Diesel1
  1. Diesel1 replied to joefly's topic in ISY994
    I can't help,but had something similar happen today. I was setting up notifications rebooted and couldn't get in,so I went to look at the isy and error and memory lights flashing. I tried reboot nothing and have no backup so I am not sure if im going to loose everything with a factory reset.
  2. The ir link is in the harmony programming as automation.It will give you all touch buttons. You can program any button to the codes once you set up the if link in harmony. I used sequence and programmed them to buttons in activities such as"watch movie" so pause button brings lights up and play lowers lights. Personally I was in the same boat as you so I bought the refurbished for 89.00 no wait and already have it boxed to go back. Don't get me wrong it works, but depending on what else you are using it takes along time to sync. I had HL2 and irlink. For a little more I replaced them with a refurbished isy-99 ir pro and gained alot more flexibility and a lot less headaches. Try it out if it serves it's purpose great. If not there are other options. Good luck
  3. What is the cost to upgrade to Pro ? I am trying to decide if I should get the standard until I need to upgrade or just buy the Pro. Thanks for your time
