william.hullsiek
  1. Okay stupid question - someone at the factory covered a screw with the label.
  2. Is there a procedure for opening the front tab after the screws are removed? I am trying to replace the Zwave controller with the series 500 module and perplexed on how to open the case without breaking the cheap plastic.
  3. I re-wired the Kitchen back in August 2018. At that time, I removed an old X-10 based lighting controller and replaced it with four 2477D Dimmer Controls. (The controls are placed behind the refrigerator) During the August install, I did a factory reset of the Keypad Linc (Air-Gap for 10 seconds, the Set). Configured the Keypad Link to control the various switches (without requiring my ISY controller). That worked great until recently (I had several trades people going through house working on other parts of the remodel). The problem is that Keypad B and Keypad D - no longer control the dimmers directly. So I am trying to see if there is software that can issue the remote set command or configure the Button as a Controller of another insteon device. I typically use my ISY as a Supervisory Control system (time-of-day programming and special events). But trying to avoid use it for localized lighting control.
  4. I have a 2486D Keypad that used to control two 2477D (Button B and Button D). The two 2477D are located behind the refrigerator which is a pain to move without scratching the floors. The two dimmers work from a Mini-Remote. I have tried a restore of the KeypadLinc - which did not solve the problem. Is there a way to electronically Link the keypad link with a dimmer? Is this done with the Device Links table? Basically, I am asking if there is a way to electronically push the set button on these devices? I have access to the keypad link - just not to the dimmer.
