Controller I had linked it to. Below is an Event View log for On/Off from the ISY: Sun 09/23/2012 04:05:39 PM : [ Time] 16:05:53 0(0) Sun 09/23/2012 04:05:41 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 11 FF Sun 09/23/2012 04:05:41 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 11 FF 06 LTONRR (FF) Sun 09/23/2012 04:05:41 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 11 FF 06 LTONRR (FF): Duplicate or ACK for a different device Sun 09/23/2012 04:05:41 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 11 FF LTONRR (FF) Sun 09/23/2012 04:05:41 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:05:41 PM : [ 1A C7 55 1] ST 255 Sun 09/23/2012 04:05:46 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 13 00 Sun 09/23/2012 04:05:46 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 13 00 06 LTOFFRR(00) Sun 09/23/2012 04:05:46 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 13 00 06 LTOFFRR(00): Duplicate or ACK for a different device Sun 09/23/2012 04:05:47 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 13 00 LTOFFRR(00) Sun 09/23/2012 04:05:47 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 04:05:47 PM : [ 1A C7 55 1] ST 0 And next is an On/Off from the KeypadLinc, using "C" for ON and "D" for OFF. Some of the log lines are for other KeypadLinc buttons that were turned off when the "C" and "D" buttons were pressed. Sun 09/23/2012 04:06:42 PM : [iNST-SRX ] 02 50 1C.8E.6E 00.00.03 C7 11 00 LTONRR (00) Sun 09/23/2012 04:06:42 PM : [standard-Group][1C.8E.6E-->Group=3] Max Hops=3, Hops Left=1 Sun 09/23/2012 04:06:42 PM : [ 1C 8E 6E 3] DON 0 Sun 09/23/2012 04:06:42 PM : [ 1A C7 55 1] ST 255 Sun 09/23/2012 04:06:42 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 41 11 03 LTONRR (03) Sun 09/23/2012 04:06:42 PM : [standard-Cleanup][1C.8E.6E-->ISY/PLM Group=3] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:06:42 PM : [iNST-DUP ] Previous message ignored. Sun 09/23/2012 04:06:48 PM : [iNST-SRX ] 02 50 1C.8E.6E 00.00.04 C7 11 00 LTONRR (00) Sun 09/23/2012 04:06:48 PM : [standard-Group][1C.8E.6E-->Group=4] Max Hops=3, Hops Left=1 Sun 09/23/2012 04:06:48 PM : [ 1C 8E 6E 4] DON 0 Sun 09/23/2012 04:06:48 PM : [ 1C 8E 6E 1] ST 165 Sun 09/23/2012 04:06:48 PM : [ 1C 8E 6E 3] ST 0 Sun 09/23/2012 04:06:48 PM : [ 1C 8E 6E 4] ST 255 Sun 09/23/2012 04:06:48 PM : [ 1A C7 55 1] ST 0 Sun 09/23/2012 04:06:48 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 41 11 04 LTONRR (04) Sun 09/23/2012 04:06:48 PM : [standard-Cleanup][1C.8E.6E-->ISY/PLM Group=4] Max Hops=1, Hops Left=0 Sun 09/23/2012 04:06:48 PM : [iNST-DUP ] Previous message ignored. And there you have it. That's what worked for me. Hopefully it will for you. And hopefully it will also provide developers with a clear log of what is going on so they can potentially come up with a fix and/or an easier workaround for this problem.
  13. Technical Details - and steps to get around this problem if you find yourself with the same problem Based on all of Lee's and Michel's great comments, I've learned some things. There are still some things I don't know about WHY things don't work right. But I have got a workaround figured out, and I would expect it would work for others. STEP 1) Factory Reset - Start out by factory resetting the 2477SA1. One thing I figured out is that factory reset for the latest versions of the 2477SA1 do NOT match what is in the manual. The manual says: However, on my 2477SA1, you've got to replace Step 5 with: Continue to hold down the Set button until the unit quits beeping. This could be 10 seconds or more. STEP 2 - Set for Automatic i2 Insteon messaging - In the ISY console, the Insteon command set can be set to either "Automatic", "Device Reported", or "i1 Only". See Link Management -> Advanced Options. Set it to Automatic or Device Reported for this set, and be sure to put it back to this setting when all is done. STEP 3 - Program normally in i2 mode - Add the device as you would any other device using the New Insteon Device or Start Linking options. You may want to have the Event Viewer up at Level 3 to watch what happens (and compare to the log below). If your 2477SA1 has the same problem as mine, this effort will fail. The Event Log will show "NACK" errors (Negative acknowledgement) towards the end. However, good things have been happening anyway. The commands sent have been programming a valid link into the 2477SA1 so that it can communicate with the ISY. It just won't communicate yet, because of the NACK error. A failure to communicate popup will pop up, and then the device will have a big red exclamation point next to it. The device won't communicate. The log below shows the event viewer log from when I did this. Sun 09/23/2012 03:53:02 PM : [1a c7 55 ] Added to list of devices to link to ISY Sun 09/23/2012 03:53:02 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 0D 00 Sun 09/23/2012 03:53:02 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 0D 00 06 (00) Sun 09/23/2012 03:53:03 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 AB 0D FF (FF) Sun 09/23/2012 03:53:03 PM : [standard-Direct Nack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:03 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 Sun 09/23/2012 03:53:03 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01) Sun 09/23/2012 03:53:03 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 09 01 LNK-ON (01) Sun 09/23/2012 03:53:03 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:03 PM : [LNK-BGN ] 02 64 01 00 06 Sun 09/23/2012 03:53:04 PM : [LNK-STAT ] 02 53 M(01) gid=00 1A.C7.55 090A 41 Sun 09/23/2012 03:53:04 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 0D 00 Sun 09/23/2012 03:53:04 PM : [LNK-END ] 02 65 06 Sun 09/23/2012 03:53:04 PM : [std MH ] Unexpected Ack imCmd=65 cmd1= 0x55 Sun 09/23/2012 03:53:05 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 0D 00 06 (00) Sun 09/23/2012 03:53:05 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 0D 02 (02) Sun 09/23/2012 03:53:05 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:09 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 0D 00 Sun 09/23/2012 03:53:09 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 0D 00 06 (00) Sun 09/23/2012 03:53:10 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 0D 02 (02) Sun 09/23/2012 03:53:10 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:10 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 10 00 Sun 09/23/2012 03:53:10 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 10 00 06 ID-REQ (00) Sun 09/23/2012 03:53:10 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 10 00 ID-REQ (00) Sun 09/23/2012 03:53:10 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:10 PM : [iNST-SRX ] 02 50 1A.C7.55 09.0A.41 8B 01 00 (00) Sun 09/23/2012 03:53:10 PM : [standard-Broadcast][1A.C7.55-->09.0A.41] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:10 PM : [1A C7 55 0 ] Calibrating engine version Sun 09/23/2012 03:53:10 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 Sun 09/23/2012 03:53:10 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06 (00) Sun 09/23/2012 03:53:11 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 03:53:11 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:11 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F FF 00 A2 00 13 21 82 00 00 00 69 Sun 09/23/2012 03:53:11 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 03:53:11 PM : [1A C7 55 0 ] Using Database Link Table offset 0x0FF8 (reported 0x0FF8) Sun 09/23/2012 03:53:11 PM : [1A C7 55 1 ] Start : Adding device to ISY Sun 09/23/2012 03:53:11 PM : [1A C7 55 1 ] Finish : Adding device to ISY was Successful Sun 09/23/2012 03:53:11 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1 Sun 09/23/2012 03:53:11 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1 06 (00) Sun 09/23/2012 03:53:12 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2E 00 (00) Sun 09/23/2012 03:53:12 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:12 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2E 00 01 01 0F FF 20 00 1C FE 21 82 00 00 00 69 Sun 09/23/2012 03:53:12 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 03:53:12 PM : [ 1A C7 55 1] OL 255 Sun 09/23/2012 03:53:12 PM : [ 1A C7 55 1] RR 28 Sun 09/23/2012 03:53:12 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 19 00 Sun 09/23/2012 03:53:12 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 19 00 06 LTSREQ (LIGHT) Sun 09/23/2012 03:53:13 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 01 00 (00) Sun 09/23/2012 03:53:13 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:13 PM : [ 1A C7 55 1] ST 0 Sun 09/23/2012 03:53:13 PM : [1A C7 55 0 ] Successfully added device Sun 09/23/2012 03:53:13 PM : [1a c7 55 ] Added to list of devices to link to ISY Sun 09/23/2012 03:53:13 PM : [1A.C7.55 00] Device already added, ignored Sun 09/23/2012 03:53:13 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 02 0F FF 08 E2 01 13 21 82 FF 1F 01 01 Sun 09/23/2012 03:53:13 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 02 0F FF 08 E2 01 13 21 82 FF 1F 01 01 06 (00) Sun 09/23/2012 03:53:14 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 03:53:14 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:14 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1A C7 55 09 0A 41 15 Sun 09/23/2012 03:53:14 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 02 0F F7 08 00 00 00 00 00 00 00 00 C1 Sun 09/23/2012 03:53:14 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 02 0F F7 08 00 00 00 00 00 00 00 00 C1 06 (00) Sun 09/23/2012 03:53:15 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 AB 2F FF (FF) Sun 09/23/2012 03:53:15 PM : [standard-Direct Nack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:15 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 Sun 09/23/2012 03:53:15 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 06 (00) Sun 09/23/2012 03:53:15 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 AB 2F FF (FF) Sun 09/23/2012 03:53:15 PM : [standard-Direct Nack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:24 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 Sun 09/23/2012 03:53:24 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 06 (00) Sun 09/23/2012 03:53:25 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 AB 2F FF (FF) Sun 09/23/2012 03:53:25 PM : [standard-Direct Nack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:34 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 Sun 09/23/2012 03:53:34 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 06 (00) Sun 09/23/2012 03:53:34 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 AB 2F FF (FF) Sun 09/23/2012 03:53:34 PM : [standard-Direct Nack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:53:38 PM : [ 1A C7 55 1] ERR 1 STEP 4 - Set Insteon Signaling to i1 Mode - Set Link Management -> Advanced Options to i1 Only mode. You will get a warning. This warning sounds scary, but as long as you set this option back to Automatic or Device Reported later on, you'll be OK. STEP 5 - Restore 2477SA1 programming in i1 Mode - Right-click on the device and select "Restore Device". Then right-click on the device and select "Write Updates to Device". Event Viewer, if its up, should show a lot of commands being sent to the device. Most of them are i1 commands, but for some reason, there are some i2cs commands mixed in as well. You may even see a NAK or two. But in most cases this will work, and the big red exclamation point should go away. If it doesn't, try again. Below is a log showing this programming on mine: Sun 09/23/2012 03:54:37 PM : [ 1A C7 55 1] Preparing Device '1A.C7.55.1' for Restore Sun 09/23/2012 03:54:37 PM : [ 1A C7 55 1] Device '1A.C7.55.1' ready for Full Restore Sun 09/23/2012 03:54:44 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 0D 00 Sun 09/23/2012 03:54:44 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 0D 00 06 (00) Sun 09/23/2012 03:54:45 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 AB 0D FF (FF) Sun 09/23/2012 03:54:45 PM : [standard-Direct Nack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:45 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 Sun 09/23/2012 03:54:45 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01) Sun 09/23/2012 03:54:45 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 09 01 LNK-ON (01) Sun 09/23/2012 03:54:45 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:45 PM : [LNK-BGN ] 02 64 01 00 06 Sun 09/23/2012 03:54:46 PM : [LNK-STAT ] 02 53 M(01) gid=00 1A.C7.55 090A 41 Sun 09/23/2012 03:54:46 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 0D 00 Sun 09/23/2012 03:54:46 PM : [LNK-END ] 02 65 06 Sun 09/23/2012 03:54:46 PM : [std MH ] Unexpected Ack imCmd=65 cmd1= 0x55 Sun 09/23/2012 03:54:47 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 0D 00 06 (00) Sun 09/23/2012 03:54:47 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 0D 02 (02) Sun 09/23/2012 03:54:47 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:51 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 0D 00 Sun 09/23/2012 03:54:51 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 0D 00 06 (00) Sun 09/23/2012 03:54:51 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 0D 02 (02) Sun 09/23/2012 03:54:51 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:51 PM : [1A C7 55 0 ] Calibrating engine version Sun 09/23/2012 03:54:51 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 Sun 09/23/2012 03:54:52 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06 (00) Sun 09/23/2012 03:54:52 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 03:54:52 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:52 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F FF 20 E2 01 13 21 82 FF 1F 01 E9 Sun 09/23/2012 03:54:52 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 03:54:52 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:54:52 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:54:53 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:54:53 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:53 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B F8 Sun 09/23/2012 03:54:53 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B F8 06 PEEK (F8) Sun 09/23/2012 03:54:53 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B F8 PEEK (F8) Sun 09/23/2012 03:54:53 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:53 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 E2 Sun 09/23/2012 03:54:53 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 E2 06 POKE (E2) Sun 09/23/2012 03:54:54 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 E2 POKE (E2) Sun 09/23/2012 03:54:54 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:54 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B F9 Sun 09/23/2012 03:54:54 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B F9 06 PEEK (F9) Sun 09/23/2012 03:54:54 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 29 E2 POKE (E2) Sun 09/23/2012 03:54:54 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 03:54:54 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B F9 PEEK (F9) Sun 09/23/2012 03:54:54 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:54 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 01 Sun 09/23/2012 03:54:54 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 01 06 POKE (01) Sun 09/23/2012 03:54:55 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 01 POKE (01) Sun 09/23/2012 03:54:55 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:55 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B FA Sun 09/23/2012 03:54:55 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B FA 06 PEEK (FA) Sun 09/23/2012 03:54:55 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B FA PEEK (FA) Sun 09/23/2012 03:54:55 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:55 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 13 Sun 09/23/2012 03:54:55 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 13 06 POKE (13) Sun 09/23/2012 03:54:56 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 13 POKE (13) Sun 09/23/2012 03:54:56 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:56 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B FB Sun 09/23/2012 03:54:56 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B FB 06 PEEK (FB) Sun 09/23/2012 03:54:56 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B FB PEEK (FB) Sun 09/23/2012 03:54:56 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:56 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 21 Sun 09/23/2012 03:54:56 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 21 06 POKE (21) Sun 09/23/2012 03:54:57 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 21 POKE (21) Sun 09/23/2012 03:54:57 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:57 