wswartz
  1. It was the power supply. I was able to get another one and the ISY came up with no issues. Thanks to everyone here for your suggestions and support!
  2. Thanks for the input above. I’m back from my trip and was able to unplug the unit leave it off overnight, then plug it back in. Unfortunately, just got the power LED, nothing else. So at this point, I think it’s toast. Looks like I’m going to have to get something new to manage my 80+ Insteon device network. My install has been rock solid for over 10 years and I haven’t paid any attention to what’s new. Is the eisy a direct replacement for the isy994i? My PLM is a 2413S any issue there? (yes, I need to do some research and catch up, but hoping for a quick jump start here).
  3. I was doing some work on my network and had to unplug my ISY. After plugging it back in, it didn’t come up. I’m getting a green power light, but nothing else. Ethernet lights don’t blink and I can’t ping the unit. On top of all that, it happened an hour before I had to leave for a week long trip and my poor family is left at home with no home automation (gasp, the horror!). I’m not in a position to do much diagnosing, but I’m guessing it’s dead and I may need to move to a the latest eisy. To help get a sense of what I’m in for… 1. If anyone has some diagnostic suggestions, please provide. 2. While have a backup of my system, my unit is still on v4.9.0. From what I’ve been reading, I would need to have been on version 5 to migrate. Is there any option to migrate with v4.9.0? Thanks.
  4. ...the PLM???? I've had this issue for a number of years: about every 4-6 months, things that rely on a program to run will stop working. For example, a program that watches for a switch to turn on that will then turn on a bunch of other switches. When these programs would stop working, I would simply reload the PLM and everything would go back to normal. Even when this would happen, I could still see the devices in ISY and use the interface to control them. This issue happened again earlier in the week and I performed my standard PLM restore. Except this time, only about half my network was reachable. That is, some devices reported back during a query from the ISY, and others didn't. Those that didn't reply to the query were not controllable from ISY. At this point, I did a full reset of the PLM - removed power from the PLM, shutdown my ISY, did a factory reset of the PLM, and applied power to the ISY. After this, things were much better - most of the network is now visible with the exception of a few stray switches. So, at this point, you're wondering, how old is this thing? It's a 2413S v2.0 and it's been working fairly well for the last 8 years - well past it's normal life span I'd imagine! To my questions: 1. So, it sounds like the PLM is the culprit, but I'm a bit confused. While half of the network seemed unreachable, why did the other half still work? I'd imagine if the PLM was dead, it would not work for anything. While I've had to reset my PLM in the past, I've never seen half my network be unreachable when the PLM was acting up. 2. I'm investigating the various repair services available from nilachidatasystems on eBay and I've read a few comments here. Should I consider sending it in for a rebuild? 3. I'm comfortable with a soldering iron and replacing components myself. If it's just replacing caps, I can do that. If it's replacing IC chips, I'd rather have someone else do that. Could the caps alone cause communications issues like the ones I'm seeing? I would hate to replace the caps just to have to send it in later to fix something deeper. 4. I've read in the forums here that there are instructions for replacing the caps, but I've just found posts from folks saying they've done it. I'll continue to search, but If anyone has a link handy to instructions, please forward. Thanks, Bill
