glenn_steiner
  1. I can't seem to find a list of Zigbee Devices that have been successfully tested with eISY and the ZMatter USB dongle. If you have tested and it works please list here along with what functions are working. And a link to where to buy. If its not working please post in a different thread. Thanks.
  2. Thanks, but I got it working. Thanks, but I got it working. This is my way of letting others know it is still working and hints to get it working.
  3. Hello, As of 12/30/24 I was able to get this node working with my T9 thermostat. Helpful hints: Trying to piece together documentation fixes/help from others into one place (these fixed my problems). Developer, greatly appreciate your updating your documentation in all locations. Or at least make this post sticky. Thanks. Documentation link to API website is no longer valid. Ie. https://developer.honeywell.com is a dead link. It is now: https://developer.honeywellhome.com If you have an existing account already set up, and it has been a year or more since you set it up, you may be using the OLD Callback Url. If you are trying to replace a Honeywell Tstat, you may need to change/update the "call back url". Or, you get the following error when logging into udi-honeywellhome-auth.azurewebsites.net "code": 400, "message": "The redirect URL provided does not match the redirect URL registered for the app." Then do the following: Open https://developer.honeywellhome.com Login as normal. Goto "My Apps" Select your app, in my case it was called ISY Nodeserver Hit the pencil edit button. Change the Callback Url from the old one to the new one: https://udi-honeywellhome-auth.azurewebsites.net/auth Once that is corrected you can proceed to add the new Tstat.
  4. Yes. Thanks for clarifying my comment. Its the more info button.
  5. Yep. I am new and learning the hard way. I spent years writing software and documentation. A minute extra spent by a developer in clearly writing documentation can save a collective group of users hours.
  6. OK. I thought I got it all going, but I am at the point where I can see all my zones in the UI, but status is not updating even if I click Query. And can't control when I press On or Off. What am I missing? TURNS OUT I NEEDED TO CLOSE AND START THE AC TO GET IT WORKING PLEASE I spent two hours on this tying everything and reading the forum topics to incrementally get this working. Please update your documentation so we don't have to go through all of the discussion topics to see what really needs to be done. If a user is having problems, others will also. Please please. Thanks.
  7. Title says it all. Yes, I suppose I could use two buttons to do the same, but that is just silly.
  8. link is bad and is: ttps://github.com/Panda88CO/udi-TeslaEV2/blob/main/README.md yes, missing an h at the beginning
