hongfa
  1. I don't think there is any such temperature sensor device. You could use a cheap thermostat, temperature monitor/controller or "temp alert" device hooked up to an I/O Linc. Then you would know whether the temp is above/below the setpoint but not the exact value. This is unfortunately going to be more expensive and more inconvenient than just being able to pull the temperature reading from an Energy Display. But at least you would have local control of the setpoint in the basement. You could also use an EZIO 6I with the analog input and a thermistor but I don't know if this is supported by ISY and it's even more expensive. So I think the best bet is to beg for the Energy Display to be supported for temp readings. Report this post
