codyo
  1. Thanks for the info!
  2. I have recently replaced a defective 2486D keypad with a 234-222 keypad. However, after installing the new keypad, it appears as a simple switch device noted as "Unsupported Device 1.66". Is there some reason that this device should not be configured in ISY-99 the same as the 2486D keypad?
  3. Restoring Device resolved the issue. -Thanks
  4. I'm having difficulty setting up a keypadlinc button to act as a trigger for a program. The ISY-99 apparently does not detect the ON or OFF from a keypad button used as a controller. Any suggestions?
  5. I'm having difficulty setting up a keypadlinc button to act as a trigger for a program. The ISY-99 apparently does not detect the ON or OFF from a keypad button used as a controller. Any suggestions?
