Non Sequor
  1. The lights on the network jack are not lighting at all, at any time since this started.
  2. There are no connection lights, despite switching cables with another device that is connecting properly (and continues to work properly with the cable that I was using for the ISY). It's definitely not an IP conflict, because there is no connection in the first place, and also because I don't have any devices not using DHCP, including the ISY. I haven't tried the factory reset, but it seems like it wouldn't accomplish anything since it's only advised for conflicts with a fixed IP that can't be resolved. Unless there's something else to try, this looks like an issue that will require an RMA.
  3. I'm having an issue where the ISY is executing programs properly, but it's impossible to contact it over the network. The memory and error lights are flashing. I've tried changing the network cable, trying a different port on the switch, and rebooting the ISY. The switch has lights on each port indicating a connection and I'm never seeing even a temporary connection when I connect it to a different port or reboot the ISY. This seems to point towards the issue being with the network interface on the ISY itself. Is there anything else that I haven't ruled out?
  4. I'm interested in an option to point the weather bug module at a non-Weather Bug RSS feed. I wrote a script that queries my neighbor's web accessible weather station and spits out the data in the same RSS format as Weather Bug uses. I had been planning on setting up some sort of custom DNS proxy or routing setup to redirect the ISY to my RSS transparently, but I never got around to finishing that part of the project.