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B FC Sun 09/23/2012 03:54:57 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B FC 06 PEEK (FC) Sun 09/23/2012 03:54:57 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B FC PEEK (FC) Sun 09/23/2012 03:54:57 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:57 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 82 Sun 09/23/2012 03:54:57 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 82 06 POKE (82) Sun 09/23/2012 03:54:58 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 82 POKE (82) Sun 09/23/2012 03:54:58 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:58 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B FD Sun 09/23/2012 03:54:58 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B FD 06 PEEK (FD) Sun 09/23/2012 03:54:58 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B FD PEEK (FD) Sun 09/23/2012 03:54:58 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:58 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 FF Sun 09/23/2012 03:54:58 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 FF 06 POKE (FF) Sun 09/23/2012 03:54:59 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 FF POKE (FF) Sun 09/23/2012 03:54:59 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:59 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B FE Sun 09/23/2012 03:54:59 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B FE 06 PEEK (FE) Sun 09/23/2012 03:54:59 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B FE PEEK (FE) Sun 09/23/2012 03:54:59 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:54:59 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 1F Sun 09/23/2012 03:54:59 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 2B FE PEEK (FE) Sun 09/23/2012 03:54:59 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 03:54:59 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 1F 06 POKE (1F) Sun 09/23/2012 03:54:59 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 2B FE PEEK (FE) Sun 09/23/2012 03:54:59 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 03:54:59 PM : [iNST-DUP ] Previous message ignored. Sun 09/23/2012 03:55:00 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 1F POKE (1F) Sun 09/23/2012 03:55:00 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:00 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B FF Sun 09/23/2012 03:55:00 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B FF 06 PEEK (FF) Sun 09/23/2012 03:55:00 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B FF PEEK (FF) Sun 09/23/2012 03:55:00 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:00 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 01 Sun 09/23/2012 03:55:00 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 2B FF PEEK (FF) Sun 09/23/2012 03:55:00 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 03:55:00 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 01 06 POKE (01) Sun 09/23/2012 03:55:01 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 01 POKE (01) Sun 09/23/2012 03:55:01 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:01 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1A C7 55 09 0A 41 15 Sun 09/23/2012 03:55:01 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:01 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:02 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:02 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:02 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B F0 Sun 09/23/2012 03:55:02 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B F0 06 PEEK (F0) Sun 09/23/2012 03:55:02 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B F0 PEEK (F0) Sun 09/23/2012 03:55:02 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:02 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:02 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:03 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:03 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:03 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:03 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:03 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:03 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:03 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B E8 Sun 09/23/2012 03:55:03 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B E8 06 PEEK (E8) Sun 09/23/2012 03:55:04 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B E8 PEEK (E8) Sun 09/23/2012 03:55:04 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:04 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:04 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:04 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:04 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:04 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:04 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:05 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:05 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:05 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B E0 Sun 09/23/2012 03:55:05 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B E0 06 PEEK (E0) Sun 09/23/2012 03:55:05 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B E0 PEEK (E0) Sun 09/23/2012 03:55:05 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:05 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:05 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 2B E0 PEEK (E0) Sun 09/23/2012 03:55:05 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 03:55:05 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:06 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:06 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:06 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:06 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:06 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:06 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:06 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B D8 Sun 09/23/2012 03:55:06 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B D8 06 PEEK (D8) Sun 09/23/2012 03:55:07 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B D8 PEEK (D8) Sun 09/23/2012 03:55:07 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:07 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:07 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:07 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:07 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:07 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:07 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:08 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:08 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:08 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B D0 Sun 09/23/2012 03:55:08 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B D0 06 PEEK (D0) Sun 09/23/2012 03:55:08 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B D0 PEEK (D0) Sun 09/23/2012 03:55:08 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:08 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:08 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:09 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:09 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:09 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:09 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:09 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:09 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:09 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B C8 Sun 09/23/2012 03:55:09 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B C8 06 PEEK (C8) Sun 09/23/2012 03:55:10 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B C8 PEEK (C8) Sun 09/23/2012 03:55:10 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:10 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:10 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:10 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:10 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:10 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:10 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:11 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:11 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:11 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B C0 Sun 09/23/2012 03:55:11 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:11 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 03:55:11 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B C0 06 PEEK (C0) Sun 09/23/2012 03:55:11 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B C0 PEEK (C0) Sun 09/23/2012 03:55:11 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:11 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:11 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:12 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:12 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:12 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:12 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 29 00 POKE (00) Sun 09/23/2012 03:55:12 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 03:55:12 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:12 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:12 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:12 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B B8 Sun 09/23/2012 03:55:12 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B B8 06 PEEK (B8) Sun 09/23/2012 03:55:12 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B B8 PEEK (B8) Sun 09/23/2012 03:55:12 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:12 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:13 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 2B B8 PEEK (B8) Sun 09/23/2012 03:55:13 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 03:55:13 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:13 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:13 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:13 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:13 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:13 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:13 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:13 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B B0 Sun 09/23/2012 03:55:14 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B B0 06 PEEK (B0) Sun 09/23/2012 03:55:14 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B B0 PEEK (B0) Sun 09/23/2012 03:55:14 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:14 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:14 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:14 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:14 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:14 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:15 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:15 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:15 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:15 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B A8 Sun 09/23/2012 03:55:15 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B A8 06 PEEK (A8) Sun 09/23/2012 03:55:15 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B A8 PEEK (A8) Sun 09/23/2012 03:55:15 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:15 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:16 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:16 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:16 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:16 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:16 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:16 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:16 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:16 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B A0 Sun 09/23/2012 03:55:17 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B A0 06 PEEK (A0) Sun 09/23/2012 03:55:17 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B A0 PEEK (A0) Sun 09/23/2012 03:55:17 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:17 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:17 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:17 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:17 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:17 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:18 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:18 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:18 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:18 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 98 Sun 09/23/2012 03:55:18 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 98 06 PEEK (98) Sun 09/23/2012 03:55:18 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 98 PEEK (98) Sun 09/23/2012 03:55:18 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:18 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:19 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:19 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:19 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:19 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:19 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:19 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:19 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:19 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 90 Sun 09/23/2012 03:55:20 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:20 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 03:55:20 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 90 06 PEEK (90) Sun 09/23/2012 03:55:20 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 90 PEEK (90) Sun 09/23/2012 03:55:20 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:20 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:20 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 2B 90 PEEK (90) Sun 09/23/2012 03:55:20 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 03:55:20 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:20 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:20 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:20 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:21 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:21 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:21 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:21 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 88 Sun 09/23/2012 03:55:21 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:21 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 03:55:21 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 88 06 PEEK (88) Sun 09/23/2012 03:55:21 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 88 PEEK (88) Sun 09/23/2012 03:55:21 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:21 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:22 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:22 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:22 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:22 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:22 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:22 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:22 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:22 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 80 Sun 09/23/2012 03:55:23 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 80 06 PEEK (80) Sun 09/23/2012 03:55:23 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 80 PEEK (80) Sun 09/23/2012 03:55:23 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:23 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:23 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:23 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:23 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:23 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:24 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:24 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:24 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:24 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 78 Sun 09/23/2012 03:55:24 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 78 06 PEEK (78) Sun 09/23/2012 03:55:24 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 78 PEEK (78) Sun 09/23/2012 03:55:24 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:24 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:25 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:25 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:25 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:25 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:25 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:25 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:25 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:25 