flemingmike
Everything posted by flemingmike
  1. thanks, ill just build programs with variables. appreciate your time.
  2. this doesnt exactly solve the problem though as if i send a 50% command of a scene it still turns the scene on to 100% ive tried removing the kpl from the scene and i still cannot dim a scene, only dim a device /rest/nodes/SCENEID/cmd/DON/50 - this still turns on my light to 100%
  3. is it possible in the future to say - if any controller in a scene is turned on then all controllers in that scene are turned on? or is this a limitation to insteon and not the eisy. ive seen other hardware that works this way
  4. correct, if i send rest/nodes/38898/cmd/DON/0 the scene turns off. if i send anything greater than 0 it turns scene on but turns on to 100% and not the value of the number
  5. so ive done this in the past by 1 - create scene with kpl button as responder named device 1 status update 2 - create program - if device 1 is not off then turn on scene "device 1 status update" else turn off scene "device 1 status update" my issue im trying to solve is 1 have about 50 of these scenes at this jobsite and im hoping not to make 50 programs and additional scenes
  6. Nevermind, when i dim the scene it just turns the scene on or off, doesnt apply percentage level. back to the drawing board.
  7. in a future version of the eisy in the http://192.168.*.1:8080/rest/nodes/ feedback add in status of the scene it would save a programming step.
  8. Ok, amazing, this pointed me in right direction. in my control app - i use slider to dim scene which activates all devices then in the feedback from the eisy, since it doesnt show the status of a scene, i show the status of the device that controls the load so now i can control and see status of my lighting. thanks for the help everyone. Edit: This isnt correct information
  9. Yes, I see that part. problem is that the scene turns on the devices to the on levels set in the scene. If i want to use the dimmer in the app, the other controllers from the scene dont turn on. and you cant dim a scene
  10. lets say im using the ud mobile app and i set device 1 to 50% dim, device 2 doesnt turn on to reflect that the device 1 is on. if i use device 1 locally to dim to 50% device 2 turns on
  11. ill try expain one example and hopefully there is a way to do this without creating a program for every scene i have Device 1 - dimmer - controller/responder Device 2 - 6 button kp letter b - controller/responder Scene 6 - includes device 1 and 2 If i use an app to turn on scene 6, device 1 and device 2 turn on If i use an app to turn on device 1 (lets say i dim it to 50%) device 2 does not turn on so therefore when im at the other end of the room i cannot turn off device 1 by pressing letter b on device 2. workaround: create a program (if device 1 is not off then turn on device 2, else turn off device 2) - not ideal when i have 100+ scenes. is there a way to create a way that if any controller in a scene isnt off then turn on all controllers?
  12. i cannot login to either.
  13. hi, I only have a blue light and my switch doesn't show any activity on the port isy is plugged into. my devices aren't plugged responding to any programs that I have so I believe there isn't a plm communication either. any ideas for that to try next? thanks
  14. - <isy.diag> <title>Device Links Table : 1B.70.6D-On / 1B 70 6D 1</title> - <insteon.lincs> - <eventInfo> <ix>0</ix> <ad>4088</ad> <fl>255</fl> <gr>255</gr> <id>16777215</id> <data>16777215</data> </eventInfo> </insteon.lincs> </isy.diag>
  15. I did follow that and it does link into my isy. my isy doesn't control the lock though. the morninglinc can control the lock by pressing the set button. when I press the set button it doesn't update the isy though.
  16. hi, my plm died and I had to restore after replacing plm. since then my morninglinc doesn't work. im able to link it to the isy with keep existing links but then when I press the set button on my morninglinc it locks/unlocks my door but doesn't update the isy as per the button press. when I press the on or off button on the isy it doesn't lock or unlock the door. any ideas? thanks
  17. now a year later, is this in the plans?
  18. hi, I hope this gets to the right person. im currently developing an insteon product and am using a 2448a7 as my battery powered rf chip. when I add it to the isy, it says unsupported device. can you add this as a supported device? if you need to know any info on it for adding, please let me know. im hoping this can be done easily so I can continue with product testing. thanks
  19. what are the correct settings for the iolinc in a garage door setup? i find i need to hit the button twice to get it to open or close.
  20. done. still not working. same problems.
  21. DOF 0 ST 0 CLIHCS 0 DOF 0
  22. E2 EF E2 01 E2 02 00 00
  23. I still don't have this working. I am now playing with a 2441zth and I can control the thermostat from the isy, but the changes to the thermostat aren't making it to the isy. it doesn't even display the current temperature.
  24. if status of switch a is on or if status of switch b is on then turn scene "notify me if light is on" on make a scene with the button of the keypad that you want illuminated as a responder and call it "notify me if light is on".
