mrxmas
  1. uninstalled java and reinstalled. downloaded the launcher file, and i get a screen that says "select an app to open this .jnlp file" Java (TM) web launcher Word Javaws i picked the "Java (TM) web lancher. and it keeps going back to the Select an app window
  2. My Launcher shortcut on my laptop wont work anymore. it says "the item 'javaws.exe' that this shortcut refers to has been changed or moved, so this shortcutd wil no longer work properly. the shortcut on my desktop computer still works.
  3. mrxmas replied to mrxmas's topic in IoX Support
    Thanks for your help, with help from my brother we go the icon installed.
  4. mrxmas replied to mrxmas's topic in IoX Support
    I ran the lancher setup and it ask to select app to open this ,jnlp file
  5. How did I add launcher icon to a new computer
  6. mrxmas posted a topic in eisy
    What is the cost of the isy portal?
  7. mrxmas replied to mrxmas's topic in ISY994
    My isy is using moblinc connect and am using intseon devices. I don't know what the default username and password is
  8. mrxmas posted a topic in ISY994
    I updated my isy994 to 5.3.4 now my password and username won't work
  9. Hi All We are consdering changing from Comcast Xfinity to Direct TV or Dish Network for our Tv. I have the ISY 994i pro, connected to our wfi router and MobiLinc Connect. Direct TV and Dish Network would also need to be connected to the wfi router. Is anyone using Direct TV or Dish Network connected to a router? Are there any problems or conflicts with the ISY and Direct or Dish receivers connected to the router?? Thanks for any information anyone has Steve
  10. mrxmas replied to mrxmas's topic in ISY994
    Thanks LeeG, it never finished on the screen. I closed the program. When I reopened the Admin C and everything worked and shows current status So I don't know if it was my laptop that was stuck or what. But all is good. Thanks again
  11. mrxmas replied to mrxmas's topic in ISY994
    Hi Ok I have my new PLM. I followed the instructions for restoring the PLM. It has been going for over an hour. There are all the green write squares and one that is writing (which and been writing for 40 minutes) There was a BUSY square with the progress on it. it has since finished. however the green squares and the Writing square are still there. I have never done this before and am not sure how long the process is. I have a access point that as been blinking but most of the appliance module are not. Any advice??
  12. mrxmas replied to mrxmas's topic in ISY994
    Thanks LeeG, I appreciate your help. The new PLM was ordered today so it will be a few days before and can replace it. It sounds like the PLM failure is common, I have read reviews on the Smarthome site. I guess I was lucky as mine has lasted close to 3 years. Thanks Steve
  13. mrxmas posted a topic in ISY994
    Hi Apparently my PLM has died. I have a new one coming. I am using a ISY 994i pro and was wondering what is the proper procedure for replacing it? Do I need to delete the old one even though it has died? Thanks for any advise you can give me. Steve
  14. Thank you PurdueGuy, that worked. I learn something new that this system does. It is very complex and I'm sure I have only touched the surface. Thanks again for you help Steve
  15. Hi I have a question on updating a scene a my 8 key keypadlinc. I have a button "Guests" that dims the family room can lighting. I recently changed over the bulbs to LED's and needed to change the dim levels on the scene. It was my understanding that when a scene was changed that it updated any buttons that the scene was associated with. Am I wrong in that assumption? (I have a 994i series system) If I activate the scene from any other place, Administrative console, or Mobilinc it uses the new settings. But the Keypad doesn't. Any help or advice would be greatly appreciated ..