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 70 Sun 09/23/2012 03:55:25 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 70 06 PEEK (70) Sun 09/23/2012 03:55:26 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 70 PEEK (70) Sun 09/23/2012 03:55:26 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:26 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:26 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:26 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:26 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:26 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:26 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:27 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:27 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:27 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 68 Sun 09/23/2012 03:55:27 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 23 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:27 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 03:55:27 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 68 06 PEEK (68) Sun 09/23/2012 03:55:27 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 68 PEEK (68) Sun 09/23/2012 03:55:27 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:27 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:27 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:28 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:28 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:28 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:28 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:28 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:28 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:28 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 60 Sun 09/23/2012 03:55:28 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 60 06 PEEK (60) Sun 09/23/2012 03:55:29 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 60 PEEK (60) Sun 09/23/2012 03:55:29 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:29 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:29 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:29 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:29 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:29 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:29 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:30 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:30 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:30 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 58 Sun 09/23/2012 03:55:30 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 58 06 PEEK (58) Sun 09/23/2012 03:55:30 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 58 PEEK (58) Sun 09/23/2012 03:55:30 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:30 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:30 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:31 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:31 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:31 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:31 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:31 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:31 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:31 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 50 Sun 09/23/2012 03:55:31 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 50 06 PEEK (50) Sun 09/23/2012 03:55:32 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 50 PEEK (50) Sun 09/23/2012 03:55:32 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:32 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:32 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:32 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:32 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:32 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:32 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:33 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:33 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:33 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 48 Sun 09/23/2012 03:55:33 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 48 06 PEEK (48) Sun 09/23/2012 03:55:33 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 48 PEEK (48) Sun 09/23/2012 03:55:33 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:33 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:33 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:34 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:34 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:34 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:34 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:34 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:34 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:34 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 40 Sun 09/23/2012 03:55:34 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 40 06 PEEK (40) Sun 09/23/2012 03:55:35 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 40 PEEK (40) Sun 09/23/2012 03:55:35 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:35 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:35 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:35 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:35 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:35 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:35 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:36 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:36 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:36 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 38 Sun 09/23/2012 03:55:36 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 38 06 PEEK (38) Sun 09/23/2012 03:55:36 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 38 PEEK (38) Sun 09/23/2012 03:55:36 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:36 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:36 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:37 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:37 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:37 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:37 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:37 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:37 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:37 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 30 Sun 09/23/2012 03:55:37 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 30 06 PEEK (30) Sun 09/23/2012 03:55:38 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 30 PEEK (30) Sun 09/23/2012 03:55:38 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:38 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:38 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:38 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:38 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:38 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:38 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:39 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:39 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:39 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 28 Sun 09/23/2012 03:55:39 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 28 06 PEEK (28) Sun 09/23/2012 03:55:39 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 28 PEEK (28) Sun 09/23/2012 03:55:39 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:39 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:39 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:40 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:40 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:40 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:40 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:40 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:40 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:40 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 20 Sun 09/23/2012 03:55:40 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 20 06 PEEK (20) Sun 09/23/2012 03:55:41 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 20 PEEK (20) Sun 09/23/2012 03:55:41 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:41 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:41 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:41 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:41 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:41 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:41 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:42 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:42 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:42 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 18 Sun 09/23/2012 03:55:42 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 18 06 PEEK (18) Sun 09/23/2012 03:55:42 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 18 PEEK (18) Sun 09/23/2012 03:55:42 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:42 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:42 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:43 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:43 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:43 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:43 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:43 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:43 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:43 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 10 Sun 09/23/2012 03:55:43 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 10 06 PEEK (10) Sun 09/23/2012 03:55:44 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 10 PEEK (10) Sun 09/23/2012 03:55:44 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:44 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:44 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:44 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:44 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:44 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:44 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:45 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:45 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:45 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 08 Sun 09/23/2012 03:55:45 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 08 06 PEEK (08) Sun 09/23/2012 03:55:45 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 08 PEEK (08) Sun 09/23/2012 03:55:45 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:45 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 29 00 Sun 09/23/2012 03:55:45 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 29 00 06 POKE (00) Sun 09/23/2012 03:55:46 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 29 00 POKE (00) Sun 09/23/2012 03:55:46 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:46 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 28 0F Sun 09/23/2012 03:55:46 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 28 0F 06 SET-MSB(0F) Sun 09/23/2012 03:55:46 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 28 0F SET-MSB(0F) Sun 09/23/2012 03:55:46 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:46 PM : [iNST-TX-I1 ] 02 62 1A C7 55 0F 2B 00 Sun 09/23/2012 03:55:46 PM : [iNST-ACK ] 02 62 1A.C7.55 0F 2B 00 06 PEEK (00) Sun 09/23/2012 03:55:47 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2B 00 PEEK (00) Sun 09/23/2012 03:55:47 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:47 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2E 00 01 06 FE 00 00 00 00 00 00 00 00 00 00 CD Sun 09/23/2012 03:55:47 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2E 00 01 06 FE 00 00 00 00 00 00 00 00 00 00 CD 06 (00) Sun 09/23/2012 03:55:47 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2E 00 (00) Sun 09/23/2012 03:55:47 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:47 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2E 00 01 05 1C 00 00 00 00 00 00 00 00 00 00 B0 Sun 09/23/2012 03:55:47 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2E 00 01 05 1C 00 00 00 00 00 00 00 00 00 00 B0 06 (00) Sun 09/23/2012 03:55:48 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2E 00 (00) Sun 09/23/2012 03:55:48 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:55:48 PM : [ 1A C7 55 1] ERR 0 Now, your device should be able to be controlled with On/Off commands from the ISY. Try it out. STEP 6 - Set back to Automatic i2 Insteon messaging - Set Link Management -> Advanced Options. to Automatic or Device Reported. STEP 7 - Query Device Links - At this point, your device may be programmed completely correctly, or it may have a link error on it. Check it out by right clicking on the device and selecting Diagnostics -> Show Device Link Table. The ISY will query the device in i2 mode, and get back the list of links that have been programmed. Then, to see how well the links match what the ISY thinks they should be, click on 'Compare' at the bottom of the links table that popped up. At this point, there really should only be 1 link, followed by a link row of all zeroes. But in my case that wasn't the case. Below is a screen grab of my device links table after the compare that shows a 'bad' link labeled as "Record Mismatch" at 0x0FF0. Then I show the Event Viewer log that was generated when I queried device links. Sun 09/23/2012 03:57:38 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 C2 Sun 09/23/2012 03:57:38 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 C2 06 (00) Sun 09/23/2012 03:57:38 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 03:57:38 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:57:39 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F FF 20 E2 01 13 21 82 FF 1F 01 E9 Sun 09/23/2012 03:57:39 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 03:57:39 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F F7 01 00 00 00 00 00 00 00 00 CA Sun 09/23/2012 03:57:39 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F F7 01 00 00 00 00 00 00 00 00 CA 06 (00) Sun 09/23/2012 03:57:39 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 03:57:39 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:57:40 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F F7 20 A2 00 13 21 82 00 00 00 51 Sun 09/23/2012 03:57:40 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 03:57:40 PM : [iNST-TX-I2CS] 02 62 1A C7 55 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 Sun 09/23/2012 03:57:40 PM : [iNST-ACK ] 02 62 1A.C7.55 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 06 (00) Sun 09/23/2012 03:57:40 PM : [iNST-SRX ] 02 50 1A.C7.55 13.21.82 2B 2F 00 (00) Sun 09/23/2012 03:57:40 PM : [standard-Direct Ack][1A.C7.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 03:57:41 PM : [iNST-ERX ] 02 51 1A C7 55 13 21 82 11 2F 00 01 01 0F EF 20 00 00 00 00 00 00 00 00 B1 Sun 09/23/2012 03:57:41 PM : [Extended-Direct][1A.C7.55-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 I'm probably running out of space for this post, so I'm going to submit it, and continue with Step 8 in the next post . . .
  14. Usually, I will turn off "Automatically Write Changes", make all my scene edits, and then turn Auto write back on.
  15. Hi Lee, Yes, I understand that 'on/off' type devices, such as relay switches and LED buttons have no ramp rate. I was just trying to show the symptoms and to indicate that they seemed strange. I'm wondering if anyone knows why either A) the ISY, or the KPL shows the ramp rate as 9 minutes? What is the point in that? And it's only 9 minutes for the active controller button. All of the 'responder' buttons for that controller group have their ramp rate set to .1 sec. It doesn't bother me particularly that the ramp rate shows as 9 minutes, because in reality the button doesn't ramp - it switches immediately. However, if software in the ISY or in the 2486D is setting that byte incorrectly, and that is causing another unexpected problem elsewhere, then it is of concern. So since it was 'strange', I thought it would be good to report it. Sometimes little quirks like that can provide an 'aha' moment to a programmer, when they realize that perhaps the wrong byte was set in some location. Maybe that ramp rate byte getting set to 0x00 should not be happening, and when it happens, it is causing something else to not work right. Thanks for trying to reproduce this and help me out!
  16. Attached are some screen captures to show the contents of the test scene, and the scene settings for the "C" button's levels. As you can see, Scene C has all buttons set to a 0% level, but button C's ramp rate is 9 minutes and grayed out. You can also see that the load is set to 88%. However, pressing button C turns the load off instead of setting it to 88%. Thanks!
