Monica
  1. Thanks Michel. I sent an e-mail for the support. Mônica Corrêa
  2. Michel, I've done all the procedures that there are in link, but couldn't make it work. How do I contact you, for you help me? Thanks and Regards, Mônica Corrêa
  3. Hi Michel, I couldn't config my router, is there any document with step-by-step configuration? Do you know if anyone could config D-link DI-524 for Internet access? Thanks. Mônica Corrêa
  4. Monica posted a topic in ISY994
    Hi, I have a ISY99i-IR, and I`m not able to access Insteon network over the Internet. I have a D-link router model DI-524, anyone knows if it is possible to access the insteon network over the internet with this model? Mônica Corrêa
  5. Hello, I still couldn't access isy99i over internet. I did the port forward on my D-link DI524 router (its a compatible router) using DMZ configs as you said in the e-mail below. When I did it I couldn't find the administrative console anymore using the local IP adress (192.168.0.124) to enable internet access on ISY99i. Then, I disabled the port forward and returned to ISY99i administrative console to enable internet access. When I clicked on it, I received thru a popup the address for internet access (something like https://189.110.33.33) So I turned on again the portforward in my router (using the local IP address). So I accessed the whatsmyip.com to discover whats my ip. With a 3G connection, I tried to connect using the IP I discovered in whatsmyip and the browser couldn't find it. I tried to find the https address that ISY99i gave me to access and it was not found too. But, If I try to access using the computer connected to this router, I can access using the IP assigned to my router. But I couldn't access using the https address ISY99i gaves me. Does anyone know what could be the problem?
