CTBigman
Everything posted by CTBigman
  1. Like the title says, I can't get the eisy to upgrade to v5.9.1, OS is FreeBSD eisy 13.2-RELEASE-p11 FreeBSD 13.2-RELEASE-p11 #11 releng/13.2-n254665-f5ac4e174fdd-dirty: Sun Apr 14 22:01:14 UTC 2024 . I perform upgrade as per instructions, it says its upgrading, I let it sit for an hour, clear Java cache, log back into Admin console and under "About" it still says v5.8.4? Any ideas??
  2. Yeah, it's been awhile since I did any modifications besides schedules. I went back and looked at UDI youtube videos and they are so old and out of date they were no help. When is UDI going to update their videos, I think it would help their business immensely.
  3. Thanks guys for the help, I wasn't clicking the On Level button after setting it to 25% on the Switch!
  4. No change with Device Restore. If I run the scene from Iox it works perfect as per my clip, but manually pushing the switch by the entry it goes to 100% ARGHH!
  5. I will try a restore, the levels and ramp are set on the scene and at each switch in the scene. I also tried setting the on level on both switches outside of the scene and it won't update, stays at 100%..
  6. Hello, Have had an issue with my 994iPro not being able to set "on rate" on a 2477D. Just updated to the eisy with a new 2413s and everything seeks okay. Went to fix the issue with the ramp setting and it won't stick. 2-2477D controlling 2 recess in the MB that I want to come on at 25%. Now it gets weird, I can dim manually from both locations, when I turn the scene on from the bed it goes to 25% but if I try the switch by the door it goes to 100%?? The switches are actually on different circuits, the switch by the door is on an AFCI breaker and the switch by the bed isn't. If I run the scene from Iox it goes to 100%. Load is at the switch by the door. I have defaulted the switches and the scene have also deleted the switches and started over fresh and get the exact same result. What next? I don't understand how to decipher the event viewer but I see "Link not Found"? The first group is on/off at the door, second is on/off at the bed. Thanks in advance, Sat 01/13/2024 01:06:36 PM : [INST-SRX ] 02 50 58.9E.2D 00.00.01 CF 11 00 LTONRR (00) Sat 01/13/2024 01:06:36 PM : [Std-Group ] 58.9E.2D-->Group=1, Max Hops=3, Hops Left=3 Sat 01/13/2024 01:06:36 PM : [D2D EVENT ] Event [58 9E 2D 1] [DON] [0] uom=0 prec=-1 Sat 01/13/2024 01:06:36 PM : [58 9E 2D 1 ] DON 0 Sat 01/13/2024 01:06:36 PM : [D2D EVENT ] Event [58 9E 2D 1] [ST] [255] uom=100 prec=0 Sat 01/13/2024 01:06:36 PM : [58 9E 2D 1 ] ST 255 (uom=100 prec=0) Sat 01/13/2024 01:06:36 PM : [D2D EVENT ] Event [58 A0 82 1] [ST] [64] uom=100 prec=0 Sat 01/13/2024 01:06:36 PM : [58 A0 82 1 ] ST 64 (uom=100 prec=0) Sat 01/13/2024 01:06:36 PM : [LINK-INFO ] Link for responder 58 9E 2D 1 not found Sat 01/13/2024 01:06:36 PM : [INST-SRX ] 02 50 58.9E.2D 70.8A.A1 40 11 01 LTONRR (01) Sat 01/13/2024 01:06:36 PM : [Std-Cleanup ] 58.9E.2D-->ISY/PLM Group=1, Max Hops=0, Hops Left=0 Sat 01/13/2024 01:06:36 PM : [INST-DUP 2 ] Previous message ignored. Sat 01/13/2024 01:06:37 PM : [INST-SRX ] 02 50 58.9E.2D 11.02.01 CF 06 00 (00) Sat 01/13/2024 01:06:37 PM : [Std-Group ] 58.9E.2D-->11.02.01, Max Hops=3, Hops Left=3 Sat 01/13/2024 01:06:37 PM : [INST-INFO ] Previous message ignored. Sat 01/13/2024 01:06:39 PM : [INST-SRX ] 02 50 58.9E.2D 00.00.01 CF 13 00 LTOFFRR(00) Sat 01/13/2024 01:06:39 PM : [Std-Group ] 58.9E.2D-->Group=1, Max Hops=3, Hops Left=3 Sat 01/13/2024 01:06:39 PM : [D2D EVENT ] Event [58 9E 2D 1] [DOF] [0] uom=0 prec=-1 Sat 01/13/2024 01:06:39 PM : [58 9E 2D 1 ] DOF 0 Sat 01/13/2024 01:06:39 PM : [D2D EVENT ] Event [58 9E 2D 1] [ST] [0] uom=100 prec=0 Sat 01/13/2024 01:06:39 PM : [58 9E 2D 1 ] ST 0 (uom=100 prec=0) Sat 01/13/2024 01:06:39 PM : [D2D EVENT ] Event [58 A0 82 1] [ST] [0] uom=100 prec=0 Sat 01/13/2024 01:06:39 PM : [58 A0 82 1 ] ST 0 (uom=100 prec=0) Sat 01/13/2024 01:06:39 PM : [LINK-INFO ] Link for responder 58 9E 2D 1 not found Sat 01/13/2024 01:06:39 PM : [INST-SRX ] 02 50 58.9E.2D 70.8A.A1 40 13 01 LTOFFRR(01) Sat 01/13/2024 01:06:39 PM : [Std-Cleanup ] 58.9E.2D-->ISY/PLM Group=1, Max Hops=0, Hops Left=0 Sat 01/13/2024 01:06:39 PM : [INST-DUP 2 ] Previous message ignored. Sat 01/13/2024 01:06:39 PM : [INST-SRX ] 02 50 58.9E.2D 13.02.01 CF 06 00 (00) Sat 01/13/2024 01:06:39 PM : [Std-Group ] 58.9E.2D-->13.02.01, Max Hops=3, Hops Left=3 Sat 01/13/2024 01:06:39 PM : [INST-INFO ] Previous message ignored. Sat 01/13/2024 01:06:43 PM : [INST-SRX ] 02 50 58.A0.82 00.00.01 CF 11 00 LTONRR (00) Sat 01/13/2024 01:06:43 PM : [Std-Group ] 58.A0.82-->Group=1, Max Hops=3, Hops Left=3 Sat 01/13/2024 01:06:43 PM : [D2D EVENT ] Event [58 A0 82 1] [DON] [0] uom=0 prec=-1 Sat 01/13/2024 01:06:43 PM : [58 A0 82 1 ] DON 0 Sat 01/13/2024 01:06:43 PM : [D2D EVENT ] Event [58 A0 82 1] [ST] [255] uom=100 prec=0 Sat 01/13/2024 01:06:43 PM : [58 A0 82 1 ] ST 255 (uom=100 prec=0) Sat 01/13/2024 01:06:43 PM : [D2D EVENT ] Event [58 9E 2D 1] [ST] [64] uom=100 prec=0 Sat 01/13/2024 01:06:43 PM : [58 9E 2D 1 ] ST 64 (uom=100 prec=0) Sat 01/13/2024 01:06:43 PM : [LINK-INFO ] Link for responder 58 A0 82 1 not found Sat 01/13/2024 01:06:44 PM : [INST-SRX ] 02 50 58.A0.82 70.8A.A1 40 11 01 LTONRR (01) Sat 01/13/2024 01:06:44 PM : [Std-Cleanup ] 58.A0.82-->ISY/PLM Group=1, Max Hops=0, Hops Left=0 Sat 01/13/2024 01:06:44 PM : [INST-DUP 2 ] Previous message ignored. Sat 01/13/2024 01:06:44 PM : [INST-SRX ] 02 50 58.A0.82 11.02.01 CF 06 00 (00) Sat 01/13/2024 01:06:44 PM : [Std-Group ] 58.A0.82-->11.02.01, Max Hops=3, Hops Left=3 Sat 01/13/2024 01:06:44 PM : [INST-INFO ] Previous message ignored. Sat 01/13/2024 01:06:46 PM : [ Time] 13:07:02 0(0) Sat 01/13/2024 01:06:46 PM : [INST-SRX ] 02 50 58.A0.82 00.00.01 CF 13 00 LTOFFRR(00) Sat 01/13/2024 01:06:46 PM : [Std-Group ] 58.A0.82-->Group=1, Max Hops=3, Hops Left=3 Sat 01/13/2024 01:06:46 PM : [D2D EVENT ] Event [58 A0 82 1] [DOF] [0] uom=0 prec=-1 Sat 01/13/2024 01:06:46 PM : [58 A0 82 1 ] DOF 0 Sat 01/13/2024 01:06:46 PM : [D2D EVENT ] Event [58 A0 82 1] [ST] [0] uom=100 prec=0 Sat 01/13/2024 01:06:46 PM : [58 A0 82 1 ] ST 0 (uom=100 prec=0) Sat 01/13/2024 01:06:46 PM : [D2D EVENT ] Event [58 9E 2D 1] [ST] [0] uom=100 prec=0 Sat 01/13/2024 01:06:46 PM : [58 9E 2D 1 ] ST 0 (uom=100 prec=0) Sat 01/13/2024 01:06:46 PM : [LINK-INFO ] Link for responder 58 A0 82 1 not found Sat 01/13/2024 01:06:47 PM : [INST-SRX ] 02 50 58.A0.82 70.8A.A1 40 13 01 LTOFFRR(01) Sat 01/13/2024 01:06:47 PM : [Std-Cleanup ] 58.A0.82-->ISY/PLM Group=1, Max Hops=0, Hops Left=0 Sat 01/13/2024 01:06:47 PM : [INST-DUP 2 ] Previous message ignored. Sat 01/13/2024 01:06:47 PM : [INST-SRX ] 02 50 58.A0.82 13.02.01 CF 06 00 (00) Sat 01/13/2024 01:06:47 PM : [Std-Group ] 58.A0.82-->13.02.01, Max Hops=3, Hops Left=3 Sat 01/13/2024 01:06:47 PM : [INST-INFO ] Previous message ignored.
