Kev1000000
Everything posted by Kev1000000
  1. Paul, thanks for the help! No, the local web server is also not responsive when it gets in this state. I am trying to access the REST API. I'll try and pull the logs when it gets in this state. Since I can get to the admin console via the portal, should be easy to pull the logs. Good idea.
  2. Very recently, the local API on ISY994i appears to go down/unresponsive for long periods of time. It does eventually return (downtime is around 4-12 hours usually), but the instability is causing my integration into my custom interfaces to be very unreliable, and now the wife is getting upset ? I can still access the ISY through the portal, and all of the local INSTEON communication + programs operate just fine. It's simply the local access of the API that is seemingly going down. Any ideas or areas I should look into to help resolve this? I am FW version 4.7.3.
  3. I have, they were beyond useless
  4. Haha, that's the question I am trying to figure out!
  5. Q1: Nothing happened to the physical devices. They are easily controllable via ISY, the API, etc. Q3: I am using the Optimized for Smart Home skill, not the custom "ask izzy.." I know everything on the ISY-side is fine. ISY didn't lose communication to the devices, the ISY API works great with these devices, and if I add spoken word names to these devices in my wife's account, the Alexa app can discover them. It is JUST my Alexa account that cannot discover any of the devices/programs I've added spoken words for. I have a bunch of them added on my account, Alexa just never finds them. I assumed I just lost the auth token or something, so I already disabled/re-enabled the skill dozens of times and re-linked my Amazon account via the ISY Portal. Nothing ever solves it though. My Alexa account never finds the devices.
  6. They do not exist within the Alexa app, but they exist within ISY and the Portal. Alexa "not pulling any of them" means Alexa doesn't find those devices during the "Discover Devices" process (only on my account).
  7. All of the devices, programs, and scenes exist. Alexa just doesn't pull any of them that are associated with my account. Any devices, programs, and scenes that are associated with my wife's account work just fine and are discoverable via Alexa. This started happening out of the blue. No changes from my end.
  8. About 30 for my account, 15 for my wife's.
  9. No devices are discovered at all on my account.
  10. For over a year, I have been running two Amazon Echos in my home, both on separate accounts (as described by the Wiki), with near 100% reliability. The two accounts are mine + my wife's, and we're in an "Amazon Household." This is has been perfect up until two weeks ago. On my account, no devices can be discovered at all. My wife's account discovers devices and works just fine. I've already tried... Disabling/Re-enabling the skill on my account. Unlinking/Re-linking my amazon account through the ISY portal. Disabling the skill on my wife's account and enabling the skill on my account. Factory resetting the Echo De-registering the Echo from my account and re-registering. If I use the "switch accounts" voice command, the Echo that normally doesn't work will work when logged into my wife's account, so clearly this isn't a hardware problem. For whatever reason, my account can not communicate to this skill correctly, even after doing all of the above troubleshooting steps. Anyone have any ideas? I am at a loss.
  11. Lee, I will try out the TriggerLinc idea. I'll report back the results. Great idea! Klundy, the reason I didn't want to go that route is, anyone could brute force the garage door open. If that happens, my scenes would fire, which includes unlocking my door to the house. If I go the wireless device route, then only that button press would fire my scenes, making it similar to a key. Bulletproof? No. But I do feel it's a little more safe than relying simply the status of the Garage door. Although, I do assume the Garage door I/OLinc works based off of the door sensor. Does the I/OLinc receive an event from the garage door opener, which would only fire if I pressed the garage door opener button? If so, that option may be the best. I just assumed it all worked based off of the door sensor. Thanks for the help, guys.
  12. I am trying to find some sort of device combo that will allow me to send wireless commands to the ISY via a small remote/button of some sort. The idea is, I want to place a small button in my car to set my house to either "HOME" or "AWAY" mode. Yes, I could use my phone, but that requires me to take it out of my pocket, load the app, and then find the right buttons, etc. I want a very simple remote I an mount in my car that can talk to the ISY. I would like the range to be ~200ft ish. So, ideally, this is how it would work. I leave for work and press a button to set my house in away mode. The following will happen: [*:b0qrvd53]Garage door will close. [*:b0qrvd53]All lights off. [*:b0qrvd53]Security Cameras on. [*:b0qrvd53]Door will auto-lock (via MorningLinc) When I arrive home while just pulling into my driveway, I'll set the house into "HOME" mode. The following will happen: [*:b0qrvd53]Garage door will open. [*:b0qrvd53]Entry light on. [*:b0qrvd53]Security Cameras off. [*:b0qrvd53]Door will auto-unlock (via MorningLinc) The only missing link is the button I can mount in my car that will talk to ISY natively without having to run a separate dedicated PC. Ideas?
