dkaye
  1. Thanks, Michel. Perhaps you can explain (or point me to the explanation of) some points regarding Programs: (1) If the "If" clause contains a "Status" condition (eg, "Status is not On") and there is no Schedule, when and how often is the program run? (2) If the "Then" clause contains a "Repeat" action, what precisely does this do? Does it re-schedule the entire program for execution? (3) If the answer to #2 is Yes, is this a reasonable/proper way to cause a program to run at a predictable interval, say every ten minutes? Thanks. ...doug
  2. I've got an EZIO2x4 in series with my furnace thermostat so that I can turn the heat on and off to save energy while I'm out of town. Through the ISY-26 I can turn it on a few hours before I get home. Sweet. There's just one problem. If there's a power failure -- it happens a lot here in the winter -- when the power comes back on, the relay contacts on the EZIO2x4 are open (off). The device doesn't remember its last state. If it happens in the middle of the night, when I'm home, my heat stays off. What would you do? Have a program that turns the device on every ten minutes and then just disable the script when traveling? Is there a way for the ISY-26 to remember the state of the device and re-apply that state upon power up? Got another clever solution?
  3. dkaye posted a topic in ISY994
    Is there a recommended motion detector that is compatible with Insteon and the ISY-26?
