jdheltne
Everything posted by jdheltne
  1. I am trying to control the on/off of the water flow for my mister system on my patio. My thinking was to get a Electronic Water shutoff valve and control it via an Insteon device such as either a IO Link or an On/Off Outdoor Module via my ISY. What I am having problems with is the wiring and controlling it. I have an Smarthome Select Electronic Water Shutoff Valve 3/4" DC. With the IO Link, the wiring guide for the valve says green from value to IO Link NC red from valve to IO Link NO black from valve to 1 wire of my DC adapter 2nd wire from DC adapter to COM on IO Link When I do this, and I discover my IO Link and then configure it for: - LED on TX - Relay follow input - Momentary B and then turn the relay on or off, nothing happens on my valve. What am I missing here?
  2. It goes into linking mode but my isy never sees it. Done factory reset on it and still wouldnt link. It did wworkbefore I moved.
  3. Right, so as I mentioned I upgraded the ISY to 3.3.10, upgaded the UI to 4.0.11, THEN added all devices. I did all upgrades on the ISY and UI before I added any devices to the ISY, so all were added with 3.3.10 firmware and 4.4.11 UI straight away. Im having problems with all my KPLs not recognizing them with multiple buttons, and all of the KPLs are model 2334-222 and purchased brand new in the last 2 weeks. Additionally, now I tried to add a remotelinc2 and its not recognized at all...
  4. So the whole history is this: I moved to a new house, so I factory reset everything, the ISY99i, the PLM, access points, switches, etc... WHen I did the factory reset of the ISY, I also upgraded to the latest and greatest version. Then I installed everything, so yes, everything was installed after the upgrade. The ISY I have had for 2+ years, the keypadlinc I have had for 1 week and they are brand new from Smarthome. Also, no there is no plus sign next to it, it looks like like a Switchlinc does.
  5. RIght, firmware is 3.3.10 and UI is 4.0.11 I have 2 of them, 1 started out as a 6 button and I converted it to 8, and the 2nd is an 8 button, both purchased new in the last 2 weeks. I also did a factory reset on both of them this morning and tried to relink them with the same results. KeypadLinc1 = 2334-232 5 button - this was origionally a 6 button KeypadLinc but I converted it to 8. At the switch, each button acts independently of the other, so I know it is in 8 button mode. I can also turn the main light connected to the main on/offf at the switch, however, when I try to link it via the ISY I get an error saying it cant read the link table and fails. KeypadLinc2 = 2334-232 8 button - when I look at it via the ISY GUI, it shows as (2334-2) KeypadLinc Dimmer 8 Buttons v43 but I only see the 1 device, not 8 devices. I have no problem linking this KeypadLinc other than it shows as 1 device only. I can manage it via the ISY GUI but on as if it was a SwitchLinc dimmer...
  6. I have had an ISY-99ir/PRO for several years now and had previous versions of keypadlinc. I recently purchased a new KeypadLinc (model 2334-232). WHen the ISY discovers it, it shows it as a single switch, not the 8 buttons that are there like it did in previous KeypadLincs. I am at firmware 3.3.10 and UI 4.0.11. Reading around the internet, people who have the issue as myself have basically been saying I need to upgrade to a new 994 in order to support the new keypadlinc. Is this really true? It would be both time consuming and expensive to replace my 99i with the new 994. Has ANYONE gotten a new keypadlinc to work on a 99i? If so, What am I missing/doing wrong? thanks, Jason
