mkg
Everything posted by mkg
  1. I restored one KPL. No change. It still says that the device type is 6-button KPL. Any other idea? If not, I think I will need to: Delete the device Add it as a "New Insteon Device" - using a pre-defined device type (and not used "Auto Discover") Re-program/configure everything. Please let me know if there is a better idea to recover from this situation. Thanks! MKG
  2. Techman, Thanks for the info. KPLs are already in 8-button mode. Each of the key can be turned on/off individually. About restoring the device - where is the info about device type is stored? If this info is also coming from the ISY database then will that make a change? Thanks!
  3. Thanks for your response. These KPLs were installed more than 8 years ago! At least one of them was installed by a contractor. I am not sure if there were 6-button or 8-button, originally. But, they have been working fine as 8-button KPLs before the upgrade. I am using "ISY994 Administrator Console" and both firmware and UI are at version 5.3.4 (as per the "About" pop-up).
  4. I recently upgraded firmware on my ISY 994i from version 4.9.0 to 5.34. Upgrade went fine and most of the devices (including Insteon motion sensors) are working fine. Very simple upgrade process! Thanks!! The only issue I found that device type for couple of Insteon KPLs is wrong. ISY is reporting that the device type for both KPLs is "(2486D) KeypadLinc Dimmer 6 Buttons v.39". However, these are 8-button KPLs. Now, this is causing problem in creating new programs or updated existing programs. For example, while checking status of a key, the only possible values are "on" or "off" and not like "50%". What is the least painful way to reconfigure these KPLs? I would like to avoid/minimize reprogram everything again. Thanks!
  5. I searched all the relevant forums, but unable to find an answer to this.. I have a "ISY-99i" (w/PLM) and I would like a upgrade it to a model of "ISY-994" which can be integrate with my PGE SmartMeter such that I can monitor my electric usage in real-time. My questions are: Which model of "ISY-994i" I need to buy? What will I need to do to integrate it with PGE SmartMeter? Thanks! --Mike
