mmknox
Everything posted by mmknox
  1. Hi, I am finally upgrading from my old ISY-99i/IR Pro which has mostly died to a new ISY-994 IR PRO. Should arrive next week. The old unit was backed up and I have the files. What do I need to do to get the new unit set up? Is it as simple as connecting and restoring from my backup or is the new device sufficiently different that I need to start from scratch. It's been years but I seem to recall that some of the programming or logic gets pushed down to the Insteon devices themselves. Any concerns there? Thanks!
  2. mmknox replied to joe567890's topic in ISY994
    So I have the same problem, and Michel's will allow me to launch the console. But going the "normal" way still says there is a revoked certificate. What is "special" about this admin.jnlp file? Is is some older version of Java?
  3. mmknox replied to mmknox's topic in ISY994
    Thanks. I went back and looked at the Link Tables for the dead device, and here's what I found: In the ISY, the first byte is 22 (not A2 or E2); In the devices, the first byte is also 22; But in the PLM, the first byte is A2. When looking at the device Link Table, I clicked "Compare" and it came back with [identical/Ignore] beside the MAC address for the dead device. I guess I was expecting the device to simply be "gone" when I looked at these tables, but from what you say, it sounds like old, removed devices stay, and are simply flagged as inactive. Is this correct? Also, is it an issue that the old device seems to still be showing as "active" in the PLM (A2 in the first byte)? Mike
  4. Hi All, I had an 8-button KeypadLinc fail on me. After a power outage, it became completely unresponsive, won't reset to factory default and won't respond to any key presses, so I've ordered a replacement. Through the ISY interface, I removed each of the 8 buttons from the Scenes they were a part of, then deleted the KeypadLinc itself. So far, so good, but when I look up the links by various device, the ISY or the powerline interface, I still see the dead KeypadLinc's MAC address showing up in the tables. Have I done something wrong? I want to make sure the dead device is "gone" before I set up the replacement, because I've heard having missing devices can negatively affect performance when the system hunts for a device that isn't there. Thanks, Mike
  5. Thanks, Michel. I looked at that article quite a while ago, but will circle back to it to see if there are any programming tips that might help. My problem really seems to be in the actual "detection" of occupancy. People seated in the family room don't generate enough movement for the Insteon IR detector to pick up. I was kidding about the pressure switch on the sofa, but a quick Google search turned up all kinds of chair and bed pressure sensors aimed at the medical industry for monitoring patients who fall out of their seats, beds etc. One of these under the cushions might just be the ticket. If the couch is occupied, then the room is occupied, and if they're standing, the IR motion sensor is more likely to pick them up. Shouldn't be too hard to rig one of these up to an IOLinc module. Mike
  6. Hi, I have a Family Room with lights that were just operating on a timed schedule. While this worked well, the problem was that if the room was occupied at "lights out" time, we would find ourselves sitting in the dark reaching for a controller. I have added two devices to try and deduce occupancy: a SyncroLinc on the TV (which is usually on when the room is occupied) and a Motion Detector. The SyncroLinc works great. If the TV is on at "lights out" time, the lights stay on, then go out after the TV is turned off and the motion detector times out and sends its OFF command. The Motion Detector also works great *as long as it's seeing motion*. I have it set up to send an ON when it sees motion and an OFF after 10 minutes (unless it sees motion again where it re-sets the countdown timer). The problem occurs when the TV is off and the room is occupied, but people are sitting relatively still and the motion detector can't see any movement. My program only turns the lights off when the conditions are met because I don't want them coming on again that evening (based on motion) after the final "lights out". What other ideas have people come up with to determine if a room is occupied? The room has two entrances and is "sunken" off the kitchen and so is open along that wall too. I've thought of some sort of counter at the entrances, but you'd have to know the direction of motion to make that work! Are there any other Insteon occupancy devices (or existing devices used in clever ways) that can help in this area? Maybe a pressure switch on the sofa tied to an IOLinc? Thanks, Mike
  7. AARtech are very good to deal with for RMA's. I had a DOA SwitchLinc which they handled for me very well... sent me a return mailing label and everything.