  7. Thank you all I think I got it all working now.
  8. Thank you guys for the help. I think I have this working with 1 final question: I was hoping to try to get the buttons on the keypad to light up 50% if 1 or more switches in the scene are on. So for example, Switches -GR-FloodLights (on) -GR-Light (off) Keypad Button D -KL-BD-D Keypad button D would light up 50% since 1 of those lights is on. I see how to turn the buttons on and off, but is it possible to set the button itself to only be 50% lit? What i have is: If Status 'GR-FloodLight' is on Or Status 'GR-Light' is on Then Wait 2 seconds Set Scene 'Keypad-BD-D' On <--- This is what I want to set at 50% if any of the 2 switches above is on Else Wait 2 seconds Set Scene 'Keypad-BD-D' Off Basically if 1 or more lights is on, light the button up 50% brightness
  9. I have the following devices: ISY-99i IR/Pro Gameroom Patio Builtin Lights - Lights that are built into the patio for the gameroom (3 way switch) - "GR-Patio-Light-Builtin" (2477D) Switch is in the gameroom - "Shop-GR-Patio-Light-Builtin" (2477D) Switch is in the shop -Scene is called "GR-Patio-Lights-BuiltIn" and currently works as a 3 way switch were both switches are controllers and responders to each other Gameroom Patio Fan Lights - Lights that are in the fan on the gameroom patio (3 way switch) - "GR-Patio-Fan-Light" (2476S) Switch is in the gameroom - "Shop-GR-Patio-Fan-Light" (2476D) Switch is in the shop -Scene is called "GR-Patio-Fan-Light" and currently works as a 3 way switch were both switches are controllers and responders to each other What I want to do is using my keypadlinc 2 (2486D) button D be able to control all 4 of the above switches, and have button D show a light when any of these switches are on, and no light when they are not on. In addition, when I press button D, I want these lights to turn on or off, and reflect that on their switches as well.
  10. It sounds like in order for the Keypadlinc to reflect state of those buttons I actually need to create a program such as shown here (http://www.universal-devices.com/mwiki/ ... ow_Program) in order for the keypad to reflect the state of the buttons?
  11. If I already have a 3 way switch for several lights, and want to combine them to be controlled from one keypadlinc button: Scene - GR-Floodlight - GR-Outdoor-Floodlight - Shop-Outdoor-Floodlight Scene - Visitor Lights - House-Patio-Spotlight - House-Driveway-Spotlight I want to add both scenes (or all 4 devices) to a scene controllable by a keypadlinc button. When I try to add them it says they are already part of a scene and only gives me the option to add them as a responder.
  12. I am having a problem making my keypadlinc 2 (2486D 8 button) control a scene. What I have is this: ISY-99i Pro firmware 3.1.17 (2012-01-19-15:34:02) UI 3.1.17 (2012-01-19-15:34:02) Keypadlinc 2 (2486D 8 button) SwitchLinc (2476D) - Gameroom Light (only used as on and off, no dimmer in light) I am trying to link them so that button C on the keypad can turn this light on and off and have the state be reflected on the keypad if I turn the light on and off from the gameroom as well. When I look at the button in the UI, I see it is a controller and a responder for the scene, but when I look at the Switchlinc it is only a responder, and the On Level says applied locally and same with the ramp rate. How would I setup the switchlinc to be both controller and responder? 2nd, when I have a scene already created because of a 3 way switch, and I then want a button on the keypadlinc to control the existing scene, how do I make it controller/responder? thanks, Jason
  13. They both now have the option to "Copy Scene Attributes...." and when i click on each switch in the scene, that particular switch shows in red and [Applied Locally]
  14. How do I do that? What I did when I created the scene was this: - Create new scene - drag the line switch to the scene and tell it that it is the controller - drag the load switch to the scene and tell it that it is the responder When I look at the switches individually I see the folllowing: - line switch - Is Controller for - Kitchen-Light (the scene name) - Kitchen-Light-FR (the load switch) and is in blue - Is Responder to - Kitchen-Light (the scene name) - load switch - Is Controller for (nothing) - Is Responder to - Kitchen-Light (the scene name) - Kitchen-Light-BR (the line switch) and is in red
  15. I have 2 switchlinc 2476D switches setup in a 3 way switch configuration. I did not link them from the switches themselves, I simply imported them into the ISY-99i and then created a new scene and assigned them to the scene, with the line switch being the controller and the load switch being the responder. These switches are for my kitchen light, and have a scene called "Kitchen-Light" The problem I am seeing is on the controller switch, I see the message "Copy Scene Attributes from Kitchen-Light". When I click on the responder switch I see what I expected, which is the status, on-level, Membership, etc.... In addition, if I turn the light on from the line switch, both switches reflect the correct state, however, when I turn the light on from the load switch, only the load switch reflects the correct state. Any suggestions would be appreciated. thank you Jason
  16. Its not exactly working as designed. For some reason once I press the On, then press the off, i cant use the On again. Would that have to do with the toggle?