  17. (Continued from previous post): . . . So after doing the above, I decided to adjust the controller button's on/off levels for each controller, so that the controller button pressed would turn on, but the other controller buttons would turn off. So, for button G, for example, I slid the level for buttons B-F and H to 0%, and slid the level for button G to 100%. After getting them adjusted, I programmed the switch. After doing so, and trying out the switch, I found that all buttons B-H would turn the load off, and some of them acted a little strange as well. I went back to the ISY console, and looked at the programming. The on level for the load had reverted to 0% for every B-H controller. (Apparently it does this when you switch a controller's LED button, other than the one being programmed, from 100% to 0%, but it only shows the change when you leave the controller in the tree and come back to it). Additionally, the On/Off levels that I had set to 100% for the button being pressed had also reverted to 0%, and strangely, the Ramp Rate for the active controller button (which is grayed out for these controllers), showed a 9 minute ramp rate, while the ramp rate for all other controller buttons showed .1 second. I reset the load level to the previous levels indicated, and it seemed to stick when I went back and forth between the controllers in the tree. However, I could no longer set the active controller button to 100%. I'd set it to 100% on the screen, and it would show. But if I clicked on a different controller button in the tree, and then went back to the one I had just adjusted, it was back at 0%. Perhaps this is intended operation, but it sure seems strange. If this is the way it is supposed to work, this should be explained somewhere. Anyway, after all of that, I programmed the KPL again and tried it out. Now, any B-H controller button that was pressed would turn on, and all of the other controller buttons would turn off. That part is good. However, pressing any of these buttons would turn the the load off rather than to the programmed dim level. I went back to the ISY console to validate the programming once again. This time, the load dim levels for each of the B-H scenes was correct on the screen. I checked the Device Links table against the ISY's table, and they matched, so the KPL was properly programmed as specified by the ISY. The Event Log for the programming is below: Sun 09/23/2012 12:52:04 PM : [ 1C 8E 6E 1] Preparing Device '1C.8E.6E.1' for Restore Sun 09/23/2012 12:52:04 PM : [ 1C 8E 6E 1] Device '1C.8E.6E.1' ready for Full Restore Sun 09/23/2012 12:52:04 PM : [iNST-TX-I1 ] 02 62 1C 8E 6E 0F 0D 00 Sun 09/23/2012 12:52:04 PM : [iNST-ACK ] 02 62 1C.8E.6E 0F 0D 00 06 (00) Sun 09/23/2012 12:52:04 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 0D 01 (01) Sun 09/23/2012 12:52:04 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:04 PM : [1C 8E 6E 0 ] Calibrating engine version Sun 09/23/2012 12:52:04 PM : [1C 8E 6E 0 ] May not fully support i2, reverting to i1 Sun 09/23/2012 12:52:04 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F FF 08 A2 47 13 21 82 00 1F 08 F3 Sun 09/23/2012 12:52:04 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F FF 08 A2 47 13 21 82 00 1F 08 F3 06 (00) Sun 09/23/2012 12:52:13 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F FF 08 A2 47 13 21 82 00 1F 08 F3 Sun 09/23/2012 12:52:13 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F FF 08 A2 47 13 21 82 00 1F 08 F3 06 (00) Sun 09/23/2012 12:52:16 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:16 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:16 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:16 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F F7 08 A2 47 13 21 82 00 1F 07 FC Sun 09/23/2012 12:52:16 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F F7 08 A2 47 13 21 82 00 1F 07 FC 06 (00) Sun 09/23/2012 12:52:17 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:17 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:17 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:17 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F EF 08 A2 47 13 21 82 00 1F 06 05 Sun 09/23/2012 12:52:17 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F EF 08 A2 47 13 21 82 00 1F 06 05 06 (00) Sun 09/23/2012 12:52:18 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:18 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:18 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:18 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:52:18 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:52:18 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F E7 08 A2 47 13 21 82 00 1F 05 0E Sun 09/23/2012 12:52:18 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F E7 08 A2 47 13 21 82 00 1F 05 0E 06 (00) Sun 09/23/2012 12:52:19 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:19 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:19 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:19 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F DF 08 A2 47 13 21 82 00 1F 04 17 Sun 09/23/2012 12:52:19 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F DF 08 A2 47 13 21 82 00 1F 04 17 06 (00) Sun 09/23/2012 12:52:20 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:20 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:20 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:20 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F D7 08 A2 47 13 21 82 00 1F 03 20 Sun 09/23/2012 12:52:21 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F D7 08 A2 47 13 21 82 00 1F 03 20 06 (00) Sun 09/23/2012 12:52:21 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:21 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:21 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:21 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F CF 08 A2 47 13 21 82 00 1F 02 29 Sun 09/23/2012 12:52:22 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F CF 08 A2 47 13 21 82 00 1F 02 29 06 (00) Sun 09/23/2012 12:52:22 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:22 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:22 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:22 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F C7 08 A2 00 13 21 82 FF 1F 01 7A Sun 09/23/2012 12:52:23 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F C7 08 A2 00 13 21 82 FF 1F 01 7A 06 (00) Sun 09/23/2012 12:52:23 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:23 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:23 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:23 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F BF 08 A2 47 13 21 82 FF 1F 01 3B Sun 09/23/2012 12:52:24 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F BF 08 A2 47 13 21 82 FF 1F 01 3B 06 (00) Sun 09/23/2012 12:52:24 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:24 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:25 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:25 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F B7 08 E2 01 13 21 82 FF 1F 01 49 Sun 09/23/2012 12:52:25 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F B7 08 E2 01 13 21 82 FF 1F 01 49 06 (00) Sun 09/23/2012 12:52:25 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:25 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:26 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:26 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F AF 08 E2 02 13 21 82 FF 1F 02 4F Sun 09/23/2012 12:52:26 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F AF 08 E2 02 13 21 82 FF 1F 02 4F 06 (00) Sun 09/23/2012 12:52:27 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:27 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:27 PM : [MNG-LNK-RSP ] 02 6F 41 A2 02 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:27 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F A7 08 E2 03 13 21 82 FF 1F 03 55 Sun 09/23/2012 12:52:27 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F A7 08 E2 03 13 21 82 FF 1F 03 55 06 (00) Sun 09/23/2012 12:52:28 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:28 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:28 PM : [MNG-LNK-RSP ] 02 6F 41 A2 03 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:28 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 9F 08 E2 04 13 21 82 FF 1F 04 5B Sun 09/23/2012 12:52:28 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 9F 08 E2 04 13 21 82 FF 1F 04 5B 06 (00) Sun 09/23/2012 12:52:29 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:29 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:29 PM : [MNG-LNK-RSP ] 02 6F 41 A2 04 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:29 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 97 08 E2 05 13 21 82 FF 1F 05 61 Sun 09/23/2012 12:52:29 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 97 08 E2 05 13 21 82 FF 1F 05 61 06 (00) Sun 09/23/2012 12:52:30 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:30 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:30 PM : [MNG-LNK-RSP ] 02 6F 41 A2 05 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:30 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 8F 08 E2 06 13 21 82 FF 1F 06 67 Sun 09/23/2012 12:52:30 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 8F 08 E2 06 13 21 82 FF 1F 06 67 06 (00) Sun 09/23/2012 12:52:31 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:31 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:31 PM : [MNG-LNK-RSP ] 02 6F 41 A2 06 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:31 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 87 08 E2 07 13 21 82 FF 1F 07 6D Sun 09/23/2012 12:52:31 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 87 08 E2 07 13 21 82 FF 1F 07 6D 06 (00) Sun 09/23/2012 12:52:32 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:32 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:32 PM : [MNG-LNK-RSP ] 02 6F 41 A2 07 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:32 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:52:32 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:52:32 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 7F 08 E2 08 13 21 82 FF 1F 08 73 Sun 09/23/2012 12:52:32 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 7F 08 E2 08 13 21 82 FF 1F 08 73 06 (00) Sun 09/23/2012 12:52:33 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:33 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:33 PM : [MNG-LNK-RSP ] 02 6F 41 A2 08 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:52:33 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 77 08 00 00 00 00 00 00 00 00 41 Sun 09/23/2012 12:52:33 PM : [iNST-ERX ] 02 51 1C 8A 6C 13 21 82 B1 A1 80 62 4D FD F2 FD E2 15 1B 32 A3 7D E0 14 C7 Sun 09/23/2012 12:52:33 PM : [standard-Direct Nack][1C.8A.6C-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:52:33 PM : [iNST-ERX ] 02 51 1C 8A 6C 13 21 82 B1 A1 80 62 4D FD F2 FD E2 15 1B 32 A3 7D E0 14 C7 Sun 09/23/2012 12:52:33 PM : [standard-Direct Nack][1C.8A.6C-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:52:34 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 77 08 00 00 00 00 00 00 00 00 41 06 (00) Sun 09/23/2012 12:52:34 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:34 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:34 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52 Sun 09/23/2012 12:52:34 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52 06 (00) Sun 09/23/2012 12:52:35 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:35 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:35 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 0F 6F 01 00 00 00 00 00 00 00 00 52 Sun 09/23/2012 12:52:35 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:52:35 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52 Sun 09/23/2012 12:52:35 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52 06 (00) Sun 09/23/2012 12:52:36 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:36 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:36 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 0F 6F 01 00 00 00 00 00 00 00 00 52 Sun 09/23/2012 12:52:36 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:52:36 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 6F 08 00 00 00 00 00 00 00 00 49 Sun 09/23/2012 12:52:36 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 6F 08 00 00 00 00 00 00 00 00 49 06 (00) Sun 09/23/2012 12:52:37 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:37 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:37 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17 Sun 09/23/2012 12:52:37 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17 06 (00) Sun 09/23/2012 12:52:38 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:52:38 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:52:38 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 B7 01 00 00 00 00 00 00 00 00 17 Sun 09/23/2012 12:52:38 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0 Sun 09/23/2012 12:52:38 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 B7 08 00 00 00 00 00 00 00 00 0E Sun 09/23/2012 12:52:38 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 B7 08 00 00 00 00 00 00 00 00 0E 06 (00) Sun 09/23/2012 12:52:39 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:39 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:39 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17 Sun 09/23/2012 12:52:39 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17 06 (00) Sun 09/23/2012 12:52:40 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:40 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:40 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 B7 01 00 00 00 00 00 00 00 00 17 Sun 09/23/2012 12:52:40 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0 Sun 09/23/2012 12:52:40 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 B7 08 1F 00 00 00 00 00 00 00 EF Sun 09/23/2012 12:52:40 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 B7 08 1F 00 00 00 00 00 00 00 EF 06 (00) Sun 09/23/2012 12:52:41 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:41 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:41 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:41 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:52:42 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:42 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:42 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:42 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:52:42 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 00 33 E3 Sun 09/23/2012 12:52:42 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 00 33 E3 06 (00) Sun 09/23/2012 12:52:43 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:43 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:43 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:43 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:52:44 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:44 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:44 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:44 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0 Sun 09/23/2012 12:52:44 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 1F 00 F7 Sun 09/23/2012 12:52:44 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 1F 00 F7 06 (00) Sun 09/23/2012 12:52:45 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:45 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:45 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:45 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:52:46 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:46 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:47 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:47 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0 Sun 09/23/2012 12:52:47 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 66 00 00 B0 Sun 09/23/2012 12:52:47 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 66 00 00 B0 06 (00) Sun 09/23/2012 12:52:47 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:47 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:47 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:47 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:52:48 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:52:48 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:52:49 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:49 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0 Sun 09/23/2012 12:52:49 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 1F 00 00 00 F7 Sun 09/23/2012 12:52:49 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 1F 00 00 00 F7 06 (00) Sun 09/23/2012 12:52:50 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:50 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:50 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:50 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:52:50 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:52:50 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:52:51 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:51 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:52:51 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 84 00 00 00 00 92 Sun 09/23/2012 12:52:51 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 84 00 00 00 00 92 06 (00) Sun 09/23/2012 12:52:51 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:51 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:51 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:51 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:52:52 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:52 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:52 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:52 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:52:52 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 1F 00 00 00 00 00 F7 Sun 09/23/2012 12:52:52 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 1F 00 00 00 00 00 F7 06 (00) Sun 09/23/2012 12:52:53 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:53 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:53 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:53 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:52:54 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:54 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0 Sun 09/23/2012 12:52:54 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 A5 00 00 00 00 00 00 71 Sun 09/23/2012 12:52:54 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 A5 00 00 00 00 00 00 71 06 (00) Sun 09/23/2012 12:52:55 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:55 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:55 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:55 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:52:56 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:56 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:57 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:52:57 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0 Sun 09/23/2012 12:52:57 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 1F 00 00 00 00 00 00 00 F7 Sun 09/23/2012 12:52:57 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 1F 00 00 00 00 00 00 00 F7 06 (00) Sun 09/23/2012 12:52:57 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:57 