frank
  1. Has anyone written a program that will sense a garage door is open and keep repeating the announcement via Alexa until action by myself turns it off? Frank Sent from my iPhone using Tapatalk
  2. 1: What is the correct color wiring and connected to where? 2: Unable to connect to PLM 3: right now I have the ethernet cable (gold or clear colored) connected to the side of the eisy. This is connected to the USB adapter which then connects to the PLM via the blue USB to Serial 2413S ver 2.1.
  3. Does anyone know if the Aeotec 7 MultiSensor will work in the UD 994iz Pro and if yes, instructions on inclusion instruction. Frank Sent from my iPhone using Tapatalk
  4. frank posted a topic in Insteon
    I can view my camera while at home and WiFi is on. However if I turn off WiFi I can not access the camera. This camera has been working perfectly up to about a couple weeks ago. It is the Insteon PTZ camera. Is anyone else experiencing the same problem? Did Insteon shut off their server or change their access info? Or has something changed in my Comcast gateway? Frank
  5. I have the same problem which O posted a couple weeks ago. The ONLY data I get is motion detection. Temp, luminance and battery level all froze up and don’t send data any longer. I tried a new battery with zero results Sent from my iPhone using Tapatalk
  6. frank replied to frank's topic in ISY994
    Thanks for the feedback. Have already done the above. Will wait for 24 hrs and see if any parameters may be affecting the performance. Sent from my iPhone using Tapatalk
  7. frank replied to frank's topic in ISY994
    Firmware and UI both 5.3.2. 1 sensor is Insteon MS II 1 sensor is Zooz ZSE29 ver 2.0 Sent from my iPhone using Tapatalk
  8. frank replied to frank's topic in ISY994
    No, did not recently do an upgrade. Asking if anyone else is experiencing a similar problem before I go replace the batteries because of difficult location to get to. I’m running 5.3.2 at the moment. Just ironic that both quit at the exact same time. Sent from my iPhone using Tapatalk
  9. Just had 2 motion sensors from 2 diff companies, go dead at same time and wondering if a coincidence or are others having the same problem? Has anything changed on the ISY994iz ? Sent from my iPhone using Tapatalk
  10. Try using “ON” and “OFF” instead of “Fast on” and “Fast off” Sent from my iPhone using Tapatalk
  11. Mustang65, Thanks for the update. That is exactly to results I experienced. It appeared, in my experiment, the solar cell only had a MINOR influence on the life of the battery and what I actually experienced was just the typical life of the 1.2v battery in a scenario similar to yours. Not sure, but I think I didn’t have enough current from the solar to fully charge the battery each day. If you come up with a solution, please advise and I will do the same. Frank Sent from my iPhone using Tapatalk
  12. Mustang65. Thanks for the update. Appreciate the info. I’m going to give it a second try on my mailbox sensor and if successful I’ll try on my motion sensors frank
  13. Mustang65. Thanks for the update. I posted last week but guess it didn’t go thru. Where in the solar charging circuit did you tap in and did you use the battery that came with the solar light or did you stay with the Insteon battery? Did you consider using both in parallel? frank
  14. Great info Mustang65. I tried using solar cells bought off Amazon that did not keep the battery charged. I also used a high capacity battery. I will probably try using the lower capacity battery and a repurposed solar light. Thanks for keeping us updated.
  15. Thanks for the feedback Mustang65 Sent from my iPhone using Tapatalk
