starmanj
  1. I am finding I'm only getting real time switch status on a subset of all my light switches. Swapped PLM and same issue. Restoring device does not fix it. I am completely stumped. Event viewer shows it's sending status to PLM. Any ideas?
  2. It previously worked, but 2.04 Polyglot cloud shows "true" online and no data. Drivers show "ST" and "GV1"...logs show "authorization failed" though all keys and data are correct?
  3. Solar Edge used to work for me, but now I get: 2021-01-02 14:47:25,596 [NodeServer] [ERROR] Model SE10000A-USR00NNU2 is not yet supported It worked before. Can the Polyglot Cloud server be updated to re-enable my solar inverter? Thanks!
  4. From Mobilinc page: MobiLinc X requires your ISY-994i have our MobiLinc Portal module installed. To install, open the Admin Console and go to Help->Purchase Modules to install the MobiLinc Portal and then Help->Manage Modules. Do not install the UDI/ISY Portal as MobiLinc X will not work with the UDI/ISY Portal. If you've installed the UDI/ISY Portal, please contact UDI Support to have them remove the UDI/ISY Portal and install the MobiLinc Portal for your ISY. Looks like they want to compete with ISY portal. Mobilinc is too expensive and slow with feature updates. What are the alternatives? I'm afraid UD is too dependent on Mobilinc and this will harm UD in the long run...
  5. Also your suggestion to link/unlink Google Home worked! Spokens were successfully sent to Google home.
  6. D'oh. There it is! Never even noticed "My Profile" in upper right. Why not merge that into "My Account"? Anyway I updated and am super stoked to seamlessly use my ISY's!
  7. One last thing-- under "google home", click "send spokens to google home", I get this error: Error sending your spokens. Google home API returned: PERMISSION_DENIED The caller does not have permission
  8. FYI yes Amazon seems to have screwed up a lot of accounts-- I had to put an older password in to login. Amazon bug.
  9. Hi Benoit- Wondering if you backed out the recent update? The portal doesn't show "My profile", just "My account". When I click on user, it only shows "preferred ISY", not "all ISYs". Spearse
  10. Duh...never mind. A simple then set=1 else set=0 will instantly change state; no need for a wait period that doesn't always work. However Portal will still get flooded with Alexa routing requests.
  11. So if I make a second program that sets den_motion to 0 if motion sensor is normal, the state variable immediately reverts back to 0 after motion stops. Is this the correct procedure? Have two separate programs constantly monitoring the elk sensor, and change state instantly? The portal will get a lot of sudden Alexa routine requests within the 30 second interval...
  12. Fantastic News!!! Thanks for the ingenuity and rapid response to this request! My life will be SO much easier not having to constantly switch preferred ISYs. Thanks again!
  13. So if the motion sensor is triggered for only one second, and the wait is five seconds, the variable won't be reset to zero? So how do you reset motion sensor variables back to zero?
  14. Update-- if I change set $den_motion=1 and "WAit 36 seconds" it will change the state variable back to 0. Is this an ISY limitation? Not sure why I have to wait so long to reset a state variable? However the state variable feature still won't trigger Alexa to say anything...when I play the state variable routing via Alexa app, it runs correctly. It simply won't trigger based on ISY state variable changes.