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:57 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:52:57 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06 (00) Sun 09/23/2012 12:52:58 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:58 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:58 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:52:58 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:52:58 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 00 E0 3E Sun 09/23/2012 12:52:59 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 00 E0 3E 06 (00) Sun 09/23/2012 12:52:59 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:52:59 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:52:59 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:52:59 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06 (00) Sun 09/23/2012 12:53:00 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:53:00 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:01 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:53:01 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0 Sun 09/23/2012 12:53:01 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 1F 00 FF Sun 09/23/2012 12:53:01 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 1F 00 FF 06 (00) Sun 09/23/2012 12:53:01 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:53:01 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:01 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:53:01 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06 (00) Sun 09/23/2012 12:53:02 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:53:02 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:02 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:53:02 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:53:02 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 FF 00 00 1F Sun 09/23/2012 12:53:02 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 FF 00 00 1F 06 (00) Sun 09/23/2012 12:53:03 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:53:03 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:03 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:53:03 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06 (00) Sun 09/23/2012 12:53:04 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:53:04 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:05 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 12 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:53:05 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=2, Hops Left=0 Sun 09/23/2012 12:53:05 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 1F 00 00 00 FF Sun 09/23/2012 12:53:05 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 1F 00 00 00 FF 06 (00) Sun 09/23/2012 12:53:05 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2F 00 (00) Sun 09/23/2012 12:53:05 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:05 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 01 0B FF 00 00 00 00 00 00 00 00 00 00 C7 Sun 09/23/2012 12:53:05 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 01 0B FF 00 00 00 00 00 00 00 00 00 00 C7 06 (00) Sun 09/23/2012 12:53:06 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2E 00 (00) Sun 09/23/2012 12:53:06 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:06 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 08 03 7E 00 00 00 00 00 00 00 00 00 00 49 Sun 09/23/2012 12:53:06 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 08 03 7E 00 00 00 00 00 00 00 00 00 00 49 06 (00) Sun 09/23/2012 12:53:07 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2E 00 (00) Sun 09/23/2012 12:53:07 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:53:07 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 07 03 BE 00 00 00 00 00 00 00 00 00 00 0A Sun 09/23/2012 12:53:07 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2E 00 (00) Sun 09/23/2012 12:53:07 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:53:07 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 07 03 BE 00 00 00 00 00 00 00 00 00 00 0A 06 (00) Sun 09/23/2012 12:53:07 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2E 00 (00) Sun 09/23/2012 12:53:07 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:07 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 06 03 DE 00 00 00 00 00 00 00 00 00 00 EB Sun 09/23/2012 12:53:07 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 06 03 DE 00 00 00 00 00 00 00 00 00 00 EB 06 (00) Sun 09/23/2012 12:53:08 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2E 00 (00) Sun 09/23/2012 12:53:08 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:08 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 05 03 EE 00 00 00 00 00 00 00 00 00 00 DC Sun 09/23/2012 12:53:08 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 05 03 EE 00 00 00 00 00 00 00 00 00 00 DC 06 (00) Sun 09/23/2012 12:53:09 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2E 00 (00) Sun 09/23/2012 12:53:09 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:53:09 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 04 03 F6 00 00 00 00 00 00 00 00 00 00 D5 Sun 09/23/2012 12:53:09 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 04 03 F6 00 00 00 00 00 00 00 00 00 00 D5 06 (00) Sun 09/23/2012 12:53:10 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2E 00 (00) Sun 09/23/2012 12:53:10 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:10 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 03 03 FA 00 00 00 00 00 00 00 00 00 00 D2 Sun 09/23/2012 12:53:10 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 03 03 FA 00 00 00 00 00 00 00 00 00 00 D2 06 (00) Sun 09/23/2012 12:53:10 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2E 00 (00) Sun 09/23/2012 12:53:10 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:10 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 02 03 FC 00 00 00 00 00 00 00 00 00 00 D1 Sun 09/23/2012 12:53:10 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 02 03 FC 00 00 00 00 00 00 00 00 00 00 D1 06 (00) Sun 09/23/2012 12:53:11 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2E 00 (00) Sun 09/23/2012 12:53:11 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:11 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 01 08 FE 00 00 00 00 00 00 00 00 00 00 CB Sun 09/23/2012 12:53:11 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 01 08 FE 00 00 00 00 00 00 00 00 00 00 CB 06 (00) Sun 09/23/2012 12:53:12 PM : [iNST-SRX ] 02 50 2C.EE.6E 13.21.82 23 2E 00 (00) Sun 09/23/2012 12:53:12 PM : [standard-Direct Ack][2C.EE.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:53:12 PM : [iNST-DUP ] Previous message ignored. Sun 09/23/2012 12:53:21 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 01 08 FE 00 00 00 00 00 00 00 00 00 00 CB Sun 09/23/2012 12:53:21 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 01 08 FE 00 00 00 00 00 00 00 00 00 00 CB 06 (00) Sun 09/23/2012 12:53:21 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2E 00 (00) Sun 09/23/2012 12:53:21 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:53:21 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 08 02 01 00 00 00 00 00 00 00 00 00 00 C7 Sun 09/23/2012 12:53:21 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 08 02 01 00 00 00 00 00 00 00 00 00 00 C7 06 (00) Sun 09/23/2012 12:53:22 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2E 00 (00) Sun 09/23/2012 12:53:22 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:22 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 07 02 01 00 00 00 00 00 00 00 00 00 00 C8 Sun 09/23/2012 12:53:22 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 07 02 01 00 00 00 00 00 00 00 00 00 00 C8 06 (00) Sun 09/23/2012 12:53:23 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2E 00 (00) Sun 09/23/2012 12:53:23 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:53:23 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 06 02 01 00 00 00 00 00 00 00 00 00 00 C9 Sun 09/23/2012 12:53:23 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 06 02 01 00 00 00 00 00 00 00 00 00 00 C9 06 (00) Sun 09/23/2012 12:53:23 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2E 00 (00) Sun 09/23/2012 12:53:23 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:23 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 05 02 01 00 00 00 00 00 00 00 00 00 00 CA Sun 09/23/2012 12:53:23 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 05 02 01 00 00 00 00 00 00 00 00 00 00 CA 06 (00) Sun 09/23/2012 12:53:24 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2E 00 (00) Sun 09/23/2012 12:53:24 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:24 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 04 02 01 00 00 00 00 00 00 00 00 00 00 CB Sun 09/23/2012 12:53:24 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 04 02 01 00 00 00 00 00 00 00 00 00 00 CB 06 (00) Sun 09/23/2012 12:53:25 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2E 00 (00) Sun 09/23/2012 12:53:25 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:25 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 03 02 01 00 00 00 00 00 00 00 00 00 00 CC Sun 09/23/2012 12:53:25 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 03 02 01 00 00 00 00 00 00 00 00 00 00 CC 06 (00) Sun 09/23/2012 12:53:34 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 03 02 01 00 00 00 00 00 00 00 00 00 00 CC Sun 09/23/2012 12:53:34 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 03 02 01 00 00 00 00 00 00 00 00 00 00 CC 06 (00) Sun 09/23/2012 12:53:35 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2E 00 (00) Sun 09/23/2012 12:53:35 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:35 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 02 02 01 00 00 00 00 00 00 00 00 00 00 CD Sun 09/23/2012 12:53:35 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 02 02 01 00 00 00 00 00 00 00 00 00 00 CD 06 (00) Sun 09/23/2012 12:53:36 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2E 00 (00) Sun 09/23/2012 12:53:36 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:53:36 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 01 06 FE 00 00 00 00 00 00 00 00 00 00 CD Sun 09/23/2012 12:53:36 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 01 06 FE 00 00 00 00 00 00 00 00 00 00 CD 06 (00) Sun 09/23/2012 12:53:36 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2E 00 (00) Sun 09/23/2012 12:53:36 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:53:36 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 01 05 1C 00 00 00 00 00 00 00 00 00 00 B0 Sun 09/23/2012 12:53:36 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 01 05 1C 00 00 00 00 00 00 00 00 00 00 B0 06 (00) Sun 09/23/2012 12:53:37 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 27 2E 00 (00) Sun 09/23/2012 12:53:37 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Sun 09/23/2012 12:53:37 PM : [iNST-TX-I1 ] 02 62 1C 8E 6E 0F 24 00 Sun 09/23/2012 12:53:37 PM : [iNST-ACK ] 02 62 1C.8E.6E 0F 24 00 06 (00) Sun 09/23/2012 12:53:37 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 24 00 (00) Sun 09/23/2012 12:53:37 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:53:37 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 24 00 (00) Sun 09/23/2012 12:53:37 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 So now, the big question is: what is going on? Why won't the load be controlled correctly? Why does the ISY software lose the load's dim settings (reset to 0%) when one of the controllers LED's is switched from 100% to 0%? Why can't I program the active controller LED back to 100% and have it stick? Why does the grayed out ramp rate for the active controller say that it's a 9 minute ramp? It's just very confusing. Thanks for the help!
  18. Hi Michel, Below is the log file from re-programming (restore) the device with this scene. Settings for the .1 load in each of the other scenes are supposed to be as follows: B-100% C-88% D-76% E-65% F-52% G-40% H-Off I left the ramp rates at their default of .1sec The KPL has buttons B-H set to Non-Toggle ON, while button .1 (A), the load/responder is set to toggle I didn't tweak the controller button levels in the scenes. For whatever reason, in each button's scene, the default sliders for that scene are to turns On all of the other controller buttons, and turn off the button controller being pressed. For example, for the C button, when the 1C.8E.6E.C controller is selected in the tree, it shows the load at its dim level, button C as off, and all the rest of the buttons as On 100% Here's the log: Sun 09/23/2012 12:01:13 PM : [ 1C 8E 6E 1] Preparing Device '1C.8E.6E.1' for Restore Sun 09/23/2012 12:01:14 PM : [ 1C 8E 6E 1] Device '1C.8E.6E.1' ready for Full Restore Sun 09/23/2012 12:01:14 PM : [iNST-TX-I1 ] 02 62 1C 8E 6E 0F 0D 00 Sun 09/23/2012 12:01:14 PM : [iNST-ACK ] 02 62 1C.8E.6E 0F 0D 00 06 (00) Sun 09/23/2012 12:01:14 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 0D 01 (01) Sun 09/23/2012 12:01:14 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:14 PM : [1C 8E 6E 0 ] Calibrating engine version Sun 09/23/2012 12:01:14 PM : [1C 8E 6E 0 ] May not fully support i2, reverting to i1 Sun 09/23/2012 12:01:14 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F FF 08 A2 47 13 21 82 FF 1F 08 F4 Sun 09/23/2012 12:01:14 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F FF 08 A2 47 13 21 82 FF 1F 08 F4 06 (00) Sun 09/23/2012 12:01:15 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:15 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:15 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:15 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F F7 08 A2 47 13 21 82 FF 1F 07 FD Sun 09/23/2012 12:01:15 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F F7 08 A2 47 13 21 82 FF 1F 07 FD 06 (00) Sun 09/23/2012 12:01:16 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:16 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:16 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:16 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F EF 08 A2 47 13 21 82 FF 1F 06 06 Sun 09/23/2012 12:01:16 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:01:16 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:01:16 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F EF 08 A2 47 13 21 82 FF 1F 06 06 06 (00) Sun 09/23/2012 12:01:17 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:17 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:17 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:17 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F E7 08 A2 47 13 21 82 FF 1F 05 0F Sun 09/23/2012 12:01:17 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:01:17 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:01:17 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F E7 08 A2 47 13 21 82 FF 1F 05 0F 06 (00) Sun 09/23/2012 12:01:18 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:18 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:18 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:18 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F DF 08 A2 47 13 21 82 FF 1F 04 18 Sun 09/23/2012 12:01:18 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F DF 08 A2 47 13 21 82 FF 1F 04 18 06 (00) Sun 09/23/2012 12:01:19 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:19 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:19 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:19 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F D7 08 A2 47 13 21 82 FF 1F 03 21 Sun 09/23/2012 12:01:19 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F D7 08 A2 47 13 21 82 FF 1F 03 21 06 (00) Sun 09/23/2012 12:01:20 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:20 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:20 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:20 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F CF 08 A2 47 13 21 82 FF 1F 02 2A Sun 09/23/2012 12:01:20 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:01:20 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:01:20 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F CF 08 A2 47 13 21 82 FF 1F 02 2A 06 (00) Sun 09/23/2012 12:01:21 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:21 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:21 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:21 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F C7 08 A2 47 13 21 82 FF 1F 01 33 Sun 09/23/2012 12:01:21 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F C7 08 A2 47 13 21 82 FF 1F 01 33 06 (00) Sun 09/23/2012 12:01:22 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:22 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:22 PM : [MNG-LNK-RSP ] 02 6F 40 E2 47 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:22 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F BF 08 A2 00 13 21 82 FF 1F 01 82 Sun 09/23/2012 12:01:22 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:01:22 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:01:22 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F BF 08 A2 00 13 21 82 FF 1F 01 82 06 (00) Sun 09/23/2012 12:01:23 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:23 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:23 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:23 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F B7 08 E2 01 13 21 82 FF 1F 01 49 Sun 09/23/2012 12:01:23 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F B7 08 E2 01 13 21 82 FF 1F 01 49 06 (00) Sun 09/23/2012 12:01:24 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:24 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:24 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:24 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F AF 08 E2 02 13 21 82 FF 1F 02 4F Sun 09/23/2012 12:01:24 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:01:24 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:01:24 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F AF 08 E2 02 13 21 82 FF 1F 02 4F 06 (00) Sun 09/23/2012 12:01:25 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:25 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:25 PM : [MNG-LNK-RSP ] 02 6F 41 A2 02 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:25 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F A7 08 E2 03 13 21 82 FF 1F 03 55 Sun 09/23/2012 12:01:25 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F A7 08 E2 03 13 21 82 FF 1F 03 55 06 (00) Sun 09/23/2012 12:01:26 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:26 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:26 PM : [MNG-LNK-RSP ] 02 6F 41 A2 03 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:26 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 9F 08 E2 04 13 21 82 FF 1F 04 5B Sun 09/23/2012 12:01:26 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:01:26 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:01:26 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 9F 08 E2 04 13 21 82 FF 1F 04 5B 06 (00) Sun 09/23/2012 12:01:27 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:27 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:27 PM : [MNG-LNK-RSP ] 02 6F 41 A2 04 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:27 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 97 08 E2 05 13 21 82 FF 1F 05 61 Sun 09/23/2012 12:01:27 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 97 