  7. Hello I have been offline for awhile, just replaced PLM, wanted to set Echo back up. Portal will not accept password "Error 404" and when I click forgot password (which I did not) I get a message saying user does not exist??? If I don't exist how can I post this topic? Checked stats on Portal, good til 2018, what next?
  8. It shows Offline/Registered, I click on Refresh and nothing happens
  9. My Echo stopped working with Izzy, when I login to Portal I keep getting "ISY is not online" I can ping it I can login thru admin console and control devices UUID is correct I have reset the ISY What next??? Dave
  10. I have a customer with a barn that is 100' from the house, tried to linc a set of 2477S to control lights on barn from house with no luck. I did find a spare CAT5 between the buildings. At each building I want to linc a 2477S to an I/O Linc. Can I wire from from the house I/O linc NO + COM to GND + SENSE on a 2nd I/O at the barn, to control the lights on the barn without using an ISY? Would I use Momentary B to change ON/OFF of 2477S at Barn?
  11. I just found out about Microsoft's MakeMayhem.com and that it can be used with INSTEON as either an Event or Reaction but it appears that it will only work with a SmartLinc (which I am just about to sell as I bought an ISY) Any chance of ISY becoming compatible with Mayhem, that would be so cool to walk into a room and tell the lights to turn on! If not can I use a SmartLinc and an ISY together?????
  12. Anybody wanna buy one cheap!
  13. Hello, can I use a 2412N, Rev 2.4 with an ISY99iIR instead of a PLM?
  14. Thank you for the explanation, I appreciate your wisdom/help Dave
  15. LeeG can you explain in a little more detail. On a 5 button KPL the "On" button the primary load control node right? Do the 5 buttons equal 5 nodes??
  16. I just logged into the 2nd site that has an ISY99iPro v 3.2.6 and the devices are not in folders, I do not have the option to remove from folder and I also do not have the replace option for the KPL's What else could it be???
  17. Another question, to "replace" a 5-button KPL, I would need to move all 5 buttons out of the folder and then "replace" each one individually? or does it change all because of the KPL MAC address? What is the proper procedure? Thank you again for your help
  18. Thank you very much, you were dead on!!! Both jobs are so large (100+ devices) that I had created folders for the rooms/areas to make it easier to create scenes. So can I remove it from the folder, "replace" with new KPL and then move it back to the folder?
  19. by folder you mean scene?
  20. Hello, I have several ISY installations and have run into a problem. On one site I have an ISY99iPro V 3.2.6 I have the option to "replace" switches and receptacles, but no replace feature for KPL's, so how do I replace a dead KPL that has multiple links? I have another site with an ISY99i/IR v 3.1.6 and I do not have any "replace" option, is this only available on the Pro???? and if so what is the best method to replace a dead KPL with multiple links?. I searched the forum and found "Replacing an 8 button keypadlinc question " from ingeborgdot and he seems to have the "replace" KPL option, what am I missing?????
  21. Reinstalling Java didn't help will call tech support on Monday
  22. I have Java 6 update 30, Im going to delete Java and reinstall, see if that makes a difference
  23. Turned off internet access......nada Tried reset button to reboot......nada Tried power cycle......nada
  24. And I tried from an XP laptop this morning, same result, I can turn lights on and off but cant edit scenes, wierd
