flemingmike
  1. thanks, ill just build programs with variables. appreciate your time.
  2. this doesnt exactly solve the problem though as if i send a 50% command of a scene it still turns the scene on to 100% ive tried removing the kpl from the scene and i still cannot dim a scene, only dim a device /rest/nodes/SCENEID/cmd/DON/50 - this still turns on my light to 100%
  3. is it possible in the future to say - if any controller in a scene is turned on then all controllers in that scene are turned on? or is this a limitation to insteon and not the eisy. ive seen other hardware that works this way
  4. correct, if i send rest/nodes/38898/cmd/DON/0 the scene turns off. if i send anything greater than 0 it turns scene on but turns on to 100% and not the value of the number
  5. so ive done this in the past by 1 - create scene with kpl button as responder named device 1 status update 2 - create program - if device 1 is not off then turn on scene "device 1 status update" else turn off scene "device 1 status update" my issue im trying to solve is 1 have about 50 of these scenes at this jobsite and im hoping not to make 50 programs and additional scenes
  6. Nevermind, when i dim the scene it just turns the scene on or off, doesnt apply percentage level. back to the drawing board.
  7. in a future version of the eisy in the http://192.168.*.1:8080/rest/nodes/ feedback add in status of the scene it would save a programming step.
  8. Ok, amazing, this pointed me in right direction. in my control app - i use slider to dim scene which activates all devices then in the feedback from the eisy, since it doesnt show the status of a scene, i show the status of the device that controls the load so now i can control and see status of my lighting. thanks for the help everyone. Edit: This isnt correct information
  9. Yes, I see that part. problem is that the scene turns on the devices to the on levels set in the scene. If i want to use the dimmer in the app, the other controllers from the scene dont turn on. and you cant dim a scene
  10. lets say im using the ud mobile app and i set device 1 to 50% dim, device 2 doesnt turn on to reflect that the device 1 is on. if i use device 1 locally to dim to 50% device 2 turns on
  11. ill try expain one example and hopefully there is a way to do this without creating a program for every scene i have Device 1 - dimmer - controller/responder Device 2 - 6 button kp letter b - controller/responder Scene 6 - includes device 1 and 2 If i use an app to turn on scene 6, device 1 and device 2 turn on If i use an app to turn on device 1 (lets say i dim it to 50%) device 2 does not turn on so therefore when im at the other end of the room i cannot turn off device 1 by pressing letter b on device 2. workaround: create a program (if device 1 is not off then turn on device 2, else turn off device 2) - not ideal when i have 100+ scenes. is there a way to create a way that if any controller in a scene isnt off then turn on all controllers?
  12. i cannot login to either.
  13. hi, I only have a blue light and my switch doesn't show any activity on the port isy is plugged into. my devices aren't plugged responding to any programs that I have so I believe there isn't a plm communication either. any ideas for that to try next? thanks
  14. - <isy.diag> <title>Device Links Table : 1B.70.6D-On / 1B 70 6D 1</title> - <insteon.lincs> - <eventInfo> <ix>0</ix> <ad>4088</ad> <fl>255</fl> <gr>255</gr> <id>16777215</id> <data>16777215</data> </eventInfo> </insteon.lincs> </isy.diag>
  15. I did follow that and it does link into my isy. my isy doesn't control the lock though. the morninglinc can control the lock by pressing the set button. when I press the set button it doesn't update the isy though.