08 E2 05 13 21 82 FF 1F 05 61 06 (00) Sun 09/23/2012 12:01:28 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:28 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:28 PM : [MNG-LNK-RSP ] 02 6F 41 A2 05 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:28 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 8F 08 E2 06 13 21 82 FF 1F 06 67 Sun 09/23/2012 12:01:28 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 8F 08 E2 06 13 21 82 FF 1F 06 67 06 (00) Sun 09/23/2012 12:01:28 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:28 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:29 PM : [MNG-LNK-RSP ] 02 6F 41 A2 06 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:29 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 87 08 E2 07 13 21 82 FF 1F 07 6D Sun 09/23/2012 12:01:29 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 87 08 E2 07 13 21 82 FF 1F 07 6D 06 (00) Sun 09/23/2012 12:01:29 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:29 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:30 PM : [MNG-LNK-RSP ] 02 6F 41 A2 07 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:30 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 7F 08 E2 08 13 21 82 FF 1F 08 73 Sun 09/23/2012 12:01:30 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 7F 08 E2 08 13 21 82 FF 1F 08 73 06 (00) Sun 09/23/2012 12:01:30 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:30 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:31 PM : [MNG-LNK-RSP ] 02 6F 41 A2 08 1C 8E 6E 01 1C 40 15 Sun 09/23/2012 12:01:31 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 77 08 00 00 00 00 00 00 00 00 41 Sun 09/23/2012 12:01:31 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 77 08 00 00 00 00 00 00 00 00 41 06 (00) Sun 09/23/2012 12:01:31 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:31 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:31 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52 Sun 09/23/2012 12:01:31 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52 06 (00) Sun 09/23/2012 12:01:32 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:32 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:33 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 0F 6F 01 00 00 00 00 00 00 00 00 52 Sun 09/23/2012 12:01:33 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:33 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52 Sun 09/23/2012 12:01:33 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 0F 6F 01 00 00 00 00 00 00 00 00 52 06 (00) Sun 09/23/2012 12:01:33 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:33 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:33 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 0F 6F 01 00 00 00 00 00 00 00 00 52 Sun 09/23/2012 12:01:33 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:33 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 0F 6F 08 00 00 00 00 00 00 00 00 49 Sun 09/23/2012 12:01:33 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 0F 6F 08 00 00 00 00 00 00 00 00 49 06 (00) Sun 09/23/2012 12:01:34 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:34 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:34 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17 Sun 09/23/2012 12:01:34 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17 06 (00) Sun 09/23/2012 12:01:35 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:35 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:35 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 B7 01 00 00 00 00 00 00 00 00 17 Sun 09/23/2012 12:01:35 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:35 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 B7 08 00 00 00 00 00 00 00 00 0E Sun 09/23/2012 12:01:35 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 B7 08 00 00 00 00 00 00 00 00 0E 06 (00) Sun 09/23/2012 12:01:36 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:36 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:36 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17 Sun 09/23/2012 12:01:36 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 B7 01 00 00 00 00 00 00 00 00 17 06 (00) Sun 09/23/2012 12:01:37 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:37 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:37 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:01:37 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:01:37 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 B7 01 00 00 00 00 00 00 00 00 17 Sun 09/23/2012 12:01:37 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:37 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 B7 08 1F 00 00 00 00 00 00 00 EF Sun 09/23/2012 12:01:37 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 B7 08 1F 00 00 00 00 00 00 00 EF 06 (00) Sun 09/23/2012 12:01:38 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:38 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:38 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:38 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:01:38 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:38 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:39 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:39 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:39 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 00 66 B0 Sun 09/23/2012 12:01:39 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 00 66 B0 06 (00) Sun 09/23/2012 12:01:39 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:39 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:39 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:39 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:01:40 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:40 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:41 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 1B 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:41 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:41 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 1F 00 F7 Sun 09/23/2012 12:01:41 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 00 1F 00 F7 06 (00) Sun 09/23/2012 12:01:42 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:42 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:42 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:42 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:01:43 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:43 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:43 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:43 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:43 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 84 00 00 92 Sun 09/23/2012 12:01:43 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 00 84 00 00 92 06 (00) Sun 09/23/2012 12:01:44 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:44 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:44 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:44 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:01:45 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:45 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:45 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:45 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:45 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 1F 00 00 00 F7 Sun 09/23/2012 12:01:45 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 00 1F 00 00 00 F7 06 (00) Sun 09/23/2012 12:01:46 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:46 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:46 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:46 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:01:46 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:46 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:47 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:47 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:47 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 00 A5 00 00 00 00 71 Sun 09/23/2012 12:01:47 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 00 A5 00 00 00 00 71 06 (00) Sun 09/23/2012 12:01:47 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:47 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:47 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:47 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:01:47 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:01:47 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:01:48 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:48 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:48 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:48 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:48 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 00 1F 00 00 00 00 00 F7 Sun 09/23/2012 12:01:48 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 00 1F 00 00 00 00 00 F7 06 (00) Sun 09/23/2012 12:01:49 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:49 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:49 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:49 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:01:49 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:01:49 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:01:50 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:50 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:50 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:01:50 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:01:50 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:50 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:50 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 00 C1 00 00 00 00 00 00 55 Sun 09/23/2012 12:01:50 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 00 C1 00 00 00 00 00 00 55 06 (00) Sun 09/23/2012 12:01:51 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:51 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:51 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:51 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 AF 01 00 00 00 00 00 00 00 00 1F 06 (00) Sun 09/23/2012 12:01:51 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:51 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:52 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 AF 01 00 00 00 00 00 00 00 00 1F Sun 09/23/2012 12:01:52 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:52 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 AF 08 1F 00 00 00 00 00 00 00 F7 Sun 09/23/2012 12:01:52 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 AF 08 1F 00 00 00 00 00 00 00 F7 06 (00) Sun 09/23/2012 12:01:52 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:52 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:52 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:01:52 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06 (00) Sun 09/23/2012 12:01:53 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:01:53 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:01:53 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:53 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:53 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2F 00 (00) Sun 09/23/2012 12:01:53 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:01:53 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:01:53 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:53 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 00 E0 3E Sun 09/23/2012 12:01:53 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 00 E0 3E 06 (00) Sun 09/23/2012 12:01:54 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:54 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:54 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:01:54 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06 (00) Sun 09/23/2012 12:01:55 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:55 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:55 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:01:55 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:55 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 1F 00 FF Sun 09/23/2012 12:01:55 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 00 1F 00 FF 06 (00) Sun 09/23/2012 12:01:56 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:56 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:56 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:01:56 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06 (00) Sun 09/23/2012 12:01:57 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:57 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:57 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:01:57 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:57 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 FF 00 00 1F Sun 09/23/2012 12:01:57 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 00 FF 00 00 1F 06 (00) Sun 09/23/2012 12:01:58 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:58 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:58 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:01:58 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 00 02 A7 01 00 00 00 00 00 00 00 00 27 06 (00) Sun 09/23/2012 12:01:58 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:58 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:58 PM : [iNST-ERX ] 02 51 1C 8E 6E 13 21 82 11 2F 00 00 01 02 A7 01 00 00 00 00 00 00 00 00 27 Sun 09/23/2012 12:01:58 PM : [Extended-Direct][1C.8E.6E-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sun 09/23/2012 12:01:58 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 1F 00 00 00 FF Sun 09/23/2012 12:01:58 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2F 00 00 02 02 A7 08 00 00 00 00 1F 00 00 00 FF 06 (00) Sun 09/23/2012 12:01:59 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2F 00 (00) Sun 09/23/2012 12:01:59 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:01:59 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 01 0B FF 00 00 00 00 00 00 00 00 00 00 C7 Sun 09/23/2012 12:01:59 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 01 0B FF 00 00 00 00 00 00 00 00 00 00 C7 06 (00) Sun 09/23/2012 12:02:00 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2E 00 (00) Sun 09/23/2012 12:02:00 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:02:00 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 01 08 FE 00 00 00 00 00 00 00 00 00 00 CB Sun 09/23/2012 12:02:00 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 01 08 FE 00 00 00 00 00 00 00 00 00 00 CB 06 (00) Sun 09/23/2012 12:02:01 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2E 00 (00) Sun 09/23/2012 12:02:01 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:02:01 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 08 02 7F 00 00 00 00 00 00 00 00 00 00 49 Sun 09/23/2012 12:02:01 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 08 02 7F 00 00 00 00 00 00 00 00 00 00 49 06 (00) Sun 09/23/2012 12:02:01 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2E 00 (00) Sun 09/23/2012 12:02:01 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:02:01 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 07 02 BF 00 00 00 00 00 00 00 00 00 00 0A Sun 09/23/2012 12:02:01 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 07 02 BF 00 00 00 00 00 00 00 00 00 00 0A 06 (00) Sun 09/23/2012 12:02:01 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 23 2E 00 (00) Sun 09/23/2012 12:02:01 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Sun 09/23/2012 12:02:01 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 06 02 DF 00 00 00 00 00 00 00 00 00 00 EB Sun 09/23/2012 12:02:02 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 06 02 DF 00 00 00 00 00 00 00 00 00 00 EB 06 (00) Sun 09/23/2012 12:02:02 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2E 00 (00) Sun 09/23/2012 12:02:02 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:02:02 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 05 02 EF 00 00 00 00 00 00 00 00 00 00 DC Sun 09/23/2012 12:02:02 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 05 02 EF 00 00 00 00 00 00 00 00 00 00 DC 06 (00) Sun 09/23/2012 12:02:03 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2E 00 (00) Sun 09/23/2012 12:02:03 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:02:03 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 04 02 F7 00 00 00 00 00 00 00 00 00 00 D5 Sun 09/23/2012 12:02:03 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2E 00 (00) Sun 09/23/2012 12:02:03 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:02:12 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 04 02 F7 00 00 00 00 00 00 00 00 00 00 D5 Sun 09/23/2012 12:02:12 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 04 02 F7 00 00 00 00 00 00 00 00 00 00 D5 06 (00) Sun 09/23/2012 12:02:13 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2E 00 (00) Sun 09/23/2012 12:02:13 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:02:13 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 03 02 FB 00 00 00 00 00 00 00 00 00 00 D2 Sun 09/23/2012 12:02:13 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 03 02 FB 00 00 00 00 00 00 00 00 00 00 D2 06 (00) Sun 09/23/2012 12:02:13 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2E 00 (00) Sun 09/23/2012 12:02:13 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:02:13 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 02 02 FD 00 00 00 00 00 00 00 00 00 00 D1 Sun 09/23/2012 12:02:13 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 02 02 FD 00 00 00 00 00 00 00 00 00 00 D1 06 (00) Sun 09/23/2012 12:02:14 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2E 00 (00) Sun 09/23/2012 12:02:14 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:02:14 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 01 06 FE 00 00 00 00 00 00 00 00 00 00 CD Sun 09/23/2012 12:02:14 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 01 06 FE 00 00 00 00 00 00 00 00 00 00 CD 06 (00) Sun 09/23/2012 12:02:15 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2E 00 (00) Sun 09/23/2012 12:02:15 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:02:15 PM : [iNST-TX-I2 ] 02 62 1C 8E 6E 1F 2E 00 01 05 1C 00 00 00 00 00 00 00 00 00 00 B0 Sun 09/23/2012 12:02:15 PM : [iNST-ACK ] 02 62 1C.8E.6E 1F 2E 00 01 05 1C 00 00 00 00 00 00 00 00 00 00 B0 06 (00) Sun 09/23/2012 12:02:15 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 2E 00 (00) Sun 09/23/2012 12:02:15 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:02:15 PM : [iNST-TX-I1 ] 02 62 1C 8E 6E 0F 24 00 Sun 09/23/2012 12:02:15 PM : [iNST-ACK ] 02 62 1C.8E.6E 0F 24 00 06 (00) Sun 09/23/2012 12:02:16 PM : [iNST-SRX ] 02 50 1C.8E.6E 13.21.82 2B 24 00 (00) Sun 09/23/2012 12:02:16 PM : [standard-Direct Ack][1C.8E.6E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sun 09/23/2012 12:09:59 PM : [ Time] 12:10:34 0(0) Once again, when any button is pressed other than the upper left .1 load button, the load turns off. Based on the strange default of all buttons on except the one pressed, as well as the 'non-toggle ON' setting for the buttons, all of the B-H buttons turn on. So after doing the above, I decided to adjust the controller button's on/off levels for each controller, so that the controller button pressed would turn on, but the other controller buttons would turn off. (NOTE: I continued adding to this post, but exceeded my 60000 bytes, so see the next post for a continuation. . .
