jimw01
Everything posted by jimw01
  1. It may be that if only Momentary A is checked, and the timeout is 4 seconds, than an ON command from ISY would be ignored because the relay is already ON. After 4 seconds, an ON from ISY wouuld not be ignored because the relay would have switched to OFF. I have also found, that even though the display for the Sensor may be incorrect, programs that check its on/off condition work properly. However, a Query to the Sensor, will always set it OFF, and not just on the display - it will affect programs that check the sensor. That is, a Query actually does seem to set the Sensor status OFF. On another note: It seems to me, experimenting with 4 IO Lincs, that for the Momentary A to work with Look at Sensor, the sensor must be in the same status when linked to ISY itself, any scene within ISY, and any Insteon device to which it is linked as a responder - I suppose because they are different group numbers as controllers. Otherwise, it will respond differently to an ON command from the different controllers, as it was in different states when linked to each separate controller. Does this make sense?