  8. mmknox replied to gregseigs1's topic in ISY994
    Actually, I don't see why not. I used to have an RCS X10 thermostat, but I replaced it with an ecobee just prior to upgrading to Insteon. The ISY can send and receive X10 messages, and the RCS thermostats just uses one X10 House Code with each of the Unit Codes (1-16) activating two functions (one for an ON and one for an OFF) for a total of 32 discrete commands. You would just have to issue the appropriate X10 Ons and Offs to control the thermostat.
  9. Hi, My electric utility has two TOU periods (Summer and Winter), each with its own different Peak, Shoulder and Off-Peak times. One period runs from May 1 to October 31 and the other runs from November 1 to April 30. I thought I would set up two folders (Winter TOU and Summer TOU) and then throw the programs I want to run in each folder. Problem is, I can't figure out how to set up a condition for May 1 to October 31 and November 1 to April 30 without the year. The year doesn't matter because it's a recurring cycle, but the ISY will only seem to let me enter dates with the full D/M/Y. Have I missed something obvious? Is this possible? Thanks!
  10. mmknox replied to mmknox's topic in ISY994
    Everything working fine, and my I/O Linc does NOT lose settings when power is lost. Must have been older I/O Linc firmware that is referenced in the wiki.
  11. mmknox replied to mmknox's topic in ISY994
    It's true that it doesn't matter if the contacts are NO or NC, but the Wiki article suggests that the "Trigger Off" checkbox that you have to set with NO contacts gets re-set back off if the IOLinc loses power, and recommends NC contacts to get around this. I'll check mine with my multimeter this weekend, but I'm pretty sure mine are NO. I'll test it out, because the IOLinc manual says all the settings are saved in non-volitile memory, so I'm not sure why the Wiki author says otherwise. If it does re-set, I'll just replace the contacts with NC ones. Thanks for everyone's help!
  12. mmknox replied to mmknox's topic in ISY994
    That Wiki article is *exactly* what I'm trying to do... thanks. I have a dumb question about the door sensor. The Wiki article assumes the sensor is the one in the garage kit with wires for both NO and NC operation. I have an existing 2-wire sensor, but I'm not sure if NO or NC refers to its state when the magnet is engaged or when the magnet and sensor are apart! I've looked at numerous door/window sensors on-line and there is no straight answer. Some just say NO or NC, others say things like NO (NC with magnet engaged) and so forth. So in the context of the Wiki article and the Garage Door Kit sensor, are the NO and NC states with or without the magnet engaged?
  13. mmknox replied to mmknox's topic in ISY994
    Thanks... I'll check that out!
  14. mmknox posted a topic in ISY994
    Hi, So I've replaced ALL of my old X10 gear with Insteon and am having a lot of fun (probably at my family's expense) learning about the Insteon gear and ISY controller. I'm left trying to noodle through what I need to do to get my garage door set up. Let me quickly explain what I had done in X10, because it is what I'm trying to replicate... I used a PowerFlash and Universal in the garage on a set of magnetic contacts and the door opener respectively. In the house I had a Leviton keypad (similar to the Insteon KPL) by the front door. The switches were on/off rocker toggles and had a red LED to indicate "On". My old Enerlogic controller used basic-like programming language, and with several X10 addresses, flags and ON or OFF or NEUTRAL states, I had what was likely horribly inefficient code that would: With an "ON" command: Open the door if closed; do nothing if door already open; With an "OFF" command: Close the door if open, do nothing if door already closed; Turn the keypad LED ON if door open, and OFF if door closed, regardless of keypress. (The LED would go On, then OFF then ON again opening a closed door and the reverse when closing an open door). The LED would respond accordingly even if the door was opened from the car's remote. I have (but have not yet installed) an I/OLinc to connect to the door contacts and opener in the garage, and I have two 8-buttom KPLs in the house each with a "Garage Door" label on one of the buttons. (In my old setup, I only had one kepad inside). I debated assigning two buttons (Door Open and Door Close) to be similar to my old Leviton's On/Off rocker, but decided on one button. I am assuming I will have to program the button to issue only ON commands when pressed (as opposed to the alternating ON/OFF as is the default) and then put some programming in the ISY to tie it all together. What I'm not sure of is whether or not to tie components together in "scenes" or treat each as discrete components. The concept of "scenes" didn't exist in my old X10 world. In the end, I would like the KPL lights to be on when the door is open and off when closed, and have the button activate the opener just like the button in the car. If anyone has done this (or similar), I would be very interested in knowing how. Mike
  15. mmknox replied to mmknox's topic in ISY994
    I assumed so, but thanks for the confirmation!
