connorrc
Everything posted by connorrc
  1. connorrc replied to connorrc's topic in ISY994
    This is one of the last modules I installed... Any ideas why it's version number is different for the same type of device? Could this be an issue?
  2. connorrc replied to connorrc's topic in ISY994
    Hi, I have norton Internet Security, I removed the last device I added and also moved the interface module into another electric plug...at this point everything seems to be working again including conductor. It was also working really well both locally and remotely so have been very pleased .. Whatever was causing the communication issues seems to be remediated ... I will now go back and look at what I changed to see if I can determine specifically... Thanks for the assistance! Rob.
  3. connorrc replied to connorrc's topic in ISY994
    I am running the same UI/Firmware, and upgraded to 3.1.15/Cleared cache etc... Not sure I understand the explanation of the finder, am I suppose to close that window, leave it open? I did just ignore the Java warning message... I haven't changed my router/firewall settings, but I am having intermitant difficulties communicating via my android with conductor as well...
  4. connorrc replied to connorrc's topic in ISY994
    Forgot one last question... Do Insteon devices and ISY99i experience the same issues with noise in power lines as x10 devices do? I ask becasue as I noted I am new to ISY and have been using it for over a month or so, and until now it has been working flawlessly... But I know that with X10, things can change as you plug different appliances in etc...
  5. connorrc replied to connorrc's topic in ISY994
    Thanks for the help, I am new to the product... I have been using the application version for about a month now and this just started... aside from the obvious, what's its function... I am assuming that it has to do with other issues I am now just uncovering, guessing it isn't getting the information when it queries and hence the finder comes up? A number of devices are now showing current incorrect information (9 min ramp rate for example vs. the 8.5 seconds I set it to). When I query the device it finds what I expect for settings. But even after I write to device, if I move to the next device and return, then the status is again back to 9 min ramp rate, etc... I also just got this error message.. I haven't changed much and backed up often, so tried earlier settings as well... same issue.. seems to be with communicating with some devices. Could I have messed up the linking and need to clear devices and relink? Or is it in the application installation, and do I need clear out files/setting and re-install?
  6. connorrc replied to connorrc's topic in ISY994
    That fixed the Remotelinc2 errors ... but still getting the Insteon Finder window coming up along with the console...when I minimize things I find this...
  7. connorrc replied to connorrc's topic in ISY994
    I got that straight, cleared Java and it created new shortcuts.... still same error with Finder window coming up but also go an error communicating with Remotelinc2... if I query it, it works... so not sure why it gives an error at startup. May try removing and adding...
  8. connorrc replied to connorrc's topic in ISY994
    Thanks, will try that... Do you know how I create a desktop shortcut for the newer version, one was created along the way somehow but has a lengthy cryptic line.... C:\Windows\System32\javaws.exe -localfile "C:\Users\HTPC\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\17\1fc0a0d1-146025ff"
  9. connorrc posted a topic in ISY994
    I am not sure what changed, but now everytime I start the desktop software I get an error and the Insteon Finder window comes up.. I am running the following version for UI/Firmware... Firmware: V3.1.13 UI: v.3.1.12 ISY 99i/IR The errors I get are the Insteon Finder window comes up with My Lighting and I get "UPnP Cancellation Failed:SID not found [uuid]; Subscriber didn't reply to event:1 [64]"
