andyf0
  1. Yup! Picked up an Amazon Tap for $79. There have been a few times when I've wanted a mobile bluetooth speaker to play some music from my iPhone.
  2. Well I liked the local notifications. Does anyone have the updated version and still have the sounds when entering and exiting their fences? They did leave the ON/OFF settings in there for notifications and mine are all ON, but nothing, no sounds and no notifications.
  3. Locative had a new update in the Apple Store today. Now I no longer get any notifications that it did anything. I assume the cloud removal also removed the sound and visual notifications that I listened for to ensure it worked correctly. Anyone else?
  4. Program1 will call it OK. By disabling it you prevent it from triggering when the light level changes by itself.
  5. First, you can't use "Control" on a Z-Wave device unless you're running the latest alpha software. You need 2 programs. Program1: if status z sensor is switched on then Run (if) Program2 else set kitchen lights off Program2: if status z sensor < 50 lux then set kitchen lights on You should set Program2 to disabled. Either the Then or Else will be interrupted if anything in the "If" changes, if you have a Wait or Repeat statement in the body of the program.
  6. The last portal update added support for Chunked Data. Previously, it didn't work at all.
  7. Thanks, seems silly to me! How would you indicate an outside sensor/temperature?
  8. The portal web access tool seems to take forever to display all the devices when using "Chunked Data". I can literally sit and twiddle my thumbs while waiting for the display to come up. Switching back to Default seems to make it much faster, maybe 1 second or so.
  9. Benoit, When you ask Alexa for the temperature she prefixes it with "Inside it is ...............". Is that Alexa or part of the Smarthome skill?
  10. Awesome. Thanks!
  11. Ah! Got it! Thanks.
  12. I created a device "iPhone" inside a location "Home". "iPhone" shows True and False as I would expect. This shows that "iPhone" is occupied in "Home" or not. But "Home" is also showing True and False. While this is cosmetic for me with one device, if I had 2 devices and one was True and the other was False, what would "Home" show? Shouldn't "Home" just be blank?
  13. I setup network resources to do this because once in blue moon Locative will decide I've left the area when the phone is just sitting on the table. So I have programs to correct that and fix the mess caused by ISY thinking I've left the area when I'm sitting watching TV.
  14. You can setup network resources to call the same URLs that Locative uses to force a Home and Away situation. That way you can debug your home and away code without leaving the house. This will set your device to TRUE. POST /api/location/ <insert key here> /report/in HTTP/1.1 Host: my.isy.io:443 User-Agent: Mozilla/4.0 Connection: Close Content-Type: application/x-www-form-urlencoded Content-Length: 0 Change the word "in" in the URL to "out" to set your device to FALSE. For you & your wife I would imagine you have one location called Home and two devices, my iPhone & Wife's iPhone. Then you can test both of them to be false for Away or one of them to be true for Home. I don't think you need two users on the portal.
  15. andyf0 replied to andyf0's topic in UD Portal
    Thanks Benoit. BTW, it works great with Locative.