  13. Well, I deleted the device and re-added it, and it seems to have fixed the problem. The timer is now getting reset, and things seem to be working as they should. Haven't had too much time to test all scenarios yet though. Thanks again, Lee.
  14. Ahh, very nice way of debugging! Alas, I have see no X10 events in the event viewer. It seems the ISY is getting the events from the MS, but for whatever reason, ISY thinks the MS in question is not the same one I named and using in my program. I only have 1 MS.
  15. Lee, first off, thank you for the continued help. I really appreciate it. It looks like I have successfully enabled occupancy mode. Checking the event viewer, I see events hit on every LED blink. Success! However, my programming must not be correct, because my 1stFlrStrCaseDetect program does not fire every time the MS blinks, which I assume it should. Any ideas?
  16. Lee, I've tried setting the device in Occupancy only mode (which I believe is unchecking the first checkbox in Set Options for the MS. I've also enabled "On only" mode (both on the jumpers and through ISY), and still, it my MS will not resend ON commands every time motion is sensed.
  17. Any chance I can set occupancy mode from ISY?
  18. I am new to Insteon/ISY and I am having trouble figuring out how to perfect my automated staircase light. Essentially, I want to... [*:125jw7to]When motion is sensed only when dark, instantly turn on my master dimmer (another dimmer is hooked up in a 3-way virtual). [*:125jw7to]After 10 seconds, slowly fade out the light for 10 (ramp rate) seconds. [*:125jw7to]If any additional motion is sensed inside of the 10 second window, restart the 10 second timer. [*:125jw7to]Double tapping (fast on) any of the two dimmers will override the motion sensor and keep the light on indefinitely. [*:125jw7to]Double tapping (fast off) any of the two dimmer will return control to the motion sensor, restart the 10 second countdown timer. I tried to set this up, but I am having some issues. First issue: The timer never restarts. Regardless of what I try, the lights dim after 10 seconds, even I am jumping around by the MS. Second issue: After the light turns off, I have to leave the area for the light to come back on. It's almost as the MS still thinks I am near it, and won't resend the ON command. This is uber annoying. Third issue: As I am using the built-in photcell of the MS, I think that sometimes the MS thinks its light enough only because the stairway light is on. Is the MS smart enough to know when the load is on to not take any new photocell values? Here is my setup. Where have I gone wrong? First, I have a scene named "FirstFloorStaircaseThreeWay." That scene has the two dimmers and the MS as controllers. I have 4 programs to try and achieve my results. Program 1 - 1stFlrStrCaseDetect If Control '1stFlrStrwayMotSens-Sensor' is switched On And $FirstFloorStrCaseManualMode is 0 Then Stop program '1stFlrStrCaseTurnOff' Run Program '1stFlrStrCaseTurnOff' (Then Path) Else - No Actions - (To add one, press 'Action') Program 2 - 1stFlrStrCaseTurnOff If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Wait 10 seconds Set Scene 'FirstFloorStaircaseThreeWay' Off Else - No Actions - (To add one, press 'Action') Program 3 - 1stFlrStrCaseManualMode If Control 'Bottom Stairway Dimmer' is switched Fast On Or Control 'Top Stairway Dimmer (Master)' is switched Fast On Then $FirstFloorStrCaseManualMode = 1 Else - No Actions - (To add one, press 'Action') Program 4 - 1stFlrStrCaseManualModeOff If Control 'Bottom Stairway Dimmer' is switched Fast Off Or Control 'Top Stairway Dimmer (Master)' is switched Fast Off Then $FirstFloorStrCaseManualMode = 0 Else - No Actions - (To add one, press 'Action') Any help would be much appreciated!
