marksidell
Everything posted by marksidell
  1. Michel got back to me (very quickly!) with a fix: sudo pkg install -f udx sudo service udx restart (wait two minutes) sudo service isy status Spouse is happy again
  2. I was able to ssh into the dead eisy. This looks bad: [admin@eisy /var/log]$ tail messages Mar 11 18:15:33 eisy kernel: pid 64484 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped) Mar 11 18:15:54 eisy kernel: pid 65354 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped) Mar 11 18:16:14 eisy kernel: pid 66177 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped) Mar 11 18:16:35 eisy kernel: pid 66928 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped) Mar 11 18:16:56 eisy kernel: pid 67800 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped) Mar 11 18:17:17 eisy kernel: pid 68624 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped) Mar 11 18:17:38 eisy kernel: pid 69385 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped) Mar 11 18:17:58 eisy kernel: pid 70248 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped) Mar 11 18:18:19 eisy kernel: pid 71071 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped) Mar 11 18:18:40 eisy kernel: pid 71828 (isy-freebsd-x64), jid 0, uid 349: exited on signal 11 (core dumped)
  3. This release bricked my eisy. Oh well. Now what? Update: I am able to ssh into the eisy. Any way to diagnose what's wrong?
  4. Thanks for the responses. I am able to restore the programming of the keypad from the eisy, and do other updates, such as scene changes. So, I think the eisy is able to communicate with the keypad. The z device is a leviton plug-in dimmer. It does work in an eisy scene with a different keypad as the controller.
  5. More: I've determined the problem is that the eisy is receiving no event when I press a button on this particular keypad. More specifically, it receives events when the "main" on/off buttons are pressed, but not when one of the other four buttons is. I recently upgraded to an eisy. Is it possible the programming for this keypad didn't get set up correctly? I've tried restoring the device. That succeeded. Also, the device is able to control other Insteon devices, but of course that doesn't depend on the eisy doing anything. How can I fixe the device programming short of deleting and re-adding it?
  6. Is it possible to add a z wave device to a scene with an Insteon device as the scene controller? I was able to add a z wave device, but turning the Insteon device on and off has no effect. Insteon responders in the same scene do work.
  7. I've had this problem for years, and am wondering if anyone has a solution. When I launch the Administrative Console, it prompts me to login three times in a row before it's finally happy. There's a brief pause before each request. Any ideas? (Of course, I'm running the latest everything.)
  8. Thanks to everyone for the suggestions. I added the ISY to the Java site list, but I still get multiple login prompts. I know the java program is connecting to the ISY, because it initializes the devices list, and I can start working with devices, but shortly after logging in I get one or more addition login prompts. Just now I got three and then everything was fine. What exactly is happening that is causing the login prompts? Is it because the java program loses its connection to the ISY?
  9. Thanks for the suggestions. I'm not running an anti-virus program. What do I have to do to get Java to trust the ISY's address? It's a local address on my LAN, of course. Another strange thing is that this used happen, and then it stopped happening for a long time, but in the last couple of weeks it's started happening again... with the exciting new development in 4.4.6 that the admin program quits after the second, or third or fourth, login prompt.
  10. Sorry if this has been asked before... First, I cannot launch the admin console from the ISY web interface running in Chrome. I assume this has to do with java being disabled in Chrome. So instead I click the "Install Admin Console" button and launch from the resulting admin.jnlp shortcut. All fine. But, after I login to the admin console, and the console appears to be operational, a few seconds later it prompts me to login again. Sometimes it prompts a third time. If I cancel any of these subsequent prompts, the only menu option that works on the console is File. Got any idea why it keeps prompting me to login even after I have successfully logged in? I'm running version 4.3.26 (firmware and UI). And wow, it just went from bad to worse. I upgraded both the firmware and UI to 4.4.6 (and cleared the java cache). Now, after it prompts for a login the second time, the program just... quits.