  19. Slight update. I found that the C and G buttons did set the load to the right dim value, but B, D, E, and F all turned the load off even though they were programmed to set it on to particular dim levels.
  20. Hello Michel, Well, I did what you asked me to. I completely removed the 2486D from the ISY. I factory reset the 2486D. I added the 2486D to the ISY with the Start Linking button. I then created 1 scene, adding the .1 load as a responder, and B-H as controllers. The 2486D was not added to any other scenes or programs. I set the levels of the .1 load to different brightnesses for each controller: e.g. B-90%, C-80%, etc. I then programmed the 2486D, and tried it out. Result: Only the "Main" (Load) button will turn the load on. All other buttons will turn the load off. Here's some additional info: While waiting for a response, I installed another 2486D for another room that was simpler: 2 loads plus the load associated with the 2486D. I created 7 scenes. All buttons (except G) were used as scenes, including the .1 button. When .1 was pressed, all lights, including the local load went to bright. For the other buttons, there were various levels of brightness for the three different loads. This worked, and it worked well. There were around 38 links in the 2486D. Then I decided to add in the other scene buttons to each scene as responders to turn all button LEDs off except the one that had been pressed. So, for example, the Scene for button C would set the local load to 60%, the other two loads to 50%, and the other 6 buttons to off. I programmed these buttons for each of the 7 scenes, and then reprogrammed. I went to test the scenes, and now I'm back to the original problem. The local load turns off for every scene except the upper left (Main .1 button). I looked at the number of links, and it was 63. After doing the above, I decided to backtrack and set things back the way they were. I removed all of the 'other' buttons from each scene and reprogrammed. It didn't help. I factory reset the 2486D, and then reprogrammed. That didn't help either. I removed the 2486D from the ISY, factory reset it, readded it, and set it up identically to the way I first set it up that worked. That did not work. I verified how many links were in place. There were 38 like there were supposed to be, and the device matched the controller. But it still didn't work. It seems that once you do something to 'break' it, like adding too many links, there's nothing you can do to fix it.
  21. Hi, I've got a room with 9 controlled loads (9 dimmers - either LampLinc, SwitchLinc). I can't get the Keypadlinc buttons B-H, to correctly act as scene controllers for the local 2486D KPL load (V.40 firmware). They always want to turn the load off rather than to the level I've programmed in the ISY. And yes, I've set the proper levels for the scene and for all controllers within that scene. I've done this before with older V.36 Keypadlincs, and it worked fine, but doesn't seem to work with the V.40. ISY software: started with 3.2.6, and then upgraded to 3.3.2. That didn't help. First, before I got the KPL, I had everything working well with a RemoteLinc. The Remotelinc drove 6 scenes perfectly. Then, I replaced one of the Switchlincs 2477D dimmers with a 2486D V.40 KPL dimmer, and tried to set up the same scenes that I had on the RemoteLinc on buttons B, C, D, E, F, and H of the new Keypadlinc. Button "A" (Main) was not used as a scene controller as it was the on/off for the local load. I added the .1 button as a responder to all of the scenes . I added the B, C, D, E, F, and H buttons to each scene as a controller. I set the proper levels and ramp rate for the .1 local load in all of the scenes. And then I copied Scene attributes from the parent scene to each of the controllers, including the new KPL, verifying that every controller for every scene had the KPL's .1 local load set to the right brightness and ramp rate. I then programmed the 2485D KPL. When I use the KPL to control the scenes, all devices go to the proper levels except the KPL's local load. It stays off. If I manually set the KPL local load to ON by pressing the upper left button, I can then select any of the programmed scene buttons, and the local load will turn off. So the local load is in the scenes, but it seems to be programmed to turn off when those scenes turn on rather than to the proper level. If I use the RemoteLinc controller or the ISY to set the scenes, then all devices, including the KPL's local load, go to the right brightness. The local load is set to turn on in scenes B, C, and D, but off in the others. I found that if, after programming, I went into each scene's settings for the KPL on the ISY, and re-adjusted the on level for that scene (say Scene , then that scene button would work OK from the KPL. However, if I then went in and adjusted the level for Scene C in the ISY scene programming for the KPL, without changing anything for Scene B, then Scene C would start working, but now Scene B would turn off the local load again. It seems I was able to get 2 out of 3 of scenes B, C, and D to turn on the local load, but every time I got one to work, one of the others would quit working and would turn the local load off instead. I had another KPL. I replace the first with the second, and the second KPL does the same thing. I did factory resets, Query Insteon Engine, and just about every combination of thing I could think of. I've verified that the device's links match the ISY's links by using the compare feature. They match. I've been working on this 4 or 5 hours, but nothing works. Note: there are about 78-82 links on this device. Could that have something to do with it? Any thoughts are appreciated.
  22. Thanks all for the help. So I think I understand what folks are asking for. I'll provide what I can. And as I'm sure you guys know, I already have traces for when I was first trying to link the 2477SA1 to the ISY in "Automatic" mode that failed with NAKs in earlier posts. I then programmed the devices in i1 mode, and it seemed to work. Anyway, here are my latest test results. I performed these tests in Automatic mode, and then again in i1 mode. First, in Automatic mode, I set up Event Viewer, and then ran "Show Device Links" and then a compare. The compare result showed 3 lines (as this device is not linked to anything but the ISY yet): The red text indicated "Identical", "Extra Record", and "Ignore". I get the feeling that means all is OK. Anyway, after that I did a "Query Insteon Engine". The following Event log shows both "Show Device Links" and "Query Insteon Engine". It's interesting that "Show Device Links used i2cs commands while Query Insteon Engine used i1. I guess that's to make sure that the device can see it. Anyway, here's the log. Sat 09/22/2012 08:54:30 AM : [iNST-TX-I2CS] 02 62 1A C7 0D 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 C2 Sat 09/22/2012 08:54:30 AM : [iNST-ACK ] 02 62 1A.C7.0D 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 C2 06 (00) Sat 09/22/2012 08:54:30 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2F 00 (00) Sat 09/22/2012 08:54:30 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 08:54:31 AM : [iNST-ERX ] 02 51 1A C7 0D 13 21 82 11 2F 00 01 01 0F FF 04 E2 01 13 21 82 FF 1F 01 05 Sat 09/22/2012 08:54:31 AM : [Extended-Direct][1A.C7.0D-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sat 09/22/2012 08:54:31 AM : [iNST-TX-I2CS] 02 62 1A C7 0D 1F 2F 00 00 00 0F F7 01 00 00 00 00 00 00 00 00 CA Sat 09/22/2012 08:54:31 AM : [iNST-ACK ] 02 62 1A.C7.0D 1F 2F 00 00 00 0F F7 01 00 00 00 00 00 00 00 00 CA 06 (00) Sat 09/22/2012 08:54:32 AM : [iNST-ERX ] 02 51 13 21 82 1A C7 0D 27 2F 00 00 50 0F F7 01 00 00 00 00 00 00 00 00 CA Sat 09/22/2012 08:54:32 AM : [standard-Direct Ack][13.21.82-->1A.C7.0D] Max Hops=3, Hops Left=1 Sat 09/22/2012 08:54:32 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 21 2F 00 (00) Sat 09/22/2012 08:54:32 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sat 09/22/2012 08:54:41 AM : [iNST-TX-I2CS] 02 62 1A C7 0D 1F 2F 00 00 00 0F F7 01 00 00 00 00 00 00 00 00 CA Sat 09/22/2012 08:54:41 AM : [iNST-ACK ] 02 62 1A.C7.0D 1F 2F 00 00 00 0F F7 01 00 00 00 00 00 00 00 00 CA 06 (00) Sat 09/22/2012 08:54:42 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2F 00 (00) Sat 09/22/2012 08:54:42 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 08:54:42 AM : [iNST-ERX ] 02 51 1A C7 0D 13 21 82 11 2F 00 01 01 0F F7 04 A2 00 13 21 82 00 00 00 6D Sat 09/22/2012 08:54:42 AM : [Extended-Direct][1A.C7.0D-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sat 09/22/2012 08:54:42 AM : [iNST-TX-I2CS] 02 62 1A C7 0D 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 Sat 09/22/2012 08:54:42 AM : [iNST-ACK ] 02 62 1A.C7.0D 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 06 (00) Sat 09/22/2012 08:54:43 AM : [iNST-ERX ] 02 51 1A C7 0D 13 21 82 1B 2F 00 01 00 0F EF 01 00 00 00 00 00 00 00 00 D2 Sat 09/22/2012 08:54:43 AM : [Extended-Direct][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 08:54:43 AM : [All ] Writing 0 bytes to devices Sat 09/22/2012 08:54:44 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 21 2F 00 (00) Sat 09/22/2012 08:54:44 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=1, Hops Left=0 Sat 09/22/2012 08:54:49 AM : [All ] Writing 0 bytes to devices Sat 09/22/2012 08:55:57 AM : [ Time] 08:56:00 2(0) Sat 09/22/2012 08:56:36 AM : [All ] Writing 1 bytes to devices Sat 09/22/2012 08:56:36 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 0D 00 Sat 09/22/2012 08:56:36 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 0D 00 06 (00) Sat 09/22/2012 08:56:36 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 0D 02 (02) Sat 09/22/2012 08:56:36 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 08:56:36 AM : [1A C7 D 0 ] Calibrating engine version Now, to follow Lee's request, I switched to i1 mode, performed a Query Insteon Engine, and then performed a Show Device Links (with a compare as well). The result was that all 32 links available were reported incorrectly, with each byte containing the lower 8 bits of its own address. That's typical on uProcs that have nothing driving the data bus when a shared address/data bus is being read. The log is as follows, although I cut it off after a few links were reported: at 09/22/2012 09:14:55 AM : [All ] Writing 1 bytes to devices Sat 09/22/2012 09:14:55 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 0D 00 Sat 09/22/2012 09:14:55 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 0D 00 06 (00) Sat 09/22/2012 09:14:55 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 0D 02 (02) Sat 09/22/2012 09:14:55 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:14:55 AM : [1A C7 D 0 ] Calibrating engine version Sat 09/22/2012 09:15:08 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:08 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:09 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:09 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:09 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B F8 Sat 09/22/2012 09:15:09 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B F8 06 PEEK (F8) Sat 09/22/2012 09:15:09 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B F8 PEEK (F8) Sat 09/22/2012 09:15:09 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:09 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:09 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:10 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:10 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:10 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B F9 Sat 09/22/2012 09:15:10 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B F9 06 PEEK (F9) Sat 09/22/2012 09:15:10 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B F9 PEEK (F9) Sat 09/22/2012 09:15:10 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:10 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:10 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:11 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:11 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:11 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B FA Sat 09/22/2012 09:15:11 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B FA 06 PEEK (FA) Sat 09/22/2012 09:15:11 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B FA PEEK (FA) Sat 09/22/2012 09:15:11 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:11 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:11 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:12 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:12 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:12 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B FB