DavidJ
Everything posted by DavidJ
  1. Vendor replied and said that this device is not compatible for ISY994i.
  2. I am trying to include the 'Minoston S2 remote control switch (800S)' 4 button z-wave switch to my network. It successfully "includes", but it is only visible as a single device on my ISY994i when using the 'UD Administrative Console'. As such, I'm not clear on how to write a program to test the button press of the for individual buttons. I'm clearly missing something. I saw the solution in the link below but cannot find the option "turn on compatibility mode and synchronize - update with interview" so I'm assuming that only applies to ZMatter. Here are the status of my system/updates (I know '2020' was a long time ago, but to this point I was perusing the "don't touch it if it works" method of firmware updates! ). Any help would be appreciated.
  3. @MrBill and @asbril ... thank you both. I'll upgrade sometime in the next couple weekends to see if it makes the ZEN16 relays accessible. If not, at least I'll be upgraded! You guys are awesome.
  4. It is 4.55 = 300 series. So I will follow your advice to find instructions to update to 5.0.16C (I don't use "adjust scene"), and wait for Polisy. You are super helpful! It's people like you that make this fun.
  5. Have about 20 Insteon's (switches, thermostats, relays, water sensors), about 15 Zwaves (mostly switches, some temp sensors), and probably 20 simple active programs. I will do some searching for the Zwave 500 series and whatever "Polisy" is. Up till this point it's been super simple to add devices and programs... but maybe after a solid 9 years of use it is time for an upgrade!
  6. Thank you MrBill. I tried updating my UI several times and couldn't get it to work. But adding the Xmx parameter must have done the trick. With the update, and after excluding/including the ZEN16 Zwave device, the behavior remains the same. Hoping @asbril has some insights. Edit: Added Z-Wave version below.
  7. Hello, I'd like to individually control the three relays in the Zooz ZEN16. However, after including the Zwave device, it shows as a single "On-Off Power Switch" in my network... not as three separate switches which I was hoping for. Toggling that switch sets all three relays on/off. Were my expectations to high, or am I just missing something?
  8. Of the two measures (temperature and humidity), it seems that temperature would be the more important data point to store in the log this frequently. It's as though the programmer was debugging humidity measurements and forgot to turn off this logging feature!
  9. Has there been a solution posted to turn off this excessive logging of humidity for 2441TH? I plan to install 4 units and it makes the log difficult to comb through.
  10. Thanks guys! I mis-read the manuals, and was quite surprised when I found 5v across the GND and S terminals. I'll look into the relay or optoisolator approach and give it a go.
  11. Hi, I'd like to use the 12v power-on trigger from my Panasonic projector to turn on a "Now Showing..." light. I get how to turn on the light, but I have a question on the triggering. What device do I need to sense the on/off 12v trigger from the projector? A 2450 IO Linc? Thanks.
  12. Thanks for the code Mike!
