ejh3
  1. ejh3 replied to bdw72's topic in ISY994
    Michel, I to am getting the security banner whenever I try to get into the Admin console. I have tried clearing my cache, even deleting and reloading java, but I still get the warning and it won't let me in. I have been away from this project for a while but was hoping to finally getting around to upgrading to the 994 that I got from you guys a while ago. Any help would be greatly appreciated. Ed
  2. Thanks! I will try this when I get home later today.
  3. I understand that the isy can't affect the timer in the ezsnsrf but the problem I have is that it only gives a momentary closure unless the timer in the ez is programmed. Is there a way to have the isy see the momentary "on" on the ez and have it trigger a program with a timer? Thanks again
  4. Well it looks like the "on" time for my lighting devices is based on the timer build in to the ezsnsrf. At the end of the linking/programming the ezsnsrf I pressed the button 4 times making it a 2 minute timer. Do you know what variable in the "If" part of the program I need so that the timer is in the isy? Attached is what I have right now
  5. Lee, I think I over complicated the program, this really only needed one program. For some reason I thought I would have to have the one program trigger the lighting program, but I could never get it to work. Once I dumbed it down it worked right away! Thanks for the support! Ed
  6. Lee, I changed the programming to "Run" the light program, but it still doesn't seem to work. I'm gonna troubleshoot the EZSNSRF real quick, I had another program to send me text messages when anyone entered the driveway but it suddenly stopped yesterday. That might mean I have an issue with the EZ device, but i'll double check. Thanks again!
  7. Good afternoon, all! Well, I'm finally getting back to programming my EZSNSRF. All I want it to do is trigger a lighting program that turns two lights on for 5 minutes when I come down the driveway after the sun goes down. I've spent most of the day trying to get this to work, but can't seem to get it to trigger. I know the EZSNSRF works, I see it trigger in the logs. Any help/recommendations would be greatly appreciated. I have (2) programs set up, one is the lighting program *see attached I've tried programming this multiple ways without success, I think it has something to do with my "If" in regards to the EZSNSRF. I've tried programming the "If" of the EZSNSRF with "is not off", "is 100%". Thanks in advance for your time!! Ed
  8. Good afternoon, all! Well, I'm finally getting back to programming my EZSNSRF. All I want it to do is trigger a lighting program that turns two lights on for 5 minutes when I come down the driveway after the sun goes down. I've spent most of the day trying to get this to work, but can't seem to get it to trigger. I know the EZSNSRF works, I see it trigger in the logs. Any help/recommendations would be greatly appreciated. I have (2) programs set up, one is the lighting program This is the other program I've tried programming this multiple ways without success, I think it has something to do with my "If" in regards to the EZSNSRF. I've tried programming the "If" of the EZSNSRF with "is not off", "is 100%". Thanks in advance for your time!! Ed
  9. Thanks xathros! Sent from my iPad using Tapatalk
  10. Well, switched back to DHCP at Michels request and its up and working! Thanks you sir! I would like to go back to a static address, let me know if you know of a workaround.
  11. I can't seem to remember how to do this: I have (3) programs to send emails for my ELK M1 for when the system is Armed, Disarmed and Alarmed. If Elk M1 is armed Then Send email The problem I have is it sends non-stop emails. (ex. If I disarm the system it will send non stop "disarm" emails until I arm the system. Then, when armed, it will send non stop "armed" emails. How do I get the isy to send just 1 email per event? Thanks in advance for your time! Ed
  12. Thanks for the response Michael, After switching back to DHCP I get "Mail server failure" when trying to TEST and email. Any other ideas?
  13. I recently noticed I haven't been getting my email notifications and tried to figure out the issue but was unsuccessful. I originally had a gmail smtp setup that worked for years, but just decided to stop. I pulled up the configuration tab and double checked the addresses and passwords, but when I sent a test an error box came up with "Mail server DNS error". I decided to try configuring using a Hotmail address but was faced with the same error message. Any idea on how I can remedy this? Just fyi-i am still using the 99I, I have the 994, but haven't had a chance to install it. Thanks in advance for your time.
  14. The Elk M1 has one form C relay on the main board. 8 Relays can be added to the main board directly with an M1RB. A combination of 16 Outputs can be added by installing a M1XOV to the databus. It will give you 16 Low current outputs that can do things like power other M1RB's or LEDs. If you need form C relays then use an M1XOVR which will give you 8 relay outputs with 8 low voltage outputs that can do things or trigger another M1RB for 16 relays total. gatchel, Agreed, I am currently using the ELK-M1RB. I do believe this can be programmed to do what I want, do you agree?
