emtrader1004
Everything posted by emtrader1004
  1. Originally the wait was 2 minutes but I changed it to 10 secs so I could test the program faster. The program operated the same way regardless of the wait time. I changed the program to: If Status 'Patio Motion Sensor-Sensor' is On And Status 'Patio Motion Sensor-Dusk/Dawn' is On And Status 'MasterBedRm Patio Spots' is not On Or Status 'Kitchen Patio Spots' is not On And Program 'PatioMotionTimerEnable' is True Then Set 'Kitchen Patio Spots' 2 (Beep Duration) Set Scene 'Patio Spots' On Else - No Actions - (To add one, press 'Action') This seems to have solved my problem although I'm not exactly sure why but I won't complain. Thanks for your help.
  2. I believe I have it set for both on and off commands and night only mode. As for the change in the program, it originally said status not control in the first line of PatioMotion
  3. Sorry, beep duration not an issue. The motion sensor will turn the light on when it first senses motion but will not turn it off after no motion is sensed. Also, it was turning the light off after I used the switch to turn the light on and then tripped the motion sensor.
  4. I'm programming challenged and am trying to set up a simple program to control a light with a motion sensor. I want the program to only execute at night and only if the light switch has not been manually turned on. In other words I want it to behave like a typical nighttime motion sensor operating only when motion is sensed after dark, otherwise the light can be manually turned on and off using the switch and unaffected by the motion sensor. I tried coping the program that was on the forum but for some reason it's not working for me. Here is the list of programs I've been using... 'DrivewayMotion' If Control 'Driveway Motion Sensor-Sensor' is switched On And Status 'Driveway Motion Sensor-Dusk/D' is On And Status 'Driveway Spot' is not On And Program 'DrivewayMotionTimerEnable' is True Then Set 'Driveway Spot' 2 (Beep Duration) Set 'Driveway Spot' On Else - No Actions - (To add one, press 'Action') 'DrivewayMotionNotDetected' If Status 'Driveway Motion Sensor-Sensor' is Off And Status 'Driveway Spot' is On And Program 'DrivewayMotionTimerEnable' is True Then Wait 10 seconds Set 'Driveway Spot' Off Else - No Actions - (To add one, press 'Action') 'DrivewayMotionTimerEnable' If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set Program 'DrivewayMotionTimerEnable' To Run At Startup Else Set Program 'DrivewayMotionTimerEnable' To Not Run At Startup 'DrivewayMotionTru/False' If Control 'Driveway Spot' is switched On And Control 'Driveway Spot' is not switched Off Then Run Program 'DrivewayMotionTimerEnable' (Else Path) Else Run Program 'DrivewayMotionTimerEnable' (Then Path) Can someone tell me what I'm doing wrong? I have the sensor set up with the jumper on pin 5 so it will only be controlled from the ISY and I don't have it in a scene with the switch or manually linked to the motion sensor through the set button.
