verkuild
Everything posted by verkuild
  1. Okay, here's a little update on this issue. There's definitely been some changes in the way Govee interfaces with LAN API now. I had a spare Raspberry Pi, so I installed Home Assistant and the Govee Integration. It see's the Strip Light 2 Pro and doesn't even need an api_key to get there. It only shows it's own set of color and effects, but it can definitely control those lights. Now I'm trying to get eisy-Home and Home Assistant to work together without screwing up my existing set-up. Cheers!, Doug
  2. I think Geddy is on to something. I also purchased a set of 4 Govee RGBWW Smart LED bulbs. I installed one and after getting it on-line with Govee Home, I restarted the Production NS, and Bingo! It see's it and it shows up in the admin console. So the issue seems to be that the Govee Strip Light 2 Pro is not responding to the standard API calls that other Govee products do. I'll start down the path with Govee Support and see if there's anything to be learned from them. Thanks to everyone who chimed in on this issue. Cheers!, Doug
  3. Good to know that I can at least only work in Polyglot to see if I'm making any progress! Still only 1 node, the controller. Is there someone who can understand a debug log, if I capture one? I think I'm seeing an error where the log is showing that it fails when it calls discover. This might be better served if it can moved over to the Govee section under Polyglot v3.
  4. I only have the controller showing. Not the Strip Light 2 Pro I just installed. I can control that with my Fire Tablet running the Govee Home app, and my Echo's as well, just can't seem to get the eisy on-board. Here's my Ployglot page: See, no lights. Is there some kind of naming convention I missed? My name is: "Kitchen Strip Light" in the app. Thanks again for spending some time on this. Cheers!
  5. So I exited the admin console. Logged into Polyglot and restarted the plugin, then logged out of Polyglot. Restarted the admin console and selected the single Govee node, and hit discover. Nothing.... Nothing changes. Are there any settings I need to adjust within the admin console to get this working? Or is it just the api_key in Polyglot and everything should be working? I did enable LAN control within the Govee Home app and requested a fresh API key which was different than one I had been working with, but even deleting the plugin and re-installing it with the updated API key, gives no joy.
  6. I've got the Govee plugin, but when I hit discover, the only thing that happens is the discover button sort of fades in and out. I've waited for a long while, and nothing else seems the change. Where are the Strip Light 2 Pro supposed to show in the admin console? Here's what I'm seeing, after I hit discover.
  7. To DBUSS, yes I've read it, but it's pretty general and not specific to Govee. Thanks. To LarryLLix, Here's where I'm at so far: 1. Install Govee Plugin from Polyglot V3 Store. COMPLETE 2. Obtain API Key from Govee Home. COMPLETE 3. Configure Govee Plugin as detailed in README.md. MAYBE COMPLETE?? See below Now what? Am I done with configuration? Is there anything else to complete while still in Polyglot? Sorry, but even though I've worked with isy systems for years and reading all I can find, after converting to eisy, I'm kind of lost. Thanks for taking the time to show me the ropes! Cheers!
  8. I recently upgraded my 994 system to an eisy Home and was looking forward to using the wide range of Plugins that exist in the PG3 store. I even installed new Govee Strip Light 2 Pro LED lights around my home. Very nice units that I can now control with their app and my Echo devices. So now I'm ready to add control to my eisy. But I really need some step by step help here since I've never used plugins before. I've got my app ID and completed what I understood to be expected, but I'm lost. Can anyone with some experience please help? Thanks in advance, & Cheers!
  9. verkuild posted a topic in eisy
    I was wondering what LED Light Strip manufactures (Feit, Govee, GE) can be controlled by eisy and using what plugin. I'm getting ready to upgrade my ISY994i to eisy and need some info before I make that purchase. Cheers & Thanks!
