onever
  1. Well, in my particular case it was definitely a problem with replace command in PLM. Looks like the links for the new device were either not written or corrupted. Restore PLM operation took care of the issue completely. Links count is "only" 647. Thanks for the help! Forgot to mention another peculiar thing. I have a (new) leak sensor that never sent heartbeat, no matter what I tried. I was about to send it back to SmartHome for replacement when all of a sudden I started receiving the heartbeats – after PLM restore…
  2. I had couple of those... ALL ON event triggered seemingly by a motion sensor. It stopped happening though after I upgraded to 994.
  3. That did the trick! Thanks, shannong! I gues something did go wrong during the replacement process. What I don't understand however, is how in the world did device's and ISY's tables compare ok?
  4. No, thanks for the idea. That's probably the only thing I haven't done yet, short of deleting everything and recreating all the scenes again. I tried power-resting both PLM and ISY with no success. I'll try restore tonight.
  5. Both. I did a compare in GUI... They are identical!
  6. Hi everybody, I've been using ISY/Insteon for quite some time now, but this is the first time I'm absolutely clueless as to what's going on. I had to replace one of my older keypads that fell victim to "restless blinking syndrome". The new keypad is latest and greatest v43, brand new from SmartHome. I did the replace operation in ISY and everything seemed to be fine. Except, ISY doesn’t see any commands from the new device. So if I press a button on the new keypad, the appropriate scene turns on or off, but there’s no change in ISY’s device status. Moreover, if I open event log, there is *nothing* there. As if no communication is taking place between the devices in the scene. If I do query in the GUI, the statuses update fine. If I control the device itself from the GUI, it also works as expected. Just no commands from the buttons themselves are visible to PLM. The link tables are identical, I checked. I don’t think there are any communication problems either as all the scenes work and another keypad next to the new one doesn’t have any problems either. Factory reset, relinking – I tried everything I could think of, to no avail… Help!!! Thanks, --Oleg
