bruinlax
Everything posted by bruinlax
  1. Hi, I'm trying to connect to an SCE Meter with my isy994zs, and I've followed the instructions http://www.universal-devices.com/docs/p ... 994iZS.pdf i click enabled, refresh smart energy, but it never says its UUID nor does it never say anything about scanning, as shown: http://i.imgur.com/a4RDDuv.png Am i missing something? running 4.0.5
  2. awesome thanks for the prompt reply. I was pulling my hair out looking at random zigbee gateways when i discovered through luck you guys over one, which is all i'd ever want. Hopefully it gets more publicized.
  3. bruinlax posted a topic in ISY994
    Hi - I'm a southern california edison customer - and realized i have a smart meter. Question 1: "ISY994i ZS/IR PRO" should it work to get realtime KW from my smart meter? (details from power company below) ON the company's website FAQ ( http://tinyurl.com/clohjvr ) it says: "To successfully connect with the SCE smart meter, your device must support ZigBee communications and be Smart Energy Profile 1.0 or 1.1 certified." Question 2: I currently am an owner of an ISY 99iProIR, and on this site (i think yours) it says there's an upgrade price of 229 for the "ISY994i ZS/IR PRO". I assume it's different hardware - so does that mean i do a swap? applicable website: http://www.homeorchestrator.com/UDStore ... ctPurchase
  4. yep - my appliance links show up as statuses in programs. oddly, the outdoor appliance linc shows up as a "Control" item as well i'm considering ways to come up with a status solution. maybe a plunger or a magnetic contact closure and glue a rare earth magnet on the end of the deadbolt. maybe this http://www.smarthome.com/7352/Surface-M ... sed/p.aspx plus a rare earth magnet or a switch somehow in the doorframe: http://www.radioshack.com/product/index ... age=search but I'm trying to avoid opening up my doorframe.
  5. nope, i don't see a status node for it. under "condition" - then "status" when adding it to the program. it does have a "current state" under My lighting - but that isn't accurate because of a hardware limitation w/ the mobilink. (it only changes when you lock / unlock w/ the isy - unlocking w/ a key will not set off a status) - and even then it doesn't show up as a program status, so it's moot. It'd all be solved (plus it'd work if opened with a key) if i install a plunger switch to determine if the deadbolt is locked and run through an I/O to set off the ISY program but that seems like an terrible amount of work. (anyone done that?) I'm guessing the variable method might be ok. . . anyone see any issues with it?
  6. I'm trying to write a basic program, that if i open my door (morninglink) via mobilink, if it's past sunset it also turns on my hallway light. I'm having trouble thinking of a way to trigger the program. I tried creating this program below - but leaving it not "enabled", so that it doesn't continuously run, and run it manually from the phone, but i can't seem to get non-enabled programs to show up in mobilink. Then i tried to create a scene (w/ no devices in it) that i'd turn on from the phone, but that doesnt' seem to set off a condition i can add to the if part. So far the only solution i can think of is to have a variable that from my phone I increment to 1, then have the program check continuously to see if it is a 1, then set it back to 0 at the end. But that seems overkill. I'm guessing i'm missing a basic way to think about it basic program thoughts: If From Sunset + 20 minutes To Sunrise - 20 minutes (next day) Then Set 'Frontdoor-2' Unlock Door Set Scene 'HallwayEntryLight' On Else Set 'Frontdoor-2' Unlock Door Edit: after reading http://forum.universal-devices.com/viewtopic.php?f=26&t=6395&p=48518#p48518 maybe my idea about using a state variable as the condition isn't too overkill, but clean?
  7. bruinlax replied to polexian's topic in ISY994
    this doesn't work for you? it's a standard schlage tumbler, i don't know of one if you need kwikset specifically, but these are rekeyable. http://www.amazon.com/gp/product/B001JD ... W22F1RB0TW
  8. well - i just installed 3.1.7 and *so far* (about 75 runs of scripts) can no longer reproduce the error, I'll let you know if it changes, but in the meantime, thanks for the great support. oh - and i wasn't subscribing to the feeds at all - just running one off scripts (turn on lights etc) on a windows machine.
  9. here is the error log after i reproduced the error: - I let it sit over night and it didn't gain connectivity again. Wed 2011/09/14 12:39:28 AM System -10011 n/a Wed 2011/09/14 12:39:32 AM System -10011 n/a Wed 2011/09/14 12:39:49 AM System -100 No network connection Wed 2011/09/14 12:42:19 AM System -170001 [uDSockets] RSub:6 error:6 Wed 2011/09/14 12:42:29 AM System -170001 [uDSockets] RSub:6 error:6 Wed 2011/09/14 12:42:29 AM System -10103 n/a Wed 2011/09/14 12:42:39 AM System -5012 n/a Wed 2011/09/14 12:45:48 AM System -10103 n/a
  10. i discovered i'd lose connectivity when I would run a vbs script every now and then - (they'd only run one at time). couldn't access the ISY from any computer. To trouble shoot -i wrote one simple program on the ISY that increments a variable, and i would run a vbs script that calls the program via the REST every few seconds manually until i could get it to freeze. (again about 5-20 runs at every few seconds) The odd thing now is I put that code in a full VB .net program, and looped it 200 times (2 second intervals), and i couldn't get it to freeze . so it's only when i put the code in a .vbs and run it through wscript hmm - i can work through a full vb.net program, but just curious if there's any interesting debugging i could do via the rs-232 interface to see what's going on.
  11. So here's my setup i'm running an ISY-99i PRO / IR on 3.1.6 The ISY seems to hang / lose network connectivity after running a few VBS scripts to the REST interface here's what i've determined: 1) I can run the scripts fine from 5-20 times then the isy loses network connectivity 2) The scripts will then report back: The system cannot locate the resource specified - 800C0005 and i can't access the java applet anymore / the webserver times out until i reboot the ISY 3) i can still connect to it via serial and hyperterminal when it is hung 4) I can seem to put the URLs into Chrome and run them as many times as i want without problems (not after it is hung - just that Chrome requesting the REST commands seems not to make it) 5) I put the code in visual studio and looped it 200 times, and couldn't get it to hang either, but when i put it in a .vbs file, then it hangs after a few runs. It seems like it just runs out of sockets or something, and then refuses to open another connection. Below is a sample of my code: Option Explicit Dim restReq, url, userName, password Set restReq = CreateObject("MSXML2.XMLHTTP.3.0") url = "http:///rest/nodes/47403/cmd/DON" userName = "admin" password = "pw" restReq.open "GET", url, false, userName, password restReq.send