Sat 09/22/2012 09:15:12 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B FB 06 PEEK (FB) Sat 09/22/2012 09:15:12 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B FB PEEK (FB) Sat 09/22/2012 09:15:12 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:12 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:12 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:13 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:13 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:13 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B FC Sat 09/22/2012 09:15:13 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B FC 06 PEEK (FC) Sat 09/22/2012 09:15:13 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B FC PEEK (FC) Sat 09/22/2012 09:15:13 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:13 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:13 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:14 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:14 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:14 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B FD Sat 09/22/2012 09:15:14 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B FD 06 PEEK (FD) Sat 09/22/2012 09:15:14 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B FD PEEK (FD) Sat 09/22/2012 09:15:14 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:14 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:14 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:15 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:15 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:15 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B FE Sat 09/22/2012 09:15:15 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B FE 06 PEEK (FE) Sat 09/22/2012 09:15:15 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B FE PEEK (FE) Sat 09/22/2012 09:15:15 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:15 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:15 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:16 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:16 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:16 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B FF Sat 09/22/2012 09:15:16 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B FF 06 PEEK (FF) Sat 09/22/2012 09:15:16 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B FF PEEK (FF) Sat 09/22/2012 09:15:16 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:16 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:16 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:17 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:17 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:17 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B F0 Sat 09/22/2012 09:15:17 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B F0 06 PEEK (F0) Sat 09/22/2012 09:15:17 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B F0 PEEK (F0) Sat 09/22/2012 09:15:17 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:17 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:17 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:18 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:18 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:18 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B F1 Sat 09/22/2012 09:15:18 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B F1 06 PEEK (F1) Sat 09/22/2012 09:15:18 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B F1 PEEK (F1) Sat 09/22/2012 09:15:18 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:18 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:18 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:18 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:18 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:18 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B F2 Sat 09/22/2012 09:15:19 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B F2 06 PEEK (F2) Sat 09/22/2012 09:15:19 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B F2 PEEK (F2) Sat 09/22/2012 09:15:19 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:19 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:19 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:19 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:19 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:19 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B F3 Sat 09/22/2012 09:15:20 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B F3 06 PEEK (F3) Sat 09/22/2012 09:15:20 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B F3 PEEK (F3) Sat 09/22/2012 09:15:20 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:20 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:20 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:20 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:20 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:20 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B F4 Sat 09/22/2012 09:15:21 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B F4 06 PEEK (F4) Sat 09/22/2012 09:15:21 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B F4 PEEK (F4) Sat 09/22/2012 09:15:21 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:21 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:21 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:21 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:21 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:21 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B F5 Sat 09/22/2012 09:15:22 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B F5 06 PEEK (F5) Sat 09/22/2012 09:15:22 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B F5 PEEK (F5) Sat 09/22/2012 09:15:22 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:22 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:22 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:22 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:22 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:22 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B F6 Sat 09/22/2012 09:15:23 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B F6 06 PEEK (F6) Sat 09/22/2012 09:15:23 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B F6 PEEK (F6) Sat 09/22/2012 09:15:23 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:23 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 28 0F Sat 09/22/2012 09:15:23 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 28 0F 06 SET-MSB(0F) Sat 09/22/2012 09:15:23 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 28 0F SET-MSB(0F) Sat 09/22/2012 09:15:23 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Sat 09/22/2012 09:15:23 AM : [iNST-TX-I1 ] 02 62 1A C7 0D 0F 2B F7 Sat 09/22/2012 09:15:24 AM : [iNST-ACK ] 02 62 1A.C7.0D 0F 2B F7 06 PEEK (F7) Sat 09/22/2012 09:15:24 AM : [iNST-SRX ] 02 50 1A.C7.0D 13.21.82 2B 2B F7 PEEK (F7) Sat 09/22/2012 09:15:24 AM : [standard-Direct Ack][1A.C7.0D-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 It's interesting that the i1 'peek's are reading invalid information here. After re-reading LeeG's earlier messages, his response is starting to make more sense to me. I think Lee believes that the device could not have programmed in i1 mode, and should not have responded to On/Off commands, because new i2cs devices do not support the i1 peek/poke commands. But based on the fact that the device really did program, as indicated by the "Show Device Links" in automatic mode quoted earlier, and really did respond to On/Off commands from the ISY, I'm guessing this 2477sa1 at least supports poke, but not peek. It seems to program with the poke, but you can't read the results back with a peek. Lee also mentioned that the "Query Insteon Engine" command will tell you if it's an i1 or an i2 device. Since I don't have the developer's guide, can you tell me what I'm looking for in the data stream to know that? Finally, Michel asked: This does work in both Automatic and i1 modes. But I'm not sure who these 'others' are that he's talking about, or what problems they reported. The only 'other' problem I've seen reported is the one in this thread from SkunkieChris that seemed to match mine. But he was able to resolve his with a new unit, while that didn't help me. I have 2 units that act the same way (will be sending 1 back). However, I figured the workaround to program it in i1 mode, and then use it in i2 mode. I'm not sure what problems I might run into, however, after adding additional controllers/scenes (which I plan to do later today). Anyway, if you can point me to the forum threads that talk about these other problems, I'd appreciate it. And please let me know your interpretation of the results or if you think I've misinterpreted the results. All thoughts are welcome. Thanks all!
  23. I think I may not have been clear enough in my earlier explanation. I'll try to clarify. When I switched the ISY to i1 mode, and then attempted to link the 2477SA1 to it, the linking was successful. I was then able to control the load from the ISY. After linking in this way, I switched the ISY back to 'Automatic mode'. I didn't try to re-link (at first). But I did try to control the load fromt he ISY in "automatic mode", and once again it was successful. I could change the load on and off, query it, and even perform a 'Query Insteon Engine'. And these commands continued to work after performing the "Query Insteon Engine" command, and they all worked without errors or NAKs. However, the Event Viewer showed that it was sending i1 commands, even though I believe the 2477SA1 is supposed to be an i2ce device. Later, after validating everything worked, that was when I decided to try to 'relink' the device in 'Automatic Mode'. It was already working OK, but I wanted to see if relinking in Auto mode would break it. And sure enough it did. It went back to the NAK mode when loading the links, as shown in my earlier posts. So I had to delete the device, switch back to i1 mode, re-add it and re-link it, and then switch back to Automatic Mode. Then all was OK again. It is a kludge, and it shouldn't be that way, but at least I found a way around the problem. I'm looking forward to someone figuring out whether it's a problem with the 2477SA1 or the ISY-99. Time will tell. . . Thanks for your help!
  24. Well, the saga continues, but I think I figured out a work-around. Anyway, I tried all of the suggestions everyone provided, and nothing helped. No amount of factory resetting, choosing "New Devices" vs "Start Linking", or anything else made any difference. I figured my unit was probably bad like skunkiechris' was. So I ordered another one on a 'cross ship' from Smart Home. The new unit arrived, and it turns out it NACKed just like the first one did. I could not link. So I got to thinking, and read some other forums. I noticed folks talking about the i1 vs i2cs protocols, and I remembered the Advanced Options -> Insteon Messaging setting that I had never messed with. I started to change it to i1 only to see if that helped. It warned me against doing so, saying it would mess up all of my i2 devices and scenes. But I took a chance anyway and set it to i1. I could always restore from backup I figured. Well, after doing that, and after deleting the 2477SA1 from the tree, I was able to link an 2477SA1 to the ISY running in i1 mode using "New Insteon/X10 Device". I don't know if "Start Linking" would have worked or not. But I was happy. Both of the 2477SA1s linked. So then I switched Advanced Options -> Insteon Messaging back to Automatic. I tried turning the loads on and off, and that also seemed to work. I tried turning on and off some other things and they seemed to work. I then decided to 'reprogram'/'relink' one of the 2477SA1s while the ISY was still in automatic Insteon messaging mode by choosing "Restore Device" and "Write Updates". When I did this, I was back to the NACKs, and then the device wouldn't work again. I had to put the ISY back in i1 Only mode, delete the device from the ISY tree, and then re-add it back in. So my gut feel is that the problem is i2cs related. The problem might be in the ISY firmware, in the 2477SA1 firmware, or a combination thereof. But it is irritating. I see the UD guys saying that i2cs has caused a lot of problems and that they're working them. Hopefully, this will be one of them and they can resolve it. I'd appreciate any feedback from folks in-the-know if I potentially screwed anything up or slowed anything down by setting Advanced Options -> Insteon Messaging to i1 only and then setting it back to automatic. Also, I'd appreciate knowing when someone figures out what is really happening with this problem. Thanks all
  25. Firmware and UI are both v.3.2.6
