barkster
  1. barkster replied to barkster's topic in ISY994
    i liked lutron but they don't have an inwall plug, ugh
  2. barkster replied to barkster's topic in ISY994
    thanks, that is why I am looking for alternative I have had reliable system for over 10 years untill I removed about 10 switches and now it isn't. I only need about 4-5 switches now and looking to go to wifi switches or something and use my home assistant. I may end up keeping my insteon and just try and add more switches and access points even though I don't need them
  3. barkster replied to barkster's topic in ISY994
    thanks, I am looking into converting to zwave.
  4. barkster posted a topic in ISY994
    I haven't messed with my isy994 in years just chugs along. I wanted to add a dimmer switch to my lights and went searching and can't find any parts online anywhere, all out of stock. Even here the ISY994 is out of stock. I pretty much only have a few switches now is it time to replace with something else?
  5. yeah event viewer has nothing around 10pm but then I cleared it, I missed your msg about posting here. I will check back in morning with it and see. Thanks again for the help
  6. Thank you I will look into it when I get home but just one question. Why does it always work turning it off with mobilinc vs a program or alexa? If noise was issue wouldn't it not go off with mobilinc?
  7. I have found sometimes some of my devices will not go off as expected with scheduled events. For instance my yard lights come on at correct time but they do not go off at 10:00pm as scheduled. If I tell alexa to turn them off it confirms it but does not turn them off. The only way I can get them off is to go to mobilinc and turn off manually. Why would mobilinc work but not others? How can I troubleshoot this? As you can see the last event evaluated true but didn't turn off
  8. Cool, thanks for all the replies, I am trying the time node server and seems to have what I want.
  9. yeah my timezone is set correctly, these are just my observations that I have noticed. Sunset just isn't the correct time to turn on the lights. I have always just done sunset plus 1.5 hours but right now it is dark about sunset plus 30 mins. Winter time works perfect summer not so much.
  10. when we are in DST the sunset it pretty accurate for turning on porch lights etc but when we aren't I have to add an hour to sunset time to because it isn't actually dark yet. Is there a way to check for DST?
  11. awesome thank you for all your help
  12. got it back for now 24hours later. One more question you mention that antifreeze.loop should be disabled. So when it disable and you call the then statement it will still run the then? It seems like when I tried first time with it disabled it didn't run but who know. Just want to confirm that disabled programs can still have the "then" statement executed. Thanks
  13. thanks for all the help, unfortunately I lost power at 7pm and has been out since. I had to drain everything. Let's hope it survived.
  14. You mentioned program wasn't making sure everything got turned off. If it goes above my set point how is it turning off the pumps, etc... it only stops the loop but the pumps are one won't they remain on?