  5. wswartz replied to wswartz's topic in ISY994
    Thanks for your suggestions. Here's what I've done in the last few days... 1. I fixed the majority of the non-responding devices by adding a range extender to the circuit. This brought 3 switches back that weren't working. I really don't understand this since there are 5 other operational dual band switches within 4 feet of those that weren't responding. Plus, this area has been working well for the last 7 years. It's in a basement bedroom near the utilities. Nothing has changed there (no new equipment, changes in electrical). 2. The dimmer module was the victim of mistaken identity. I thought I pulled one when I really pulled another. Reset the module and deleted what thought was the instance in ISY. The Event View helped me figure that one out (thanks!). When I went to re-add the module, it said it already existed. Sure enough! Did a Restore Device with it's proper ISY instance and that one is working again. 3. I did the PLM Link Table test as requested. Did it 3 times with the following results: 426, 306, 172. Wildly different? Not sure what to make of that. 4. This is the kicker... an I/O Linc. From the event viewer, this is what I get when I try to do a query (address is 30.DF.27): Sat 01/16/2021 01:57:45 PM : [INST-TX-I1 ] 02 62 30 DF 27 0F 19 01 Sat 01/16/2021 01:57:45 PM : [INST-ACK ] 02 62 30.DF.27 0F 19 01 06 LTSREQ (01) Sat 01/16/2021 01:58:16 PM : [INST-TX-I1 ] 02 62 30 DF 27 0F 0D 00 Sat 01/16/2021 01:58:16 PM : [INST-ACK ] 02 62 30.DF.27 0F 0D 00 06 (00) Sat 01/16/2021 01:58:25 PM : [INST-TX-I1 ] 02 62 30 DF 27 0F 0D 00 Sat 01/16/2021 01:58:25 PM : [INST-ACK ] 02 62 30.DF.27 0F 0D 00 06 (00) Sat 01/16/2021 01:58:32 PM : [INST-SRX ] 02 50 14.7B.37 00.00.01 CF 13 01 LTOFFRR(01) ...and a Restore Device: Sat 01/16/2021 01:58:34 PM : [INST-TX-I1 ] 02 62 30 DF 27 0F 0D 00 Sat 01/16/2021 01:58:34 PM : [INST-ACK ] 02 62 30.DF.27 0F 0D 00 06 (00) Sat 01/16/2021 01:58:38 PM : [30 DF 27 1 ] Memory : Write dbAddr=0x4009 [15] cmd1=0x20 cmd2=0x15 Sat 01/16/2021 01:58:38 PM : [INST-TX-I2CS] 02 62 30 DF 27 1F 20 15 00 00 00 00 00 00 00 00 00 00 00 00 00 CB Sat 01/16/2021 01:58:38 PM : [INST-ACK ] 02 62 30.DF.27 1F 20 15 00 00 00 00 00 00 00 00 00 00 00 00 00 CB 06 (15) Sat 01/16/2021 01:58:47 PM : [INST-TX-I2CS] 02 62 30 DF 27 1F 20 15 00 00 00 00 00 00 00 00 00 00 00 00 00 CB Sat 01/16/2021 01:58:47 PM : [INST-ACK ] 02 62 30.DF.27 1F 20 15 00 00 00 00 00 00 00 00 00 00 00 00 00 CB 06 (15) Sat 01/16/2021 01:58:56 PM : [INST-TX-I2CS] 02 62 30 DF 27 1F 20 15 00 00 00 00 00 00 00 00 00 00 00 00 00 CB Sat 01/16/2021 01:58:56 PM : [INST-ACK ] 02 62 30.DF.27 1F 20 15 00 00 00 00 00 00 00 00 00 00 00 00 00 CB 06 (15) Sat 01/16/2021 01:59:00 PM : [30 DF 27 1 ] Memory : Write dbAddr=0x4009 [15] cmd1=0x20 cmd2=0x15 - Failed I'm guessing that last line can't be good, eh? As I mentioned in a previous post, I was able to replace this I/O Linc with a spare (it was managing my main water valve, so it's pretty important!). So at this point, everything is back up and running. But if there are any suggestions on how to recover this non-working I/O Linc, I'd be interested. Thanks, Bill
  6. wswartz replied to wswartz's topic in ISY994
    Not that I'm consciously aware of. I have done this once. I can try again. BS
  7. wswartz replied to wswartz's topic in ISY994
    Update: One of the modules was an I/O Linc. I replaced it with a spare and it is back to normal. I factory reset the original module and removed it from ISY, then tried to re-add it. It won't install. Same story with a dimmer module. I either have some modules that work but won't communicate, or something with my ISY.