  11. Wow, exciting. Ok, I've done steps 1-5 above and everything appears to be working again. Phew. I held off doing step 6 -- Restore Devices -- because it sounds kinda scary. But I'm sure there are devices with garbage data, which seems to accumulate over time in Insteon devices. Questions: Is Restore Devices safe? Does the ISY verify the data it writes and tell me which devices couldn't be written correctly? Many thanks to all here who helped. Y'all a great!
  12. Thanks for the replies. I want to make sure I understand what I should. Is this correct? Restore the ISY from a backup Unplug the ISY and PLM Plug in the PLM Plug in the ISY Restore Modem Restore Devices
  13. Wow, what a mess. This time I followed the correct procedure to replace PLM. But.. Restore Modem took almost no time at all The ISY says the PLM now has exactly ONE link Devices that have PLM links have links to both the old and the new PLM Some devices do not have links to the PLM, either in the device or in the ISY. Is that because these particular devices are not in any scenes? Some devices that ARE in scenes do not have links to either the old or the new PLM. The links are not shown in the device OR in the ISY. So... How do I restore the links to the PLM? How do I fix the bogus links in the devices that still have links to the old PLM Thanks to all who have been responding here, at all hours.
  14. The restore modem ran for about 20 minutes. During that time, the green "write" arrows appeared on all devices and were gradually removed. I may have plugged the new modem into the ISY without powering down the ISY, but then I power cycled both devices. Should I try running the restore again? More... I just read the wiki page about no status from devices and how to install a new PLM. I likely screwed it up by plugging in the new PLM while the ISY was still on. I just dumped the PLM links table, and it only lists 32 link, way fewer than there should be. What should I do now? Should I do a Delete Modem, followed by a Restore Modem? Also, I have a dozen or so devices that I only use during the Christmas holidays. Should I plug all of these devices in before I do the PLM delete / restore sequence? From what I gather, the restore writes new link values to all devices.
  15. Hmmm. I got the new PLM and did a Restore Modem. That seemed to work, and I can control individual devices from the ISY admin program. But none of the programs are working. That is, the ISY says the programs are running, but nothing happens. For example, I have a program that turns various lights on at sunset. The program ran, but none of the lights came on. I also tried running a couple of scene test diagnostics. The log reports the test failed to communicate with any of the devices in the scene. But, again, I can control individual devices. Geez. Anyone got any suggestions?
  16. SHIPS TODAY on a Sunday did seem a little too good to be true. OTOH, I was in an upgrade mood and ordered a new SSD for my computer. I ordered it from Amazon today, and they claim it will be delivered by 9pm today, free. Not by drone, I presume. Crazy.
  17. Techman, thanks for the reply. Good to know, fingers crossed, that Smarthome has fixed the problems with the PLM. My house doesn't work very well without the ISY, so I ordered one with overnight shipping. I'll see if they really mean it when they say "SHIPS TODAY!"
  18. Now the LED on the PLM is not lit, and the ISY has gone into safe mode. I'm guessing that's bad. What is it with these PLMs? They only seem to last a couple of years. It's like an Insteon tax.
  19. Yesterday, my ISY stopped responding to events from switches, which trigger programs on the ISY. However, the ISY can still control devices. When I run the diagnostic event viewer, I see no events when I turn various switches on and off. However, I do see events triggered internally, such as from timers. Do you all think the PLM is at fault, and has stopped being able to hear external events? (Of course, I've tried power-cycling both the ISY and the PLM.)
  20. Thanks for the info. I tried selecting an older model from the drop-down list, but the ISY seemed to ignore my selection and set the model to the 2334.
  21. So, am I correct in assuming that at this point I'm SOL? Also, I'm guessing that if I had a spiffy new 994i everything would be peachy keen. What makes the 994i better than my stinky old 99i? Any upgrade pricing available?
  22. I added a 2334-323 keypadlinc to my ISY 99i. But the devices list in the admin console shows only one line for the device, not the 5 lines it shows for older keypadlinc 6-button devices. The (one) entry shows the correct device type. Why aren't there entries for the other 4 switches? ISY 99i Pro (1040) Firmware UD99 v.3.3.10
