heyfrank
  1. I'm confused how the third line has the potential to change the status if its sitting in the IF statement saying, if the mode heat is on and the temperature is more or equal to 73 then.... Unless i'm missing something? What I don't think I conveyed is that it executes great, it works, I get both notifications each time and everything all the way through, BUT it's only when I go into Mobilinc and press the refresh button in the UI of Mobilinc that it gets executed if its above 72 degrees.... Should I have a query then in this program? is it safe to do that? and if so where should I put it as well as what should it exactly say? Thank you
  2. How does it make it false? Just curious what you mean? And yes I believe it's not being queried. The Thermostat is near a lot of dual-band switches so communication should not be an issue.
  3. Hi any chance you can let me know which setting it should be? I do not see an option that says "Main Mode is Heat"? I have the first dropbox set to "Status", the second set to the "Thermostat Main", the third dropbox set to "Is"and the fourth dropbox set to "Mode Heat". I have 4.7.3 firmware/ui installed. Thanks! Frank
  4. Haha, no way I'd ever put that on my thermostat in my dining room. lol
  5. Hello, hoping someone here might be able to help me with this; we have someone in the house who cannot keep their hands off the thermostat making it extra hot in the middle of the night. I want to create a program that when the thermostat's temp changes, goes back to our desired temperature. I have the one below, but noticed it only "runs" when I open my Mobilinc app or login to the ISY itself. Any ideas how to make it run without question?
  6. Hi, is there a way to set the Insteon thermostat fan from the ISY web UI to on? I’m only seeing cool control, heat control and main. Am I missing something here? Sent from my iPhone using Tapatalk
  7. Looks like my PLM just fried. Going on my 4th or 5th one, will insteon ever fix this issue?
  8. I'm not sure if this is what you mean, the screen for each individual device?
  9. Here is what my current Firmware is and UI:
  10. The Green LED on the IOLinc is off/not lit when the door is closed. What does this mean? Is this correct?
  11. Would this be correct then? The device "Garage Door - Relay" will not stay on 0% for me, every time I click out of the scene it goes back up to 100%
  12. So even the keypadlinc in the scene should be set to on level 0%? Here are some screenshots from mine if you don't mind taking a look to see if there is anything wrong or I'm missing from it...
  13. Ok just tried this, set it to 0% and it now shows as off (Garage is closed). It seems that the slider although did reset it self to 100%, this is normal i assume. I have my keypadlinc set to Non-Toggle-ON is this correct as well? It is a controller of the scene with the relay as a responder, and a responder to the scene with the sensor as the controller... I was having problems earlier trying to get it to sync correctly to the open or close of the garage. Thanks for all your time, i appreciate it.
  14. It seems like when I turn the scene off from the ISY, it will open the door, and if i turn the scene On from the ISY then it shuts the door. The sensor reports it's off when the garage is shut, but the relay reports its "ON" and never changes. Any ideas before I drive myself crazy? Ps. Double checked the wiring, and it is exactly as described in your post
  15. New problem, I found out I have the 3 wire magnetic sensor, I had it originally hooked up to Green with Red tied together with Black (G) for some reason. I cut green loose and tied red to where green was as the (S) Sense wire to the IOLinc. My other wires are hooked up to NO(Normally Open) and COM (Common). Is this correct?