  8. wswartz replied to wswartz's topic in ISY994
    Sorry, meant to add that. Version 4.8.0. And yes, using the ISY Launcher.
  9. wswartz posted a topic in ISY994
    I have about 80 devices in my network that have been running well over 10 years. In the last week or so, a portion of my house began to stop responding. They are devices of all types - dimmer modules, dimmer switches, on/of switches and one relay module. I have pulled some of the modules and brought them to an area with great signal. In ISY, it can't query them. I've tried to reload them, even removed them from ISY, factory reset, then tried to re-discover. They won't seem to come back online. When I went to discover, I never saw the box that says they were being added. The screen flashes for a moment, then it goes back to the main page. In one case, I removed a dimmer module that isn't working and put a brand new module in the same socket and added it to ISY - worked great. Almost seems the ISY is holding on to some old configuration and won't allow a factory reset device to get added in. Any thoughts as to why I can't get these devices back online? Thanks, Bill
  10. @Teken I have 123 devices in my network. I ran the PLM link count (from: Tools->Diagnostics->Show PLM Links Table) 5 times with the following results: #1: 980 #2: 312 #3: 473 #4: 634 #5: 461 I did a search of the wiki here-> https://wiki.universal-devices.com/index.php?title=Main_Page for "link" or "links" and found no relevant information regarding a correlation between links and devices. If you can guide me to more specific documentation, that would be great. As far as the date sticker on my PLM, there are 3 stickers: #1: "QC5" - imagine it's a quality control sticker #2: Address of the device ("xx.yy.zz") #3 Sticker with the Model, rev, and another number - the sticker reads: "2413S", "Rev 2.0", "1438". Not sure what that last number is. The "Rev 2.0" is a printed sticker on top of the sticker (and in a different typeface). There could be a date below it - I didn't take it off to look. Thanks for your assistance.
  11. Well, frankly, I'm not clear exactly how the HA/ISY integration works. I installed this integration on HA: https://www.home-assistant.io/integrations/isy994 My impression is that HA is calling ISY and the ISY is talking to the PLM. But I could be wrong on how that works.
  12. I have a 2413S Dual Band v2.0. I believe it's over two years old - I didn't see a date on the back of the unit. It's my second PLM that replaced one that did experience power supply issues. Totally get that the PLM is a finicky beast, but I can't ignore the correlation. Add HA and now having to restore every other week or so. Guess I could remove HA for a bit to see, but I'm getting so much out of using it.
  13. About every 6 months or so, for some reason I have to restore my PLM. I find that after some time, my programs stop working - but a PLM restore puts everything right again. It hasn't been a big deal to me since it happens so infrequently. However, in the last two months, I've had to restore my PLM three times. The only change in my setup has been the addition of Home Assistant which I installed just about two months ago. My main purpose for adding HA was so I could monitor the ESP8266 temp sensors I built. But when I discovered I could integrate my ISY with it as well, I really got interested. At this point, I'm not running any automations from HA - just using it to monitor status and turn on/off the occasional switch. Would the addition of HA be the cause of my frequent PLM restores? Anyone else experiencing such an issue? Thanks.
  14. Hello? Looking for some sample code, anything that shows how to do a subscription using ISYlib. I can probably figure it out from there. Thanks!
  15. So, from what I've been seeing, I need to use websockets to subscribe to the ISY. I looked at the mentioned libraries. While the code for Psisy is on Github, I couldn't' find any documentation. There is a link for information on the library, but the link is dead. I was able to get ISYlib to work a little bit - wrote a few lines to print print some info on my ISY which worked. But I'm not a programmer - I have to Google for every line of code I write. I found the documentation on ISYlib to be extremely light and searching for additional examples both here and on Google came up wanting. Wondering if there is a source for more documentation on ISYlib - or better yet, anyone have some example code that would do what I'm trying to accomplish? Thanks, BS
