rsansev
  1. Thanks. I have a few more Qs: I notice that the pro version supports strong encryption. Is this via hw or sw? My 99i couldn't handle strong at all! How far along is the zigbee/zwave support, i.e. is it complete for both hw&sw In other words does it work the same as the insteon devices and show up in the html and java apps? Can I upgrade from 99ir to 994 Pro? thanks!
  2. Hello, Aside from firmware updates, is there any reason to upgrade to 994? Is there a page that allows me to compare features/capabilities? thanks! -Ron
  3. ok, i will do this. i think i have tracked down the IR pressed msgs. they only seem to occur when i have my LED lights on... i tried again. both from w/in lan to public address, as well as from my 3g phone (outside of lan) log is attached.
  4. ok, i will do this. i think i have tracked down the IR pressed msgs. they only seem to occur when i have my LED lights on... i tried again. both from w/in lan to public address, as well as from my 3g phone (outside of lan) log is attached.
  5. ok, i will do this. i think i have tracked down the IR pressed msgs. they only seem to occur when i have my LED lights on...
  6. no, they have cable modem.
  7. yep! i have to say...that i have noticed this problem while remoting in from high speed connections e.g. my in-laws.
  8. i have predominantly seen it when i am in the office. i have a 4g connection, so maybe that is it. i dont have problems with other sites tho...
  9. Actually, i thought i cleared this up, i never get a 'not found'. I only get #2 The odd thing is that sometimes i *only* get the 'unsigned cert' error, in other words, i am connecting to ISY but it seems that the ISY times out. Is that what you meant by #1, if so, that is pretty rare (maybe once out every 30 times). I don't think that it is possible that my ISY CPU is maxed out, as i never have a problem connecting to it when i am on my lan. In addition, i typically only have 1 running task and none of my programs are that complex. When i am away, I have a timer program that every 15 minutes executes a few tasks. It turns off all lights (via a scene) and checks for any motion events and sends an email if any were detected. Motion counter is stored in int vars and there are 4 sensors.
  10. [it is at the default - i havent changed anything via telnet except log size (16m)] usually once i can remotely access it, i have no probs w/ admin, but today when i tried admin, i got xml parse error https://my-ip:443/desc lastly, I do believe that i currently have 'enable internet access' set.
  11. Tried it again and it opened up fine... Could it be that i need to increase time out value (via telnet)?
  12. I just tried it right now and i got the SSL cert error, clicked 'yes' and then got: This webpage is not available Google Chrome could not load the webpage because 69.143.181.204 took too long to respond. The website may be down, or you may be experiencing issues with your Internet connection. Here are some suggestions: Reload this webpage later. Check your Internet connection. Restart any router, modem, or other network devices you may be using. Add Google Chrome as a permitted program in your firewall's or antivirus software's settings. If it is already a permitted program, try deleting it from the list of permitted programs and adding it again. If you use a proxy server, check your proxy settings or contact your network administrator to make sure the proxy server is working. If you don't believe you should be using a proxy server, adjust your proxy settings: Go to the Chrome menu > Settings > Show advanced settings... > Change proxy settings... > LAN Settings and deselect the "Use a proxy server for your LAN" checkbox. Error 7 (net::ERR_TIMED_OUT): The operation timed out.
  13. sorry, it doesnt display 404, it does as you say. in my defense, i was using 404 as shorthand for not found.
  14. 1) I did put the tape over it and i will let you know how that turns out. 2) i guess i am the dummy, i thought it had a sensor built in!
  15. i dont do anything to recover - that's why i was calling it sporadic, it comes and goes... thanks!
