webminster
  1. webminster replied to drprm1's topic in UD Mobile
    That did not work for me. If it comes up like above with the favorites messed up, clicking away and back to favorites shows me the same screen. Even force closing the app doesn't necessarily reset it. What has worked is running a sync, but why?
  2. I'd like to hear an official position on the continuing support of Polisy. Paid about $375 back in 2022 for my Polisy, and it's still running fine. Since the eISY on the UD store is another $352, that's a lot of money for 3 years of service on the Polisy. If Polisy can't take newer upgrades, a discount for newer units would be nice.
  3. Well, yes, there are reasons, including: * lack of time, between family and new job; * I've seen that some people have had some issues with the polisy upgrade, and I don't have the time to do it, or troubleshoot an upgrade gone bad. I'm on 5.8.4 ATM, and not having issues, so I want to put it off to a time I have time. And not happy getting reminders 3 times a day, including middle of night. It seems that the only way to stop the upgrade messages on UDM is to disable PG3 notifications, which also probably kills the plugin connection notices as well. Wish there was more control over which messages could be suppressed... -Alan
  4. Actually, turning off the system notification in UDM did not help. I still got an upgrade available notification.
  5. Appreciate the answer. Is there something that defines what all is suppressed by that, assume it isn't just the update notification.
  6. There's an update for IoX I don't plan to run soon, but I'm getting 'Upgrade available' notifications on UD Mobile about 3 times a day (including at 4AM). Can someone point me to a procedure to disable this sort of alert? Don't want to disable all notifications. Thanks in advance. -Alan
  7. Thanks, that's helpful, got it working. The note about the variable/program startup refresh was good.
  8. I'd like to create a favorite that can enable/disable a behavior, using a state variable. Swear I had this work before, but now I can't replicate it. What I've tried to do in UD Mobile is to create a favorite from a state variable I have in IoX. I'm using that variable as a condition to enable a program folder. I've tried to change the properties of that node's View Type to "switch", as I'd like to create some sort of toggle. What I've seen doing this is that the switch toggle then flips the value of the state variable between -2 and +2 (depending on precision - higher precision shows like -2.14 and 2.14 for instance). I also note that the toggling isn't completely deterministic - sometimes the state of the toggle doesn't correspond to the numeric value, as in toggling the switch from 2 (on) to -2 (off) shows the switch graphic go to off, then back on, even if the value is -2. I assume this isn't a supported way to control a state variable, but is there some way to create such an effect? Thanks in advance.
  9. Same symptoms observed here.
  10. Thanks for that info. Too bad, I assumed it would be stored in a more stable location.
  11. For some time, I've had an issue that is a bit of an annoyance. Hope someone can let me know if this is fixable. I have IoX and admin console 5.8.0 running on my Polisy, and current Java on Windows 10 on the client side. Sometimes when I launch the admin console from the IoX Launcher, the window forgets the size of the window as I left it, opening full screen. Also, all the hierarchy is expanded on the left side. I reset the window size and the folders opened to my favorite look, and close the console. If I launch it again, the window opens like I left it. This is good for awhile, until it reverts back to full screen. Have not found a correlation of this and any other things I'm doing (not Java updates, etc.). Is there a way to stop this behavior? Thanks in advance. -Alan
  12. Michel finally logged in via remote and got the issue fixed it seems, update either installed bad or incomplete. Thanks all for entertaining questions.
  13. I was always replying from web site. I finally got a reply after 4 days by mailing to the sales email address. They said in their reponse they do NOT get a notification.
  14. I've at least finally gotten something today from them saying they didn't respond cuz they don't get notifications when someone replies. I'm trying to work out a repair or replacement with them. This has been insane.
