gspence
  1. Does anyone have this RJ45 to DB9 cable that came with the 2413S PLM? I'm attempting to connect this PLM directly to my computer and can't locate the cable. I can't locate the pinout diagram to map the RJ45 pins to a DB9. The Quickstart guide shows the connections for Tx and Rx, but it doesn't specify pin numbers for TTL In/Out or Ground. I'm assuming ground is standard, but I can't find a specification for the TTL connections. Are these even necessary when connected to a standard serial port (DB9)? Thanks! Greg