  16. mmknox posted a topic in ISY994
    When I run a Scene Test from the ISY Administrative Console, all of my devices, including 2486 KeypadLincs all come back as "Passed" except my 2430 ControLinc tabletop controller which always shows as "Failed". The 2430 is working fine, and I assume this is because it is just a Controller and not a Responder??? Thanks!
  17. Thanks, Rand. The "wait" between scenes is a good tip and I'll give it a try.
  18. Thanks, I'm going to give that at try. It is slightly different from how I was thinking of coding it. I was thinking of Set Scene, wait, set scene, wait.. I already do have all 4 outside light devices in once scene. The problem is that some days, one or two of the devices in the scene won't be on or off when they should. The other two scenes for indoor lighting are split up that way because I use one of the scenes only in the morning but both in the evenings.
  19. I do have signal bridges and the devices which fail to go on/off seem to vary from day to day (on the same schedule). Today, for instance, I logged into the Administrative Console from work just before a program was scheduled to run. (I turn on two scenes (total of 4 devices) at 1 hour before sunset). I loaded the Event Viewer and watched the programs execute on their own. After it ran, it showed the 4 devices "on". I immediately ran a query and 2 of the devices came back as "off". I manually sent an "on" to the scene with the 2 devices and ran another query and what do you know... they were on! I am unable to determine what could have happened or changed in the time it took me to run a query on 4 devices and manually running an "on" command. Those two scenes had been running flawlessly all week. Later, I came home to find my outside lights were not on, yet they had been working fine. I turned them on from my iPhone's MobiLink app in the driveway, and they turned on just fine. I am baffled. I am going to modify my programs to issue multiple "ons" and "offs" at the scheduled times with a couple of minute "waits" between them and see if that helps. Today was actually worse than what I had been experiencing with my X10 gear that I ripped out, yet for the couple of days prior it was working fine.
  20. Nope, no v35. SwitchLinc Relays are v.3A, LampLincs and Appliance Adapters are v.38 and SwitchLinc Dimmers are v.38.
  21. paulw, All of my Insteon gear was purchased within the last month. What am I looking for to determine if I have any v35 devices? Thanks!
  22. Thanks, IndyMike, that's very helpful. The last controller I spent a lot of time with was an old Enerlogic back in the '90s. It had the concept of states and flags which could be set (a lot like Basic), with the whole program in many lines of script. I will have to take some time figuring out how it's done with folders on this system. I also have a lot of CFLs. Combination of both standard and dimmables, but I'm not convinced that's the source of my problems (yet).
  23. I continue to have signal issues whereby certain devices (not always the same ones) will fail to respond to a timed ON or OFF command. The ISY will show the device in the wrong state (presumably because it sent the command but didn't hear the acknowledgement). If I run a query, it will correct itself (i.e. show it on if its on, off if its off), and I can then send a manual command from the ISY to correct the situation. Commands I initiate from the ISY console ALWAYS work reliably; it's the timed events that are hit and miss for some reason. 99% of the timed events work fine, and it is not always the same device that fails to respond each time. This is baffling because both the timed events and my manual interventions are initiated from the ISY on the same PLM. (I'm chasing down the communications problems separately). What I am wondering is this: Can I have the ISY run a query at a time, say 5 or 10 minutes after a scheduled event, and determine if the devices are in the correct state (on if they're supposed to be and vice versa)? If not, the ISY would send a second on or off command to the problematic device. My programs are very rudimentary (one or two lines) so I wouldn't know where to begin programming something like this... if it's even possible. Right now, I'm more concerned about my porch lights not turning off in the morning and running all day, so I've just added a couple of extra "offs" later in the day to catch them if they are on. Something a bit more elegant would be preferred. Thanks!