  17. Thats what it was, I had to use a seperate Scene for each on/off control for a given program. A given on/off pair of commands actually took 2 buttons and 2 scenes on the Harmony which amounts to Scene A and B on the credit card remote for just turning 1 set of lights on and off.
  18. So for example, the credit card remote that came with the IRLinc, each scene has 2 commands for Scene A. SceneAOff and SceneAOn. On the Harmony, if I want to be able to configure it so that when I press Button A (in my case "AV-Dim") it will run the SceneAOff command and in the program I have If Control 'AV-Dim Button' is switched On Then commands to turn off the lights Now to turn the lights back on, I should be able to use button B (in my case "AV-On") that will run the SceneAOn command and in the program I have If Control 'AV-Dim Buttom' is switched On Then commands to turn on the lights The 2nd command doesnt appear to be working, im wondering if I have to use another scene to make it work rather than the SceneAOn/Off command?
  19. I believe I may have found my issue, i *believe* when I have 2 buttons on the Harmony, 1 set to SceneAOff and the 2nd set to SceneAOn via the Harmony, it actually configured the On and Off automatically when I configure any of the 2 since they are the same Scene. Does that sound right? I say this because when I setup another group of 2 buttons, for SceneB it found it, but only 1 time.
  20. I have a button configured on my Harmony 1100 that via my IRLinc Reciever is now recognized as a device on my ISY-99. My Question is, how do I set the program so that when I press the button on my Harmony it runs that program? I see how to do that via the native IR functions, but not when I use the Harmony via the IRLinc. The program simply turns several lights off.
  21. Open the admin console on ISY, click on add new button (ie the screen pops up with the steps at that point) Press and hold the set button on the IRLinc reciever for 5 seconds, press the button on the harmony to learn the new button and wait for it to blink blue, then press OK in the ISY console. When I did that with the 1st button, it went through the normal screen where you see it discovering a new device and then it showed up as a device. When I do the exact same thing for the 2nd button, it does everything else but that last step where it goes through the screen that flashes up with the bar that shows it is discovering a new device.
  22. When I defined the Smarthome 2411R as the device, as I mentioned, it created every button that is on the credit card remote as buttons on the Harmony 1100. This should be plenty for me. I then went to the IRLinc, pressed the button for 5 seconds, pressed the 1st button on the Harmony and then "Add button" and it found the 1st button as added it as a device on the ISY. Now I have have another problem, when I try to do this for the 2nd button, the IRLinc does everything as it should, I press it for 5 seconds, press button on harmony, the IRLinc starts blinking, and when I try to add button, this time the ISY did nothing. It didnt find the 2nd "device".
  23. So the net of it is this: Harmony has now defined an IRLinc 2411R in their database. I added the IRLinc 2411R as a lighting controller on my Harmony 1100, which then created the buttons that match the small credit card remote that came with the IRLinc reciever. Once I do this, I should then go into the ISY and do "Add button from IRLinc Reciever" and that would then define the node that I can associate with a program. Am giving this a try...
  24. I think my issue is that my IRLinc isnt doing what the steps state. I did exactly the steps outlined: 1) On the Harmony remote, define the ISY99/IR 2) Open ISY admin console 3) Import the default IR codes 4) Went to Link management - Define new IRLinc Reciever button 5) Went to the IRLinc and pressed the set button for 5 seconds 6) From the Harmony remote pressed the 1st button (IR001) 7) Then nothing happens, it should blink and them I press ok in the ISY console, but that blink never happens
  25. I guess that is where my confusion lies. What SHOULD I see in the ISY that would let me connect it to a program when I point my remote control at my IRLinc?
