ahwman
  1. Thanks so much for your help!
  2. I’m trying to update the email address associated with my ISY portal account, however the email address field is uneditable. If I create a new account, I’ll have to re-create all of the Amazon Echo spokens/devices. Any suggestions?
  3. ahwman replied to ahwman's topic in ISY994
    Thanks for the info. For now it seems to be working, so I’ll just keep me eyes on it...
  4. ahwman replied to ahwman's topic in ISY994
    I forgot to mention that ever since I purchased my ISY-994i new, the barrel connector for the power supply fits extremely loose and the same is true for both power supplies so it must be an issue with the female connector inside the ISY. If I don’t keep a little sideways tension on the cord, the connection breaks and it looses power. Not ideal…
  5. ahwman replied to ahwman's topic in ISY994
    Will do. Thanks again everyone…
  6. ahwman replied to ahwman's topic in ISY994
    Fortunately I happened to have an old power supply from my I SY-99 and low and behold my ISY-994 came back to life! What a relief.… Thanks so much for all your help!
  7. ahwman replied to ahwman's topic in ISY994
    You’ve given me hope ?…
  8. ahwman replied to ahwman's topic in ISY994
    Thanks, I’ll give this a shot. In my case however, the power light is not on, only a small blue LED near the rear network port is illuminated. Crossing my fingers anyway…
  9. ahwman replied to ahwman's topic in ISY994
    I’ll try to find another power supply today. Do you happen to know the voltage, polarity, etc? Thanks for your help!
  10. ahwman replied to ahwman's topic in ISY994
    No activity whatsoever on any of the front panel LED’s. Only the network LED on the rear…
  11. ahwman replied to ahwman's topic in ISY994
    Unfortunately I cannot get into the admin console because the ISY cannot be found. There is no activity on any of the front lights, however I do see a blue blinking light near the network port in the rear. The PLM is not the issue, it’s definitely the ISY itself. I’m thinking if it was a bad power supply I wouldn’t see the network light blinking, unless it’s possibly undervolting?
  12. ahwman posted a topic in ISY994
    After years of rock solid reliability from my ISY-994i, today I noticed none of my devices were responding. After close inspection, there is no activity on any of the front lights of the ISY, however I do see a blue network activity light in the rear. I’ve tried power cycling, unplugging/replugging to no avail…. Any thoughts?
  13. Hope it works out for you… ?
  14. Have you tried the Home+ or Eve app to see if you can set up an automation trigger for your needs? I use several temperature automations using these apps which simply aren’t available in the native Home app…
