raydoc
  1. I have successfully added the device to my google home app. I was not able to add it through the UD Mobile app, it kept erroring out. So now that it is on the Google Home, how do I share it? Sorry for the barrage of posts. I see in my admin console ZM 002.1 On-Off Switch (Matter Device). I see no way to rename it. I assume this is my valve controller as I've added no other Matter devices.
  2. Thanks! Will try. EcoNetControls. I'll get a model off of it and post it. It worked great with the ISY but could not be made to work with the Eisy. On the other hand, my Z-way Yale door lock actually works with the Eisy where it did not happily coexist with the ISY.
  3. My old master water valve device was Z--wave and no longer works with the Eisy (it did work with ISY) supposedly due to a change in Z-wave protocol. They had me upgrade to a Matter over wifi control but I cannot figure out how to add a Matter device through the admin console. Any help would be appreciated. EcoNet ControlsBulldog Matter Solutions | Matter Certified Smart Valve KitsDiscover Bulldog Matter Solutions from EcoNet Controls, including Matter certified smart valve controllers, WiFi starter kits and accessories. Easy installation, future-proof integration with Matter o
  4. raydoc posted a topic in eisy
    I have a EcoNET Bulldog water valve installed. This is a z-wave device that turns off my main water valve. It used to work with the ISY but the eisy cannot find it. I've turned off the S2 option but it still cannot find it. The company is saying that the issue is that the eisy cannot link to the EVC200 control module. Anyone have any experience like this? The "solution" is a new one that is matter over wifi for $100.
  5. I have been working with UD tech support who have been great. I luckily had a HDMI monitor and USB keyboard lying around to plug in to the eisy to do troubleshooting and enter command line commands. Still not quite there but better. I suspect it had a bad update cycle and got borked.
  6. raydoc replied to raydoc's topic in UD Portal
    No joy. Put in a ticket. Bummer, can't run any of my programs.
  7. I did a router and eisy power cycle and it did not connect. Currently looks booted, the ethernet port light flashes and the switch sees traffic on its port but no eisy connect. I'll open a ticket. Hauling a monitor and keyboard to where it is will be "interesting" It is up on a shelf in the basement with the switches, NAS boxes, etc.
  8. The router is showing it to be offline.
  9. raydoc replied to raydoc's topic in UD Portal
    I'll try the router cycling. Thanks.
  10. We had a brief power failure as the generator came up and switched over. The cable modem was not on UPS packup (is now) so internet dropped. When power came back up, it seems the Eisy is up but I cannot find it with IoX finder and the portal says it is disconnected. I have power cycled it (front button is blue) and the switch seems to be getting data from the Eisy. I have power cycled the PLM as well. The Eisy still looks to be offline. Any ideas?
  11. raydoc replied to raydoc's topic in UD Portal
    Also, IoX Finder cannot find my Eisy.
  12. raydoc posted a topic in UD Portal
    We had a brief (hour) generator run today due to a downed tree. The internet stayed up but the Eisy had a brief power cycle (it was not on the UPS at the time, it is now). Since power has come back up, I continue to get portal disconnect messages. The Eisy is up (blue light on power switch) and all networking is up and running. Not sure what I should do next. I did power cycle the PDM again. Thanks.
  13. My EISY has stopped controlling one of my 6-button wall switches. The local load is the one that I am using for a reading lamp by a chair and although the thing is programmed into the EISY (brought over from ISY) it does not seem to be seen by the EISY. Light state does not show up and EISY cannot control it. Any suggestions for first step next for troubleshooting? Thanks and Merry Christmas!
  14. I am trying get my Yale assure z-wave lock to work through eisy to the google home portal. It used to work with my ISG. Now I can see and control the lock through the eisy portal but I cut get it to show up as available to the google portal. Any ideas? I am not terribly z-wave centric, I have lots of Insteon stuff.
  15. I have installed a Yale Z-wave lock and have successfully added it through my eisy. I can’t figure out how to make it available through the portal for google voice and home integration. thanks
