anthon710
Everything posted by anthon710
  1. Thank you Jimbo.Automates for all your help! I discovered the problem so I wanted to post it in case anyone else has the same issue. It seems that if you have more than one device trying to talk to the Elk M1EXP, then it will throw that error. The M1EXP is only able to talk to one device at a time.
  2. Thank you. Yeah I’ve been baffled by it. I will take a look at my elk system again and see if there’s anything odd that I spot there. Sent from my iPhone using Tapatalk
  3. Hey Jimbo, any chance you could take a look at this today? I really can’t seem to figure out what the problem is. Sent from my iPhone using Tapatalk
  4. Just bumping this up. Thanks Sent from my iPhone using Tapatalk
  5. I'm receiving the following error and I cannot figure out where the issue is: 2024-03-08 17:41:26,623 ELK-10623 udi_interface ERROR Controller:timeout: ELK Controller: Timeout sending message SD!!! 2024-03-08 17:41:33,372 ELK-10623 udi_interface ERROR Controller:timeout: ELK Controller: Timeout sending message SD!!! 2024-03-08 17:41:38,382 ELK-10623 udi_interface ERROR Controller:timeout: ELK Controller: Timeout sending message KA!!! 2024-03-08 17:41:47,157 ELK-10623 udi_interface ERROR Controller:timeout: ELK Controller: Timeout sending message SD!!! 2024-03-08 17:41:52,175 ELK-10623 udi_interface ERROR Controller:timeout: ELK Controller: Timeout sending message KF!!! 2024-03-08 17:41:57,185 ELK-10623 udi_interface ERROR Controller:timeout: ELK Controller: Timeout sending message CS!!! 2024-03-08 17:42:02,190 ELK-10623 udi_interface ERROR Controller:timeout: ELK Controller: Timeout sending message SD!!! 2024-03-08 17:42:11,125 ELK-10623 udi_interface ERROR Controller:timeout: ELK Controller: Timeout sending message SD!!! Any help would be much appreciated!
  6. Thank you! Sent from my iPhone using Tapatalk
  7. I'm just migrating from ISY to polisy (I've had it for a while but I've been putting off migrating). I just purchased and installed the elk module but I'm unable to get it to start. I'm receiving the following error in the logs: 2024-03-06 22:16:37,428 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.3.2 Starting... 2024-03-06 22:16:37,434 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2024-03-06 22:16:37,435 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000dbXXXXX_1/./elk-poly.py", line 10, in <module> 2024-03-06 22:16:37,436 MainThread udi_interface ERROR udi_interface:write: from nodes import VERSION,Controller 2024-03-06 22:16:37,437 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000dbXXXXXX_1/nodes/__init__.py", line 3, in <module> 2024-03-06 22:16:37,439 MainThread udi_interface ERROR udi_interface:write: from .BaseNode import BaseNode 2024-03-06 22:16:37,440 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000dbXXXXXX_1/nodes/BaseNode.py", line 1 2024-03-06 22:16:37,441 MainThread udi_interface ERROR udi_interface:write: ') 2024-03-06 22:16:37,442 MainThread udi_interface ERROR udi_interface:write: ^ 2024-03-06 22:16:37,442 MainThread udi_interface ERROR udi_interface:write: SyntaxError 2024-03-06 22:16:37,443 MainThread udi_interface ERROR udi_interface:write: : 2024-03-06 22:16:37,444 MainThread udi_interface ERROR udi_interface:write: EOL while scanning string literal I believe I configured it correctly but can anyone tell me if I'm missing something. Thanks for the help!
  8. Alarm relay doesn't support the protocol that the c1m1 connects on. Elk recommends the following services but they are not the only ones. Cellular services recommended by elk Rapid response Cops grand central monitoring Sentrynet Dial capture devices suggested Telguard tg1 Uplink 4530ex - model number not confirmed
  9. Thanks! Hopefully we will get the ability to bulk adjust everything down to 90% someday.... or export the current settings and import them back in on an excel sheet.
  10. Hi, I have several scenes with 30 to 40 devices in them and I was wondering if there was a way to set levels and ramp rates for multiple devices at once? It's lot of extra work to go through and set each one individually for that scene. Thanks!
  11. Hi, Anyone have any experience or ideas on how to integrate the isy with a baseboard thermostat or any good thermostats made for this? The thermostat i have now has 220v to the controller on the wall. I would think it would have to have some kind of double pole single throw relay (DPST)? Any wireless ideas would be best!
