popnat
  1. For those who are using a more recent bridge the following request should be used instead to get your Hue name: {"devicetype": "my_test_user#test1"} the bridge should reply with the following format: [{"success":{"username":"1028d66426293e821ecfd9ef1a0731df"}}]
  2. Hello Lip, Changed my router too and I have the same issue (went form a Cisco to an Apple Extreme). Your help would be greatly appreciated.
  3. You can do a search on this forum using "shades". I saw a couple of posts. I am not familiar with these shades. Are they controlled with a remote ? Ir or Rf ? I use my keypadlinc to turn on/off my AC split (Mitsubishi) via IR with Global Cache. Works fine.
  4. Hi, I changed the program from an "If Condition" to "If Status". It works fine. Many thanks.
  5. You're right about the IF Control part. I'll try it to switch it tonight and keep you posted. Thank you !
  6. One of my Keypadlinc button triggers my A/C ON and OFF via Global Cache's Itach. I wrote a single program (If keypadlinc button#X is switched on Then Resource A/C ON). I have a similar program for the turning it off.It works well. This button is part of a scene (named "A/C control"). If a turn on this scene, the program does not start. I have to physically press the button to turn on my A/C. I understand that it is not possible to use the status of a scene to trigger a program. Is there a way to get around this ? I would like to be able to turn on/off my A/C control Scene to initiate my programs. Any suggestion ?
  7. popnat replied to popnat's topic in ISY994
    I just found out that one of my devices had an accented letter in its nams. I removed it and now the devices are showing... Thank you very much for your help !
  8. popnat replied to popnat's topic in ISY994
    Will do. Thank you very much. One last question. Why can't I see the devices on the welcome page when I click 'My devices' ?
  9. popnat replied to popnat's topic in ISY994
    What level was migrated from when the ISY was updated to 3.1.17? 3.1.16 Do you have a backup from the that level? No I'll just reprogram them. Does the Last Run Time information on the Summary screen change when the Run Then is selected? Yes. I think I found the problem. The programs not responding are based on a folder condition (ex. if away mode is on). If that condition is met, then the program is working when I send a Run then command. One more thing. Some programs notify me of an event (alarm tripped, lights turned on at sunset while on vacation, etc.) Since I've upgraded to 3.1.17, notification no longer works. Here's the log error: Time User Code Message lun. 2012/04/09 09:20:13 System -50001 -10 Does that ring a bell ?
  10. popnat replied to popnat's topic in ISY994
    I feel stupid. The ON Level slider are set to 0 for most of my devices ! I think that when I updated to last firmware (3.1.17), some of the values were reset. Anyway, problem solved. Now do you have any idea why: - I can't see my devices on the welcome page ? - the run 'then' is not working ? Thanks again.
  11. popnat replied to popnat's topic in ISY994
    Hello again, For your info, I tried the fastest ramp rate (0.1 sec.) and I have the same problem...
  12. popnat replied to popnat's topic in ISY994
    Sir, Thank you very much for the reply. As requested, here's the log. For your info, I don't use long lamp rates (all are less than 2 seconds): dim. 04/08/2012 16:39:47 : [iNST-ACK ] 02 62 13.6B.55 0F 11 00 06 LTONRR (00) dim. 04/08/2012 16:39:47 : [iNST-SRX ] 02 50 13.6B.55 18.CE.92 2B 11 00 LTONRR (00) dim. 04/08/2012 16:39:47 : [standard-Direct Ack][13.6B.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 dim. 04/08/2012 16:39:52 : [iNST-ACK ] 02 62 13.6B.55 0F 12 00 06 LTON-F (00) dim. 04/08/2012 16:39:52 : [iNST-SRX ] 02 50 13.6B.55 18.CE.92 2B 12 00 LTON-F (00) dim. 04/08/2012 16:39:52 : [standard-Direct Ack][13.6B.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 dim. 04/08/2012 16:39:52 : [ 13 6B 55 1] ST 255 dim. 04/08/2012 16:39:56 : [iNST-ACK ] 02 62 13.6B.55 0F 13 00 06 LTOFFRR(00) dim. 04/08/2012 16:39:56 : [iNST-SRX ] 02 50 13.6B.55 18.CE.92 2B 13 00 LTOFFRR(00) dim. 04/08/2012 16:39:56 : [standard-Direct Ack][13.6B.55-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 dim. 04/08/2012 16:39:56 : [ 13 6B 55 1] ST 0 Run Then are being used (simple progarm turning devices on at sunset for example. The programs are working fine. I just can't use Run 'then'
  13. I have a few problems with my iSY-99ir. 1. When I open the main page, if I click either 'My devices' or 'My devices and scenes', nothing is happening. 2. In the administration console, devices are not responding to 'on' commands. Only 'fast On' works to turn on devices. 3. I can't test a program using 'RUN' commands anymore. All of the above used to work fine. Am I missing something or is there a problem with the unit ? Thanks for your help.
