rgn2000
  1. Well I have no idea what's going on. I changed it another Gmail address I have this morning and the test worked. I changed it back to the Gmail address I have been using all along and now that test worked. Bizzare.
  2. I don't see anything there to really try. I already mentioned that I tried a Yahoo account and that didn't work. The thread doesn't mention what the port number is supposed to be for non-Gmail accounts, so if you have any insight there, that would be great. I didn't have a "name" in the From field, but I did add one and then remove it and it didn't work with either change. I also already had Less Secure Apps enabled in my Gmail account. One thing I did just try was that I changed to the Default email account and the test did work.
  3. Thanks for the link, but it seems as though my error is different than most of everyone in that thread. I think only one person mentioned the "18" error. " Those issues were from November of last year and I never had a problem until 4 days ago. It doesn't make any sense.
  4. First off let me say I am still running an ISY99. I just haven't made the change and since I have a rather simple system and things always work, I just haven't bothered to make the switch. About 4 days ago, I stopped receiving my email alerts. I am using my own Gmail account and I haven't made any changes. The password is the same, as well as the account info, and I have 1000 ms for timeout and port 587. I also haven't changed my router or settings whatsoever. If I try to run a test, I get TLS Negotiation Failed. If I turn off TLS, I get Unsupported Authentication Method. In looking at the Error Log, I have the following when a message is attempting to be sent..... Mon 2016/06/27 11:50:01 AM System -170001 [Network] Established Mon 2016/06/27 11:50:13 AM System -50001 -18 I have also tried a Yahoo account with the same exact result. Any ideas as to what could be going on??? Thanks for any help
  5. Now that my KeyPadLink is up and running )http://forum.universal-devices.com/topic/14350-controllers-keypad-and-switch-losing-contact-with-receiver-switch/),I would to do a some programming. I have done some searching, but I can't seem to figure out if this can be done...... The KeyPadLink will control various lights in my basement. The main On/Off controls the main lights (no load connected), but I was wondering if it's possible that the main OFF button could be programmed to be an All Off? In other words, I want the ON button to just turn on the Main lights, but the OFF button to be an "All Off" for all the lights. I plan on reserving one or 2 of the KeyPadLink keys to some party scenes, which will turn on more lights, but since the main OFF button is the easiest for everyone in the family to hit, You see, the majority of time I enter the basement, I only need to the main lights to turn on so the Main On switch is obviously perfect for that. However, when we're entertaining or we just happen to turn on other lights, I want the main Off button to just turn everything off. Is this possible?
  6. I decided to keep it simple and get the FilterLinc. Things appear to be working fine. I haven't seen one error yet. Sometimes it take an extra 1 or 2 seconds to turn off, but all seems well. Thanks again everyone.
  7. How does that XPNR Pro Noise filter work. I put that in the electrical box behind the SwitchLink? Is there room for that?
  8. I just wish it was a little lower profile. These outlets are higher up on the wall to accommodate neon signs so that the cord doesn't have to go down to the normal height for outlets.
  9. Do you mean this? http://www.smarthome.com/filterlinc-10-amp-plug-in-noise-filter.html
  10. Well I didn't need to unplug all of them. Based on your guess that one of the lights could be causing some sort of interference, I deducted that it would probably be the one closest to the switch. I unplugged and it seems to be working fine. I guess I can be 100% sure, but I toggled On/Off about 10 times without a failure, which is something that never happened before. So the now the question is if there is any kind of solution or am I SOL? It's a rec room, and based on my layout, I really don't want to move that particular sign.
  11. The load is a few outlets and plugged into the outlets are neon lights. The problem doesn't happen at all with the SwitchLink (2) that is on the same breaker and leg. Only the KeyPadLink has an issue, but it's not always. I would say 1 out 4 times it will fail.
  12. Well it seems as though I am still having an issue with the problem I originally posted about. The KeypadLink will periodically fail at turning off the power, but it never has an issue with turning it on. If you remember, I have the scene setup as follows.... SwitchLink (1) with the Load connected SwitchLink (2) with no Load connected on same power supply as SwitchLink (1) KeypadLink with no load and on the opposite leg of both SwitchLinks. Whenever I run a Scene Test, it always is successful, so I am not sure what's going on here. One other thing to add is that when I do tap the KeyPadLink to turn it off (when it doesn't work), the SwitchLink (2) also shows as Off so the communication is there. And while the KeypadLink was on (before turning off), the SwitchLink (2) shows as On. So again the communication is happening. However, the SwitchLink (1) remains On and I have to turn it off from that switch or I can flip SwithLink (2) to On which does nothing, but than flipping it Off would indeed turn it off. An obvious communication issue, but the Legs are coupled.
  13. Looks like I didn't do the factory reset right. I still needed to push the button in until the tone stops. So I did a complete factory reset and it's working. I was also able to set it to "fixed brightness" and it works fine with the ISY. Thanks for all your help guys.
  14. I think it's a dud. I just pulled the set button to factory reset it and now it's all messed up, At one point the lights were flickering and now the lights on the device itself don't light up and whenever I press the paddle it makes the same noise as when you press the set button. The interesting thing is that the ISY99 has no problems controlling it. I can turn the lights on or off no problem. If I hold the paddle down I can get the lights to come one, but I suspect it's defective.
