rmlinnovator
  1. rmlinnovator posted a topic in ISY994
    n/a
  2. I think you are right about this Lee. Looks like I would have to buy another controller if I want independent control. Will see what I end up doing.
  3. I currently own the MorningLinc controller and 1 morninglinc deadbolt. I am interested in adding another deadbolt but have a question on functionality. If I add another electronic deadbolt will I be able to independently control lock/unlock via the controller? Or will I only be able to lock and unlock all deadbolts simultaneously?
  4. Great suggestions. Thanks for pointing me in the right direction. I did not even realize there was an option for > and < which makes it a lot easier. Glad we have this community to get ideas from.
  5. I am looking for some suggestions to create a program for this unpredictable spring Weather. I have an ISY, Insteon Thermostat, and 4 Insteon controlled celing fans. I would like to create a program so that if the temp is above 70 degrees according to the thermostat that the ceiling fans kick on in the evening at 6:30pm. (This part I have figured out and working) I would then like to create a program so that if the temp falls below 70 degrees in the evening the ceiling fans automatically kick off. I could have the the program check at various times during the evening. Just trying to figure out the best way to do this and would love any suggestions.
  6. Ok Lee will try moving when adding to scenes. It is already pretty distant from my PLM but I will try taking it further maybe to an isolated circuit like the one in my bedroom. Also the Factory Reset thing is a bit weird on the MorningLinc. When continuing to hold the button when I replug the MorningLinc the light never comes on if I am holding the button. I just usually hold it for like 10 seconds then let go then the LED comes on. I hope I am resetting it. Can't really tell.
  7. I am having a similar problem. I am running the latest version of stable firmware on the ISY. I cannot add my morninglinc to more than 1 scene. If I do so I loose connectivity from the ISY. Any idea how to fix this. Programs work fine but I like scenes because they are faster.
  8. I have a solution for you bro. Just trying to accomplish the same thing. I think this should work for you just fine: Create another scene called LED Button Update. Set the keypad link button for your fan as a responder to that scene. Setup a timer to turn off the LED Button Update Scene about the time you go to bed. As long as the fan is already on an running before you go to bed then the keypad link button will turn off but fan will still run since it's not part of the LED Button Update scene.
  9. I just added a MorningLinc Insteon Controller. When linking to the ISY I now have two device one with -On and one with -Off. They both do the same thing. I am confused why I see the 2 devices?
  10. Gotcha! Yes I think I understand now. I had been adjusting the scene and not the Keypad button. I am guessing this should work now.
  11. Hm...Thanks Lee yes that is the way I have it setup but it doesn't seem to work. (Master Bath KL (load) is my primary On button)
  12. Lee thanks for the reply I am using the 6 button Keypad Link with the Load button as the controller of the scene. Which is signified as Master Bath KL (load) above. (The Scene is Called "Master Bath") Not sure what I need to do different to make this work.
  13. Ok I am trying to figure out how to adjust my bathroom lights to come on at a lower level during mornings and nights. I have created a scene. Assigned the keypad load button as the controller of the scene. I then have created the following program: If On Mon, Tue, Wed, Thu, Fri From 6:00:00AM To 7:30:00AM (same day) And From 11:00:00PM To 5:00:00AM (next day) Then In Scene 'Master Bed / Master Bath / Master Bath' Set 'Master Bed / Master Bath / Master Bath KL (load)' 25% (On Level) In Scene 'Master Bed / Master Bath / Master Bath' Set 'Master Bed / Master Bath / Master Bath KL (load)' 30.0 Sec (Ramp Rate) In Scene 'Master Bed / Master Bath / Master WC' Set 'Master Bed / Master Bath / Master Bath WC' 25% (On Level) Else In Scene 'Master Bed / Master Bath / Master Bath' Set 'Master Bed / Master Bath / Master Bath KL (load)' 70% (On Level) In Scene 'Master Bed / Master Bath / Master Bath' Set 'Master Bed / Master Bath / Master Bath KL (load)' 0.5 Sec (Ramp Rate) In Scene 'Master Bed / Master Bath / Master WC' Set 'Master Bed / Master Bath / Master Bath WC' 60% (On Level) However, this isn't working for me lights come on to regular set levels at all times. Can someone point me in the right direction.
  14. Great Feedback. Thanks for the advice guys. This is very helpful info which has helped get my mind rolling on how I want to program this.
  15. Just getting started programing my home. I have some keypadlinc's by my front door and garage door. I want to make 1 of the buttons (button H on the 8 button) an away button so that I can hit it and have it turn off all the lights and turn down the Venstar. What's best program or scene? How do I cross link the buttons so the status updates on both keypadlincs?
