jam10
  1. jam10 posted a topic in ISY994
    How do I confirm if a module is really dual band? I recently ordered some module form Smarthome because both items were advertised as dual band (Dimmer 2457D2 and On/Off module 2635-222). The dimmer box clearly states "Dual Band" but the On/Off box makes no mention of dual band feature. I queried Smarthome but have yet to get a reply.
  2. jam10 posted a topic in ISY994
    Since updating to release 4.2.22 I no longer have "On" option when programming remotes or keypad buttons. Only "1 - 100%, Responding and Off" are available options. All programs that were created with "On" have automatically changed to "100%." This is weird and somewhat annoying. Any reason why the latest release changed this? Thanks
  3. Am having trouble getting a program to run correctly. I want to get an e-mail/text when humidity level in house reaches a certain percentage. My program: IF status Venstar T-1800 is 62% humitiy THEN send notification to jam Only problem with the above is that the e-mails/text keep coming. How can I just get one alert only and stop the repeating? Thanks
  4. Thanks Xathros; it worked! I assume I can also use this to access my ISY when I am outside the home by replacing http with https. Very strange how these bugs occur all of a sudden. I am still debating whether or not to completely remove Java (and Flash) from my Macs. I can live without Flash, but not sure about Java despite all its security flaws. Thanks ago for helping me troubleshoot this issue.
  5. http://isy.universal-devices.com/99i/3.3.9/admin.jnlp
  6. Nope, still can't open the JNLP app on my desktop. And it is set to open with Jave Webstart. "Starting Application" "Unable to create shortcut for 99i Administrative Console" Very strange since all was working OK a few days ago.
  7. Yesterday's Java update went OK on my Mac (OS 10.8.2), but I can no longer log into my ISY99i. I cleared the Java file after the latest update, but when I log into my ISY99i I het "404 Not Found." I downloaded the admin jnlp but get "unable to create shortcut for 99i admin console." I also downloaded dashboard jnlp, but get "unable to crete shortcut for Orchestrator Dashboard." Not sure what is going on, but all was working OK prior to yesterday's Java update. My ISY and PLM are working ok because I can control everything from my iPad or iPhone using the MobilLinc app. Any suggestions? Thanks. James
  8. jam10 posted a topic in ISY994
    Am new at ISY-99i programming, so wondering if someone can guide me on the following issue: Can scenes be created to run programs? I have several programs that turns devices on/off, but when I try to create an "Away" scene, I cannot find a way to add these programs to the scene. All I can do is turn them on/off at the same time if I add them to a scene. Is is possible to create a scene that will execute the timed programs that I have already created? Thanks
  9. I have been using the 2477SA1 Dual Band N/O load controller for about a year now and my pool filter have been working perfectly. I disassembled the Intermatic mechanical pool timer and inserted the 2477SA1 inside the box. In addition to the routine daily timed programs I also used a KeypadLinc button in our kitchen to manually turn pump on/off. Just be sure to purchase the N/O version. James
